    5bar scara Problem configuring z probe using fsr switch
    4.2k
    • gnmrc_undefined
      gnmrc_ @fcwilt
      @fcwilt, no the arm homes itself, then when it should do the x0 y0 move it stops
      • gnmrc_undefined
        gnmrc_ @Phaedrux
        @Phaedrux yes, I’m using that and I used some other forum post from 2019 I think.
        • fcwiltundefined
          fcwilt @gnmrc_
          @gnmrc_ said in Problem configuring z probe using fsr switch:
          Try to be more precise - I am not there seeing what you are seeing - need to help fill in the gaps of my knowledge. Thanks.
          Are you referring to the move to X=0 Y=0 at the end of the homing file?
          That is when you get the error message about un-homed axes?
          Correct?
          IF that is what is happening then the G1 H1 moves are NOT homing the axes. If they were being homed the move to X=0 Y=0 would work.
          When a homing move fails, that is it reaches the end of the specified travel (in your case 200) without activating the endstop switch, there is no error message - it just stops moving and the axis is still not homed.
          So remove the move to X=0 Y=0 (if it is still there), re-boot the machine and click on the HomeAll button in the DWC Dashboard.
          Once the movement in both axes stops. check if the X and Y home buttons have changed to indicate they are homed.
          gnmrc_undefined 1 Reply Last reply Reply Quote 0
          • gnmrc_undefined
            gnmrc_ @fcwilt
            @fcwilt yes exactly, the machine stops before the x=0 y=0 move in the homing file, but I see from the board’s leds that my endstop gets triggered,I even tested with m119 ,and the arms stops when touching their relative endstops so I do not think this is the case.
            Also if I only do the G1 H1 X and G1 H1 Y moves in the homing file when it ends my x and y axis results as homed.
            Gianmarco
              What are all the files in your system folder? It's not executing a different file than you expect is it?
              • gnmrc_undefined
                gnmrc_ @Phaedrux
                @Phaedrux no I checked, there is only 1 home5barscara.g
                • fcwiltundefined
                  fcwilt @gnmrc_
                  @gnmrc_ said in 5bar scara Problem configuring z probe using fsr switch:
                  Gianmarco
                  Great, good to know. Thank you.
                  However I am still at a loss as to why the you cannot so a simple G90 followed by a plain G1 X0 Y0 unless...
                  OK, let's try this:
                  • create a HomeX.g file and put just the G91 G1 H1 X200 F300 commands in it
                  • create a HomeY.g file and put just the G91 G1 H1 Y200 F300 command sin it
                  • re-boot the machine
                  • click the Home X button and see if all goes well
                  • click the Home Y button and see if all goes well
                  • from the Console of the DWC execute an M208 and report back
                  Thanks very much.
                  • gnmrc_undefined
                    gnmrc_ @fcwilt
                    @fcwilt Yeah it’s really a frustrating situation….
                    Ok I will try this solution and report back, but if I remember correctly it’s not possible to do an home X file and an home Y file, because reprap for a 5bar scara configuration during homing procedure will search and execute only a home5barscara.g, if this actually happens, I will create 2 macros home left and home right than put them in the homing file and see what happens.
                    Thanks for the help,
                    Gianmarco
                      This thread is a bit long now. Can you create a summary post of the issue as it is currently and I can pass it along to DC42 to see if he has any suggestions.
                      gnmrc_undefined 2 Replies Last reply Reply Quote 0
                      • fcwiltundefined
                        fcwilt @gnmrc_
                        Gianmarco
                        Well if that is the case that you have to have the special file then I have no idea what might be going on.
                        So just edit that one homing file and after the two G1 H1 commands add a M208.
                        I want to know what the M208 "thinks" at that point.
                        • gnmrc_undefined
                          gnmrc_ @Phaedrux
                          @Phaedrux ok thanks so:
                          I’ve built a 5bar scara arm, I can home the 2 arms in the home5barscara.g but when I try to do a G0/G1 move to set the hotend position to the center to home z, the arms overshoots the required position. If I only home the arms than send a G92 Z## the arm works as expected.
                          In this thread there are also the config and homing files, plus the videos of the machine behaviour.
                          Gianmarco.
                          • gnmrc_undefined
                            gnmrc_ @fcwilt
                            @fcwilt Ok, I’m going to report back asap.
                            Thanks,
                            Gianmarco
                            • gnmrc_undefined
                              gnmrc_ @fcwilt
                              @fcwilt so this is what I get from m208:
                              g28
                              Axis limits (mm)s X-162.7:250.0, Y-108.5:250.0, Z0.0:200.0
                              Error: Failed to home axes Z
                              Gianmarco
                              • fcwiltundefined
                                fcwilt @gnmrc_
                                g28
                                Gianmarco
                                Thanks. That all looks normal.
                                It seems that your kind of printer has some unique requirements - like changing the name of of HomeALL.g to something else.
                                So who knows what else is going on. In a "normal" printer you would have some code to home the Z axis in your HomeALL.g file. But after the X and Y are homed they can move to wherever is needed to home Z.
                                But in your case to move to X=0 Y=0 you have to force Z to be homed with a G92 - which makes no sense to me at all.
                                I gather from your config.g file you have a Z Probe which, in theory, would be used to home Z.
                                Since the G92 allows you to move to X=0 Y=0 have you tried adding the code to home Z with the probe?
                                Can you specify in G92 close to the actual position of Z? If so you can still move forward and home Z with the probe and the actual Z position would finally be established.
                                Or maybe you have to home Z first somehow?
                                Just out of curiosity what took you down the path to a SCARA printer in the first place?
                                  if you send G30 on it's own does it attempt to use the probe?
                                  • gnmrc_undefined
                                    gnmrc_ @Phaedrux
                                    @Phaedrux Yes, the heated bed is moved up, but due to the zprobe not being inside the bed area the heated bed crash. But if I manually activate the probe the homing is completed.
                                    • fcwiltundefined
                                      fcwilt @gnmrc_
                                      One "disadvantage" of homing Z with the probe is X and Y need to home first so the probe can be moved into position.
                                      I don't like that so all of my printers have a physical Z endstop switch or sensor so I can home Z first thing and be sure it is safely out of the way when homing X and Y.
                                      Then I use the Z probe for setting the Z=0 Datum, leveling the bed, creating the height map, etc.
                                      Have you consider going that way - adding a endstop switch to the Z axis - it sounds like it might solve all of your problems.
                                      • gnmrc_undefined
                                        gnmrc_ @fcwilt
                                        @fcwilt yes in the homing file I tried to use a dummy G92 comand to trick the machine in to moving, but with no success. There is something that I’m missing but I can’t figure it out.
                                        So I wanted to build a SCARA printer because I think that there is a lot of unexpressed potential in this kinematic but due to it’s complexity there aren’t a lot of people that wants to build one of this printers and improve them. This type of printers are left in an embrional state, particularly the 5bar one, the only 2 guys that I have seen make them work are Joerg and Pontus Borg but 3/4years have passed since the last videos and post about those printers.
                                        Gianmarco
                                        • gnmrc_undefined
                                          gnmrc_ @fcwilt
                                          @fcwilt for semplicity of wiring I would prefere to have only the probe, but due to all this problems I’m really considering this solution.
                                          Gianmarco
                                          • fcwiltundefined
                                            fcwilt @gnmrc_
                                            I clearly misunderstood. I thought the G92 did allow homing to complete.
                                            Just out of curiosity how about a test where the G92 for the Z axis is before the two G1 H1 moves. Then you could see if the G1 X0 Y0 move needed H2/S2.
                                            If that worked once you could get to X=0 Y=0 then you could use the Z probe to accurately set the Z axis.
