    5bar scara Problem configuring z probe using fsr switch
    4.3k
    • gnmrc_undefined
      gnmrc_ @fcwilt
      @fcwilt It will work but would be like skipping the problem. I want to make the homing work properly as intended.
      Gianmarco
      • fcwiltundefined
        fcwilt @gnmrc_
        @gnmrc_ said in Problem configuring z probe using fsr switch:
        Gianmarco
        There is no "properly" - there are just several ways to achieve the desired outcome.
        Consider this printer of mine using three Z steppers to achieve auto bed leveling:
        Bed Leveling Demo
        Now I purposely put the bed way out of level to demonstrate the auto bed leveling. It works because each Z axis has it's on endstop switch. It would not be possible with a typical Z probe to level the bed as it is.
        Once the bed is level then I use the Z probe to run the firmware's bed leveling feature which fine tunes the result obtained from leveling with the endstop switches.
        It's your printer and you can do anything you want but don't frustrate yourself thinking homing Z with a probe is "as intended".
        Good luck.
        gnmrc_undefined 1 Reply Last reply Reply Quote 0
        • gnmrc_undefined
          gnmrc_ @fcwilt
          @fcwilt Ok, I'm gonna do that way.
          By the way I forgot to link the videos of the machine:
          This is the overshoot that the arm does
          This is the homing only of the 2 arms and after the g92 command followed by the G0 x0 y0.
          Thanks,
          Gianmarco
          • fcwiltundefined
            fcwilt @gnmrc_
            @gnmrc_
            That is a fascinating machine.
            Please post your most recent config.g file and the various homing files.
            We are overlooking something simple - I think.
            • gnmrc_undefined
              gnmrc_ @fcwilt
              @fcwilt
              This is the most recent config file: config (1).g
              and this is the most recent homing file:home5barscara (2).g
              (I left commented some workarounds that I tried)
              Thanks for all the help that you are giving me,
              Gianmarco.
              • fcwiltundefined
                fcwilt @gnmrc_
                @gnmrc_
                Sorry it is taking so long.
                In your homing file at the end you have
                G1 X0 Y0 S2
                Why the S2?
                • gnmrc_undefined
                  gnmrc_ @fcwilt
                  @fcwilt, do not worry about the time I’m not in a hurry.
                  I use S2 because it makes me move the arm even if it’s not homed, other h commands would not make it move, I do not know why.
                  Gianmarco
                  • fcwiltundefined
                    fcwilt @gnmrc_
                    Gianmarco
                    What version of firmware are you using?
                    This is what the docs says about that for v3 firmware:
                    Snnn In RRF3, this parameter is used to set laser power, when switched into Laser mode (see M452); its use for defining move type is deprecated, use 'H' parameter instead. In RRF2.02 and later, when switched into Laser mode (see M452), this parameter sets the laser power. When not switched into Laser mode, and always in firmware 2.01 and earlier, it defines the move type (see the description of the H parameter).
                    Also the G1 H1 moves in the homing file, assuming they triggered the endstops, should have marked the axis as homed.
                    If that is not happening something is wrong with the code or the endstops (configuration, wiring, etc).
                    gnmrc_undefined 1 Reply Last reply Reply Quote 1
                      Can you send M122 in the gcode console and share the results?
                      • gnmrc_undefined
                        gnmrc_ @fcwilt
                        @fcwilt
                        So I’m using RRF3.
                        I’m going to re-test it but when I use the S2 command it gives me a warning message saying obsolete command, but still moves as the old s2 command so ignoring homing not completed.
                        Gianmarco
                        • fcwiltundefined
                          fcwilt @gnmrc_
                          @fcwilt
                          So I’m using RRF3.
                          Gianmarco
                          Good to know. Often commands and command options, like S2, are deprecated but not yet gone.
                          But it still leaves the question of why the two H1 moves aren't marking the axes as homed.
                          I notice that you specify the movement distance as X200 and Y200.
                          Be aware that if the endstop swtiches are not activated by the time the distance has been moved the axis is not marked as homed.
                          Is 200 long enough to insure the endstop switches are reached?
                          • gnmrc_undefined
                            gnmrc_ @fcwilt
                            @fcwilt Yes endstop are reached with no problems from any arm position.
                            Maybe the movement does not work because it needs to home every axis not only x and y for some reason, this would explain the problem with the movement and why the arm works correctly after a partial homing routine(homing only the arm) and then using g92 to home z and after that everything works as expected.
                            Let me know what you think.
                            Thanks,
                            Gianmarco
                            • fcwiltundefined
                              fcwilt @gnmrc_
                              @gnmrc_
                              Here are the last three lines from the most recent homing code:
                              G90
                              G1 X0 Y0 F300 S2 ;move hotend to the center
                              G30
                              As I recall you said the S2 (which should be H2 according to the docs) is needed.
                              But if the previous two G1 H1 commands worked the X and Y axis should be homed and the S2 (H2) should not be needed.
                              Now the G30 is the probing command and it is not going to work since it needs the Z axis to be homed.
                              And there is nothing in your homing file that tries to home the Z axis.
                              To help clarify something try this, please:
                              • remove the S2 from the last G1 command
                              • remove the G30 command
                              • test homing now
                              Yes, I know that Z axis will not be homed but I am not worried about that.
                              What worries me is the need for the S2.
                              • gnmrc_undefined
                                gnmrc_ @fcwilt
                                @fcwilt I’ve done as you said, this is the error I get:
                                G0/G1: insufficient axes homed
                                • gnmrc_undefined
                                  gnmrc_ @Phaedrux
                                  @Phaedrux this is what I get from m122:
                                  m122
                                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.4.5 (2022-11-30 19:36:12) running on Duet WiFi 1.02 or later
                                  Board ID: 0JD0M-9P6M2-NWNS0-7JKDD-3SN6S-1U0BJ
                                  Used output buffers: 1 of 26 (11 max)
                                  Static ram: 23836
                                  Dynamic ram: 74172 of which 68 recycled
                                  Never used RAM 14004, free system stack 184 words
                                  Tasks: NETWORK(ready,13.4%,242) HEAT(notifyWait,0.0%,333) Move(notifyWait,0.0%,363) MAIN(running,84.1%,446) IDLE(ready,2.5%,30), total 100.0%
                                  Owned mutexes:
                                  Last reset 00:00:37 ago, cause: power up
                                  Last software reset at 2023-10-19 21:58, reason: User, GCodes spinning, available RAM 13692, slot 2
                                  Error status: 0x00
                                  Step timer max interval 0
                                  MCU temperature: min 29.8, current 33.2, max 33.4
                                  Supply voltage: min 12.5, current 12.5, max 12.6, under voltage events: 0, over voltage events: 0, power good: yes
                                  Events: 0 queued, 0 completed
                                  Driver 0: standstill, SG min n/a
                                  Driver 1: standstill, SG min n/a
                                  Driver 2: standstill, SG min n/a
                                  Driver 3: standstill, SG min n/a
                                  Driver 4: standstill, SG min n/a
                                  Driver 5:
                                  Driver 6:
                                  Driver 7:
                                  Driver 8:
                                  Driver 9:
                                  Driver 10:
                                  Driver 11:
                                  Date/time: 2023-10-24 17:39:02
                                  Cache data hit count 1374063136
                                  Slowest loop: 6.81ms; fastest: 0.18ms
                                  === Storage ===
                                  Free file entries: 10
                                  SD card longest read time 2.4ms, write time 0.0ms, max retries 0
                                  DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, comp offset 0.000
                                  === MainDDARing ===
                                  === AuxDDARing ===
                                  Segments left: 0
                                  Movement lock held by null
                                  HTTP is idle in state(s) 0
                                  Telnet is idle in state(s) 0
                                  File is idle in state(s) 0
                                  USB is idle in state(s) 0
                                  Aux is idle in state(s) 0
                                  Trigger is idle in state(s) 0
                                  Queue is idle in state(s) 0
                                  LCD is idle in state(s) 0
                                  Daemon is idle in state(s) 0
                                  Code queue is empty
                                  === Network ===
                                  Slowest loop: 15.77ms; fastest: 0.00ms
                                  Responder states: HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                                  HTTP sessions: 1 of 8
                                  = WiFi =
                                  Network state is active
                                  WiFi firmware version 1.23
                                  WiFi MAC address 98💿ac:20:cb:ca
                                  WiFi Vcc 3.37, reset reason Turned on by main processor
                                  WiFi flash size 4194304, free heap 25824
                                  WiFi IP address 192.168.178.109
                                  WiFi signal strength -54dBm, mode none, reconnections 0, sleep mode modem
                                  Clock register ffffffff
                                  • fcwiltundefined
                                    fcwilt @gnmrc_
                                    I should have asked - exactly what are you/it doing when this message appears - during the homing file execution?
                                    • gnmrc_undefined
                                      gnmrc_ @fcwilt
                                      @fcwilt It’does nothing the arm stays in his homed position
                                      Gianmarco
                                      • fcwiltundefined
                                        fcwilt @gnmrc_
                                        @fcwilt It’does nothing it stops the movement.
                                        When does that happen?
                                        When trying to execute the homing file?
                                        After that?
                                          I assume you're working from this?
                                          https://docs.duet3d.com/en/User_manual/Machine_configuration/Configuration_five_bar_parallel_scara
                                          • gnmrc_undefined
                                            gnmrc_ @fcwilt
                                            @fcwilt, no the arm homes itself, then when it should do the x0 y0 move it stops
