    Help with configuration
    439
    • Pranaymeundefined
      Pranayme
      I get this error when i try M98 P"config.g"
      Error: Setting not available for external drivers
      Warning: Macro file config-override.g not found
      This is my configuration file.
      config (1).g
      I have one motor on each of x,y and z axes. and one extruder motor. Extruder is connected on to 1XD board and Z is connected to HCL board. The main board is 6HC v1.02. Firmware is 3.4.5.
      Can anyone help me please. Thanks in advance.
      • fcwiltundefined
        fcwilt @Pranayme
        @Pranayme
        Well the warning about config_override.g is simple. You have an M501 near the very end of your config file but you don't have the actual override file. Either disable/remove the M501 or add a empty config-override.g file
        As to the other error perhaps it is this: M569 P40.0 S1 T2:2:2:2.
        Remove the T parameter and see what happens.
        Pranaymeundefined 1 Reply Last reply Reply Quote 0
        • Pranaymeundefined
          Pranayme @fcwilt
          @fcwilt Well the warning is gone, but the error still remains
          • fcwiltundefined
            fcwilt @Pranayme
            @Pranayme said in Help with configuration:
            So you removed the T parameter?
            • Pranaymeundefined
              Pranayme @fcwilt
              @fcwilt Yes, but got the same error
              • fcwiltundefined
                fcwilt @Pranayme
                You are "re-booting" after changing config.g - correct?
                • Pranaymeundefined
                  Pranayme @fcwilt
                  @fcwilt No i didn't reboot. I sent M98 P"config.g"
                  • fcwiltundefined
                    fcwilt @Pranayme
                    Just to be safe try a re-boot. I vaguely recall that some configuration settings need a re-boot to clear them.
                    I always re-boot to be safe.
                    • Pranaymeundefined
                      Pranayme @fcwilt
                      @fcwilt
                      Tried reboot, but same thing.
                      fcwiltundefined 2 Replies Last reply Reply Quote 0
                      • fcwiltundefined
                        fcwilt @Pranayme
                        @fcwilt
                        OK thanks.
                        Let me take another look.
                        • fcwiltundefined
                          fcwilt @Pranayme
                          @Pranayme
                          While I ponder this you could try a "brute force" approach and edit things so you are:
                          • configuring X only
                          • test
                          • then add Y
                          • test
                          • then add Z
                          • test
                          Tedious but likely to reveal the problem.
                          • fcwiltundefined
                            fcwilt @fcwilt
                            @fcwilt
                            Oh, you have a M569.7 command twice.
                            It may or may not matter.
                            • Pranaymeundefined
                              Pranayme @fcwilt
                              @fcwilt I did this, X,Y and Z axis were fine. The error came when I had the extruder configuration alone.
                              • Pranaymeundefined Pranayme marked this topic as a question
                              • fcwiltundefined
                                fcwilt @Pranayme
                                Good job.
                                Now we can focus on axis E.
                                How about adding back each E related item and test.
                                One of them should be the source of the error.
                                Again tedious but likely effective.
                                • Pranaymeundefined
                                  Pranayme @fcwilt
                                  @fcwilt Error was with the M906 command
                                  • fcwiltundefined
                                    fcwilt @Pranayme
                                    Good job.
                                    I know it was tedious but it worked.
                                    I wonder how you do set the current for that stepper - clearly related to using the 1XD board.
                                    • Pranaymeundefined Pranayme has marked this topic as solved
