Genuine BLtouch 3.1 no output
So I I have definately wired the power correctly because it lights up and does the self test. After the test, the red led remains on. Presumably this means it hasn't found any issues?
With the pin retracted, I don't get a value in DWC. Also my mutltimeter is saying there's no voltage between the black wire and the white wire. Neither do I get any voltage when the pin is extended.
However I can retract and extend the pin via DWC. It just doesn't make a difference to the value in the Z column. I have wired the black wire to gnd and white wire to the in pin of the Z probe connector on my duet ethernet 2 board
So is it faulty?I should buy the lottery because am lucky enough to get a faulty bltouch
@ageis The lines in your configuration file for this device - what do they contain?
; Configuration file for Duet WiFi (firmware version 3.3) ; executed by the firmware on start-up ; ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sun Jul 23 2023 20:00:34 GMT+0100 (British Summer Time) ; General preferences G90 ; send absolute coordinates... M83 ; ...but relative extruder moves M550 P"prusa" ; set printer name ; Network M552 P0.0.0.0 S1 ; enable network and acquire dynamic address via DHCP M586 P0 S1 ; enable HTTP M586 P1 S0 ; disable FTP M586 P2 S0 ; disable Telnet ; Drives M569 P0 S1 ; physical drive 0 goes forwards M569 P1 S1 ; physical drive 1 goes forwards M569 P2 S1 ; physical drive 2 goes forwards M569 P3 S1 ; physical drive 3 goes forwards M584 X0 Y1 Z2 E3 ; set drive mapping M350 X16 Y16 Z16 E16 I1 ; configure microstepping with interpolation M92 X98.52 Y100.00 Z400.00 E161.3 ; set steps per mm M566 X900.00 Y900.00 Z12.00 E120.00 ; set maximum instantaneous speed changes (mm/min) M203 X6000.00 Y6000.00 Z1000.00 E1200.00 ; set maximum speeds (mm/min) M201 X500.00 Y20.00 Z400.00 E250.00 ; set accelerations (mm/s^2) M906 X1300 Y800 Z800 E800 I30 ; set motor currents (mA) and motor idle factor in per cent M84 S30 ; Set idle timeout ; Axis Limits M208 X0 Y0 Z0 S1 ; set axis minima M208 X250 Y190 Z210 S0 ; set axis maxima ; Endstops M574 X1 S1 P"xstop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop M574 Z1 S2 ; configure Z-probe endstop for low end on Z ; Z-Probe ;M558 P8 C"zprobe.in" H10 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds M558 P9 C"^zprobe.in" H15 F120 T6000 M950 S0 C"exp.heater3" ;G31 P500 X22 Y10 Z120.1 0; set Z probe trigger value, offset and trigger height G31 P500 X30 Y52 Z0; set Z probe trigger value, offset and trigger height M557 X40:235 Y0:190 S10 ; define mesh grid ; Heaters M308 S0 P"bedtemp" Y"thermistor" T100000 B4138 ; configure sensor 0 as thermistor on pin bedtemp M950 H0 C"bedheat" T0 ; create bed heater output on bedheat and map it to sensor 0 ;M307 H0 B1 S1.00 ; enable bang-bang mode for the bed heater and set PWM limit M307 H0 R0.268 K0.283:0.000 D13.25 E1.35 S1.00 B0 M140 H0 ; map heated bed to heater 0 M143 H0 S120 ; set temperature limit for heater 0 to 120C M308 S1 P"e0temp" Y"thermistor" T100000 B4138 ; configure sensor 1 as thermistor on pin e0temp M950 H1 C"e0heat" T1 ; create nozzle heater output on e0heat and map it to sensor 1 M307 H1 B0 S1.00 ; disable bang-bang mode for heater and set PWM limit M143 H1 S280 ; set temperature limit for heater 1 to 280C ; Fans M950 F0 C"fan0" Q500 ; create fan 0 on pin fan0 and set its frequency M106 P0 S0 H-1 ; set fan 0 value. Thermostatic control is turned off M950 F1 C"fan1" Q500 ; create fan 1 on pin fan1 and set its frequency M106 P1 S1 H1 T45 ; set fan 1 value. Thermostatic control is turned on ; Tools M563 P0 D0 H1 F0 ; define tool 0 G10 P0 X0 Y0 Z0 ; set tool 0 axis offsets G10 P0 R0 S0 ; set initial tool 0 active and standby temperatures to 0C ; Custom settings are not defined T0 So my wiring is exactly like the image on the documentation
https://docs.duet3d.com/manual/sensors/sensors_probe_bltouch_d2we.png
Why no voltage on the output though if it's config issue? Is it a PWM signal?
@ageis said in Genuine BLtouch 3.1 no output:
You're unlikely to see any change displayed in DWC since the BLTouch triggers and instantly resets itself. Your best bet to see if it's functioning is to follow this guide: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_testing
@ageis Can you issue the commands that deploy and retract?
@fcwilt
Thats just it, I can. Thats what's got me confused.When I issue M280 P0 S10 it extends and the led switches off.
When I issue M280 P0 S90 it retracts and the led turns on.
confused!
Just no response on the output. I have buzzed out the black and white wires. Just in case it's my dodgy crimping but they seem fine.
@ageis That leaves a bad input or the wrong input? Quadruple check you are connected to the correct pin and using the correct pin name.
Does M401 and M402 work to deploy and retract?
Have you actually tried a G30 to see if it deploys the pin and trigger the pin by hand to see if it stops movement?
@Phaedrux
both M401 and 402 does nothing. but M280 P0 S10 and M280 S90 works.I noticed the pin doesn't get deployed when executing G30 or a G28.
It should deploy the pin when I do a G30 right? -
Then your deployprobe.g and retractprobe.g either haven't been created or don't contain the correct commands. Or maybe they aren't in the right spot. They should be in the sys folder.
@ageis I seem to recall that for the M commands to work you need to create two files deployprobe.g and retractprobe.g and put the appropriate servo command into the file.
@fcwilt
Yeah I skipped that step by mistake. Rushing through things yet again. I never learn.It works now.
Many Thanks to @fcwilt and @PhaedruxThe bltouch appears to be repeatable so far. The 5 trigger height measurments I did were all +/- 0.1mm of each other.
My chinese sister invented a good product. I believe the engineer that invented the BL TOuch was female and chinese. Unless the picture i saw was just a representive. I hope I can finally get a consistent first layer. Not 0.3mm on one side then barely anything on the other side.
