    5bar scara Problem configuring z probe using fsr switch
    4.4k
    • fcwiltundefined
      fcwilt @gnmrc_
      @gnmrc_ said in 5bar scara Problem configuring z probe using fsr switch:
      @fcwilt so this is what I get from m208:
      g28
      Axis limits (mm)s X-162.7:250.0, Y-108.5:250.0, Z0.0:200.0
      Error: Failed to home axes Z
      Thanks for the help,
      Gianmarco
      Thanks. That all looks normal.
      It seems that your kind of printer has some unique requirements - like changing the name of of HomeALL.g to something else.
      So who knows what else is going on. In a "normal" printer you would have some code to home the Z axis in your HomeALL.g file. But after the X and Y are homed they can move to wherever is needed to home Z.
      But in your case to move to X=0 Y=0 you have to force Z to be homed with a G92 - which makes no sense to me at all.
      I gather from your config.g file you have a Z Probe which, in theory, would be used to home Z.
      Since the G92 allows you to move to X=0 Y=0 have you tried adding the code to home Z with the probe?
      Can you specify in G92 close to the actual position of Z? If so you can still move forward and home Z with the probe and the actual Z position would finally be established.
      Or maybe you have to home Z first somehow?
      Just out of curiosity what took you down the path to a SCARA printer in the first place?
      gnmrc_undefined 1 Reply Last reply Reply Quote 0
        if you send G30 on it's own does it attempt to use the probe?
        • gnmrc_undefined
          gnmrc_ @Phaedrux
          @Phaedrux Yes, the heated bed is moved up, but due to the zprobe not being inside the bed area the heated bed crash. But if I manually activate the probe the homing is completed.
          • fcwiltundefined
            fcwilt @gnmrc_
            One "disadvantage" of homing Z with the probe is X and Y need to home first so the probe can be moved into position.
            I don't like that so all of my printers have a physical Z endstop switch or sensor so I can home Z first thing and be sure it is safely out of the way when homing X and Y.
            Then I use the Z probe for setting the Z=0 Datum, leveling the bed, creating the height map, etc.
            Have you consider going that way - adding a endstop switch to the Z axis - it sounds like it might solve all of your problems.
            • gnmrc_undefined
              gnmrc_ @fcwilt
              @fcwilt yes in the homing file I tried to use a dummy G92 comand to trick the machine in to moving, but with no success. There is something that I’m missing but I can’t figure it out.
              So I wanted to build a SCARA printer because I think that there is a lot of unexpressed potential in this kinematic but due to it’s complexity there aren’t a lot of people that wants to build one of this printers and improve them. This type of printers are left in an embrional state, particularly the 5bar one, the only 2 guys that I have seen make them work are Joerg and Pontus Borg but 3/4years have passed since the last videos and post about those printers.
              Gianmarco
              • gnmrc_undefined
                gnmrc_ @fcwilt
                @fcwilt for semplicity of wiring I would prefere to have only the probe, but due to all this problems I’m really considering this solution.
                Gianmarco
                • fcwiltundefined
                  fcwilt @gnmrc_
                  I clearly misunderstood. I thought the G92 did allow homing to complete.
                  Just out of curiosity how about a test where the G92 for the Z axis is before the two G1 H1 moves. Then you could see if the G1 X0 Y0 move needed H2/S2.
                  If that worked once you could get to X=0 Y=0 then you could use the Z probe to accurately set the Z axis.
                  • gnmrc_undefined
                    gnmrc_ @fcwilt
                    @fcwilt Nice idea, I’m gonna try and see if this trick works.
                    Gianmarco
                    • fcwiltundefined
                      fcwilt @gnmrc_
                      Gianmarco
                      I haven't been much help so far.
                      To date what I have mostly done is help you to find new and interesting things that don't work. 😀
                      • gnmrc_undefined
                        gnmrc_ @fcwilt
                        @fcwilt It’s not true, we are trying to solve a problem that seems easier than what it really is on a complex and not so well documented machine. You gave a really big help trying to figure out what the problem is, and giving option on how to solve it.
                        By the way if you want to build one I can give you the cad files so you have the machine too and we can complete the build of a well documented and easy to work scara arm.
                        Gianmarco
                        • fcwiltundefined
                          fcwilt @gnmrc_
                          @gnmrc_
                          Actually I would like the CAD files - I'm always up for a challenge and I like new and interesting things to work on.
                          • gnmrc_undefined
                            gnmrc_ @fcwilt
                            @fcwilt ok I’m gonna send it to you, but I have no idea in how to do it. Can I link them here in some way?
                            • fcwiltundefined
                              fcwilt @gnmrc_
                              Are they large?
                              You can attach files to messages here but I don't know if there is a size limit.
                              Perhaps you can email them?
                              Or I have a DropBox account. Maybe there is a way you can leave them there. I would have to research how to do that.
                              • gnmrc_undefined
                                gnmrc_ @fcwilt
                                @fcwilt Yes they are too big to link them here, the dropbox could be the best way.
                                • fcwiltundefined
                                  fcwilt @gnmrc_
                                  Do you have a Dropbox account? I know how to share files (yours to me) but I don't know how to allow you to put files into my Dropbox.
                                  • gnmrc_undefined
                                    gnmrc_ @fcwilt
                                    @fcwilt no but we can use a google drive in the same way right?
                                    • fcwiltundefined
                                      fcwilt @gnmrc_
                                      I don't know. I have it but to do certain things you have to sign up for a paid account. It's not much it's still another $72 annually - minimum.
                                      Do you have Google Drive?
                                      gnmrc_undefined 2 Replies Last reply Reply Quote 0
                                      • gnmrc_undefined
                                        gnmrc_ @fcwilt
                                        @fcwilt yes, it would be simpler to link them there
                                        • gnmrc_undefined
                                          gnmrc_ @fcwilt
                                          This post is deleted!
                                          • gnmrc_undefined
                                            gnmrc_ @Phaedrux
                                            @Phaedrux said in 5bar scara Problem configuring z probe using fsr switch:
                                            This thread is a bit long now. Can you create a summary post of the issue as it is currently and I can pass it along to DC42 to see if he has any suggestions.
                                            @Phaedrux do you have any news from DC42?
