Solved Help with configuration
Well the warning about config_override.g is simple. You have an M501 near the very end of your config file but you don't have the actual override file. Either disable/remove the M501 or add a empty config-override.g file
As to the other error perhaps it is this: M569 P40.0 S1 T2:2:2:2.
Remove the T parameter and see what happens.
@fcwilt Well the warning is gone, but the error still remains
@Pranayme said in Help with configuration:
So you removed the T parameter?
@fcwilt Yes, but got the same error
You are "re-booting" after changing config.g - correct?
@fcwilt No i didn't reboot. I sent M98 P"config.g"
Just to be safe try a re-boot. I vaguely recall that some configuration settings need a re-boot to clear them.
I always re-boot to be safe.
@fcwilt
Tried reboot, but same thing.
Error: Setting not available for external drivers -
@fcwilt
Error: Setting not available for external driversOK thanks.
Let me take another look.
While I ponder this you could try a "brute force" approach and edit things so you are:
- configuring X only
- test
- then add Y
- test
- then add Z
- test
Tedious but likely to reveal the problem.
@fcwilt I did this, X,Y and Z axis were fine. The error came when I had the extruder configuration alone.
Good job.
Now we can focus on axis E.
How about adding back each E related item and test.
One of them should be the source of the error.
Again tedious but likely effective.
@fcwilt Error was with the M906 command
Good job.
I know it was tedious but it worked.
I wonder how you do set the current for that stepper - clearly related to using the 1XD board.
