    Movement after M112 E-Stop!
    CNC
    3.6k
    • timschneiderundefined
      timschneider @gloomyandy
      @gloomyandy sure. I did even more tests.
      run M112 from console will change the behaviour a bit, the last disable / enable toggle will disappear. It appears to me, that a reset will also toggle the driver enable once.
      I've changed the test setup to be able to test the sbc setup.
      Unfortunately, it will also fail, so there is also movement after the M112.
      the following screens are all taken with SBC setup 3.4.6
      and the following config.g
      M669 K0 X1:0:0 Y0:1:0 Z0:0:1 S1 T1                      ; Cartesian kinematics
      M569 P0 R0 T1:1:2:0
      M569 P1 R0 T1:1:2:0
      M569 P2 R0 T1:1:2:0
      M569 P3 R0 T1:1:2:0
      M569 P4 R0 T1:1:2:0
      M569 P5 R0 T1:1:2:0
      M569 P0 S1
      M569 P1 S1
      M569 P2 S1
      M569 P3 S1
      M569 P4 S1
      M569 P5 S1
      G90                                                     ; send absolute coordinates...
      M584 X0 Y4:5 Z3                                         ; set drive mapping
      M92 X400 Y400 Z800                                      ; set steps per mm 4000 steps/rev / 10 mm pitch - 5mm on z
      M566 X120.0 Y120.0 Z120.00 P1                           ; set maximum instantaneous speed changes (mm/min) and apply jerk on every move
      M203 X10000.00 Y10000.00 Z7000.00                       ; set maximum speeds (mm/min)
      M201 X400.00 Y500.00 Z1000.00                           ; set accelerations (mm/s^2)
      M204 P250 T1250                                         ; Set printing and travel accelerations
      M84 S30                                                 ; Set idle timeout
      M208 X0 Y0 Z0 S1                                        ; set axis minima
      M208 X1330 Y1036 Z278 S0                               ; set axis maxima
      ; Mode Selector
      M453                                                    ; Select CNC Mode
      without M669 S1 T1
      with M669 S1 T1
      with M112 in console
      with Emergency Stop in DWC
      hpizundefined timschneiderundefined 2 Replies Last reply Reply Quote 1
      • hpizundefined
        hpiz @timschneider
        @timschneider What a relief to hear this is reproducible, I was starting to get really depressed. And you beat me to yanking my 6xd out of the cabinet and wiring resistors on an unconnected drive output on the 6xd. That was literally gonna be my next course of troubleshooting.
        I took a vacation day today, so I'm about to test the Z (although your test all but confirm this is board/firmware behavior). Will post vid shortly.
          timschneider @timschneider
          I did some more test, as I was not able to see this behaviour in my last cnc build. So I was recording the STEP and Enable Signal for the other driver 0,1,2,3 and 5 as well, all with M112 mapped to the Y-axis.
          M584 X4 Y0:1:3:5 Z2
          and
          M584 X4 Y0:1:2:5 Z3
          btw. the resistors are all 15k
          driver0
          driver1
          driver2
          driver3
          driver5
          timschneiderundefined hpizundefined 2 Replies Last reply Reply Quote 0
            it looks like the motion system takes some time to shut down - so is it possible that the following will reactivate the drive again after an EmergencyStop?
            In the function void DDA::Prepare(SimulationMode simMode) noexcept
            • hpizundefined
              hpiz @timschneider
              @timschneider Obviously my scope is way worse than Tim's so I would reference Tim's scope grabs over my shoddy videos, but I'm trying to do what I can...
              Z stepper test with M112 in job
              Z stepper test with no M112 in job, using DWC EStop
              And lastly...
              Z stepper test using external estop trigger with T0
              That last one, in my mind, all but confirms there is a wait delay in that driver after enable is reactivated, and depending on how long the Duet keeps it enabled, eventually it too does move, but reacts to disabling immediately.
              timschneiderundefined 1 Reply Last reply Reply Quote 0
                timschneider @hpiz
                @hpiz I was using the 6XD quite a while without noticeing, so I think it is a good teamwork!
                and I guess I maybe found the place where the delay kicks in
                when the seperate move thread was added, the active switch fall overboard and it appears to me, that TerminateAndUnlink needs some time to terminate and unlink, and in the meantime, new moves are prepared, and the prepare move is enableing the drive again.
                  droftarts administrators @timschneider
                  @timschneider @hpiz Thanks for all your investigative work, I've flagged this to @dc42.
                    dc42 administrators @droftarts
                    Hi all, so does this issue occur only when using external drivers, for example with a 6XD? Does it occur only in SBC mode?
                    @timschneider which source code branch are you looking at? The current 3.5-dev and 3.4-dev source code has this for Move::Exit:
                    void Move::Exit() noexcept
                    	StepTimer::DisableTimerInterrupt();
                    	rings[0].Exit();
                    #if SUPPORT_ASYNC_MOVES
                    	rings[1].Exit();
                    #endif
                    #if SUPPORT_LASER || SUPPORT_IOBITS
                    	delete laserTask;
                    	laserTask = nullptr;
                    #endif
                    	moveTask.TerminateAndUnlink();
                    That should be sufficient to stop all movement.
                    @hpiz which firmware version are you using?
                    PS - when Emergency Stop is pressed in DWC, it sends M112 and then after a little while it sends M999 to reset the Duet. At the reset the driver Enable signal may go to Enabled again, depending on its polarity. But by then the movement queue is empty because RRF has re-initialised.
                      timschneider @dc42
                      sorry I was referring to the commit where the Move Task was added.
                      But you give the right hint, I was looking in the wrong direction, as it can bee seen from the oscilloscope that the stop of the step generation is delayed. So I guess, another code before Move::Exit is delayed or the very first line StepTimer::DisableTimerInterrupt is slow.
                      I'll be back in the office on monday, then I can do the above tests with Duet 3 6HC.
                      hpiz is using 3.4.6 - from the debug log
                      power up + 00:00:00 [info] Running: Duet 3 MB6XD v1.01 or later: 3.4.6 (2023-07-21 14:11:58)
                      • hpizundefined
                        hpiz @dc42
                        @dc42 Hi, I have a Duet 2 I could test 3.4.6 with to see steps on my analog scope. Not sure if that helps...
                          dc42 administrators @hpiz
                          All, when you see this behaviour is it just the remainder of the current move that continues to execute after a pause? The Move::Exit code empties the movement queues but I'm wondering whether the step interrupt might be getting re-enabled and perhaps that might cause the current move to complete.
                          • hpizundefined
                            hpiz @dc42
                            @dc42 From my experience, it would seem it is just continuing with the moves it was already performing. For example, I don't really see any behavior difference between the following two GCode jobs...
                            G90
                            G21
                            G1 Y500 Z100 F4000
                            G1 Y600 Z0 F4000
                            G1 Y500 Z100 F4000
                            G1 Y600 Z0 F4000
                            G1 Y500 Z100 F4000
                            G1 Y600 Z0 F4000
                            M112
                            G1 Y500 Z100 F4000
                            G1 Y600 Z0 F4000
                            G1 Y500 Z100 F4000
                            G1 Y600 Z0 F4000
                            vs
                            G90
                            G21
                            G1 Y500 Z100 F4000
                            G1 Y600 Z0 F4000
                            G1 Y500 Z100 F4000
                            G1 Y600 Z0 F4000
                            G1 Y500 Z100 F4000
                            G1 Y600 Z0 F4000
                            M112
                            The M112 seems to be executed as it's read into the buffer, around the second movement loop, it then tries to complete the third loop after a brief stop (0.25 secs), nothing after M112 seems to ever try to execute, so that's good. Not sure if this matters, but the continued moves seem to move beyond where they should, which in my mind could only happen if more steps are sent than should. I'm gonna test my Duet 2 ethernet today (will post back maybe 2 hours from now) and see if it's got the same step continuation.
                            As far as the code goes, I wish I could help more but I mostly make websites in C#. Though, I will keep trying.
                            • hpizundefined
                              hpiz @dc42
                              @dc42 My Duet 2 does not produce pulses after M112 running 3.4.6
                              Note: The scope is in trigger mode
                              Duet2: M112 in job
                              Duet2: Using DWC Endstop
                                Thanks all, I'll be away at FormNext for a week but I'll look into this as a matter of urgency when I return.
                                  timschneider @dc42
                                  @dc42 we have to thank you for your very fast response and in the middle of the preperation for the Formnext!
                                  @dc42 said in Movement after M112 E-Stop!:
                                  To check that, I did another test. Setup as above with SBC. Jobfile the following:
                                  G90
                                  G21
                                  G1 Y0 F60
                                  G1 Y1 F60
                                  G1 Y0 F60
                                  G1 Y1 F60
                                  G1 Y0 F60
                                  G1 Y1 F60
                                  G1 Y0 F60
                                  G1 Y1 F60
                                  G1 Y0 F60
                                  G1 Y1 F60
                                  G1 Y0 F60
                                  G1 Y1 F60
                                  G1 Y0 F60
                                  G1 Y1 F60
                                  G1 Y0 F60
                                  G1 Y1 F60
                                  So every move is around 1 sec (F60 is within the jerk so i guess there is not much acceleration). Based on that, the delay should be less than 1-1.5s, but in fact, it is again around 3.5s (3.46s) as in all the samples above, regardless of the movement length and speed.
                                  So from my understanding, it is not only the remainder of the current move.
                                    @timschneider
                                    I think the problem is in the IterateDrivers Function in the Platform.cpp
                                    the following code snippets are based on the 3.4-dev branch
                                    The else if branch will disable all extruders, but the problem is, that it will start working from GetTotalAxes() to MaxAxesPlusExtruders. But there are only MaxExtruders allowed.
                                    That means in numbers for the MB6XD
                                    MaxAxesPlusExtruders = 25
                                    GetTotalAxes() = 3 in this case XYZ
                                    MaxExtruders  = 16
                                    So from 3 - 24 it will work with the else if branch
                                    size_t LogicalDriveToExtruder(size_t drive) noexcept { return MaxAxesPlusExtruders - 1 - drive; }
                                    25 - 1 - 3 = 21
                                    25 - 1 - 4 = 20
                                    25 - 1 - 24 = 0
                                    DriverId extruderDrivers[MaxExtruders] -> array of 16 elements
                                    so the following code will read some random data for the elements from 3 - 8
                                    const DriverId id = extruderDrivers[LogicalDriveToExtruder(axisOrExtruder)];
                                    and this code will sometimes end up in the remoteFunc e.g. in our case send can message and wait for a reply
                                    if (id.IsLocal())
                                    	localFunc(id.localDriver);
                                    else
                                    	remoteFunc(id);
                                    but there will be no reply and this will delay the e-stop (stop step generation and clear the movement system) around 3 - 3.5 sec
                                    I've changed the IterateDrivers the following:
                                    // Function to identify and iterate through all drivers attached to an axis or extruder
                                    void Platform::IterateDrivers(size_t axisOrExtruder, function_ref<void(uint8_t)> localFunc, function_ref<void(DriverId)> remoteFunc) noexcept
                                    	if (axisOrExtruder < reprap.GetGCodes().GetTotalAxes())
                                    		for (size_t i = 0; i < axisDrivers[axisOrExtruder].numDrivers; ++i)
                                    			const DriverId id = axisDrivers[axisOrExtruder].driverNumbers[i];
                                    			if (id.IsLocal())
                                    			else
                                    				remoteFunc(id);
                                    	else if (axisOrExtruder >= (MaxAxesPlusExtruders - MaxExtruders) && axisOrExtruder < MaxAxesPlusExtruders)
                                    		if (id.IsLocal())
                                    		else
                                    			remoteFunc(id);
                                    But this will only address the delay - I think this is a good time to add a secondary layer to prevent the EnableSignale from getting high again. (Because of the delay, prepare moves where re-enableing the drivers again)
                                    platform.cpp
                                     src/Platform/Platform.cpp | 7 ++++---
                                     1 file changed, 4 insertions(+), 3 deletions(-)
                                    diff --git a/src/Platform/Platform.cpp b/src/Platform/Platform.cpp
                                    index c8f7793c..fdd6f2d3 100644
                                    --- a/src/Platform/Platform.cpp
                                    +++ b/src/Platform/Platform.cpp
                                    @@ -424,7 +424,7 @@ Platform::Platform() noexcept :
                                     #if HAS_MASS_STORAGE
                                     	logger(nullptr),
                                     #endif
                                    -	board(DEFAULT_BOARD_TYPE), active(false), errorCodeBits(0),
                                    +	board(DEFAULT_BOARD_TYPE), active(false), preventDriverEnable(true), errorCodeBits(0),
                                     	nextDriveToPoll(0),
                                     	lastFanCheckTime(0),
                                     #if SUPPORT_PANELDUE_FLASH
                                    @@ -861,6 +861,7 @@ void Platform::Init() noexcept
                                     	DuetExpansion::DueXnTaskInit();								// must initialise interrupt priorities before calling this
                                     #endif
                                     	active = true;
                                    +	preventDriverEnable = false;
                                     // Reset the min and max recorded voltages to the current values
                                    @@ -2439,7 +2440,7 @@ void Platform::IterateDrivers(size_t axisOrExtruder, function_ref<void(uint8_t)>
                                    -	else if (axisOrExtruder < MaxAxesPlusExtruders)
                                    +	else if (axisOrExtruder >= (MaxAxesPlusExtruders - MaxExtruders) && axisOrExtruder < MaxAxesPlusExtruders)
                                     		if (id.IsLocal())
                                    @@ -2572,7 +2573,7 @@ void Platform::DisableOneLocalDriver(size_t driver) noexcept
                                     // Enable the local drivers for a drive. Must not be called from an ISR, or with interrupts disabled.
                                     void Platform::EnableDrivers(size_t axisOrExtruder, bool unconditional) noexcept
                                    -	if (unconditional || driverState[axisOrExtruder] != DriverStatus::enabled)
                                    +	if (unconditional || (driverState[axisOrExtruder] != DriverStatus::enabled && !preventDriverEnable))
                                     		driverState[axisOrExtruder] = DriverStatus::enabled;
                                     		const float requiredCurrent = motorCurrents[axisOrExtruder] * motorCurrentFraction[axisOrExtruder];
                                    platform.h
                                     src/Platform/Platform.h | 5 ++++-
                                     1 file changed, 4 insertions(+), 1 deletion(-)
                                    diff --git a/src/Platform/Platform.h b/src/Platform/Platform.h
                                    index c3f006b4..4f2b2196 100644
                                    --- a/src/Platform/Platform.h
                                    +++ b/src/Platform/Platform.h
                                    @@ -528,7 +528,7 @@ public:
                                     	uint32_t GetSteppingEnabledDrivers() const noexcept { return steppingEnabledDriversBitmap; }
                                     	void DisableSteppingDriver(uint8_t driver) noexcept { steppingEnabledDriversBitmap &= ~StepPins::CalcDriverBitmap(driver); }
                                    -	void EnableAllSteppingDrivers() noexcept { steppingEnabledDriversBitmap = 0xFFFFFFFFu; }
                                    +	void EnableAllSteppingDrivers() noexcept { if (!preventDriverEnable) { steppingEnabledDriversBitmap = 0xFFFFFFFFu; } }
                                     #ifdef DUET3_MB6XD
                                     	bool HasDriverError(size_t driver) const noexcept;
                                    @@ -643,6 +643,8 @@ public:
                                     	const GpInputPort& GetGpInPort(size_t gpinPortNumber) const noexcept
                                     		pre(gpinPortNumber < MaxGpInPorts) 	{ return gpinPorts[gpinPortNumber]; }
                                    +	void SetPreventDriverEnable() noexcept { preventDriverEnable = true; }
                                     #if MCU_HAS_UNIQUE_ID
                                     	const UniqueId& GetUniqueId() const noexcept { return uniqueId; }
                                     	uint32_t Random() noexcept;
                                    @@ -742,6 +744,7 @@ private:
                                     #endif
                                     	bool active;
                                    +	bool preventDriverEnable;
                                     	uint32_t errorCodeBits;
                                     	void InitialiseInterrupts() noexcept;
                                    RepRap.cpp
                                     src/Platform/RepRap.cpp | 1 +
                                     1 file changed, 1 insertion(+)
                                    diff --git a/src/Platform/RepRap.cpp b/src/Platform/RepRap.cpp
                                    index 5d5a28aa..168619c4 100644
                                    --- a/src/Platform/RepRap.cpp
                                    +++ b/src/Platform/RepRap.cpp
                                    @@ -1004,6 +1004,7 @@ void RepRap::EmergencyStop() noexcept
                                     	else
                                     #endif
                                    +		platform->SetPreventDriverEnable(); // prevent any conditional call to EnableDrivers
                                     		platform->DisableAllDrivers();				// disable all local and remote drivers - need to do this to ensure that any motor brakes are re-engaged
                                     		switch (gCodes->GetMachineType())
                                    With these changes, there will be no delay at all after the estop is pressed in DWC and processed by RRF.
                                    timschneiderundefined dc42undefined 2 Replies Last reply Reply Quote 2
                                      @hpiz so I've recompiled a clean version of the 3.4-dev branch with only the IterateDrivers fix pull request on github.
                                      This is not a production version and only for testing purpose, it is based on the current 3.4-dev branch and only for MB6XD. Use on your own risk.
                                      Duet3Firmware_MB6XD.bin
                                      Maybe you can try, and we can see if this will fix the problem for you too.
                                        @dc42 the missing MB6HC test.
                                        MB6HC in standalone mode
                                        following config
                                        ; Enable network
                                        M552 P0.0.0.0 S1
                                        ;CNC Mode
                                        M453                            ; Select CNC device mode
                                        M669 K0 S2 T1
                                        M584 X5 Y0.0:0.1:0.2:0.3 Z4             ; set drive mapping
                                        M92 X160.00 Y320.00 Z640.00     ; set steps per mm
                                        M566 X1800.00 Y180.00 Z120.00     ; set maximum instantaneous speed changes (mm/min)
                                        M203 X15000.00 Y12000.00 Z5000.00 I5  ; set maximum speeds (mm/min)
                                        M201 X400.00 Y200.00 Z200.00        ; set accelerations (mm/s^2)
                                        ;M564 H0                         ; Allow stepper movement before homing
                                        M208 X600 Y1200 Z170 S0         ; set axis maxima
                                        ;Machine Initialization
                                        ;M18                          ; disable all steppers
                                        ;M17                          ; enable z stepper so it doesn't fall
                                        no delay.
                                        with the following config (added stepper driver timings)
                                        ; Enable network
                                        M552 P0.0.0.0 S1
                                        ;CNC Mode
                                        M669 K0 S2 T1
                                        M569 R0 P0 S0 T3:3:6:0
                                        M569 R0 P1 S0 T3:3:6:0
                                        M569 R0 P2 S0 T3:3:6:0
                                        M569 R0 P3 S0 T3:3:6:0
                                        M569 R0 P4 S0 T3:3:6:0
                                        M569 R0 P5 S0 T3:3:6:0
                                        the delay is there again. I think it will fill the following struct (slowDriversBitmap and slowDriverStepTimingClocks), and will cause IterateDrivers to send can messages.
                                        	DriverId extruderDrivers[MaxExtruders];					// the driver number assigned to each extruder
                                        #ifdef DUET3_MB6XD
                                        ... disabled for MB6HC
                                        #else
                                        	uint32_t slowDriversBitmap;								// bitmap of driver port bits that need extended step pulse timing
                                        	uint32_t slowDriverStepTimingClocks[4];					// minimum step high, step low, dir setup and dir hold timing for slow drivers
                                        M112 in job file, because there is no enable signal turned on and off for the interal / smart drivers.
                                        jobfile
                                        G90
                                        G21
                                        G1 Y0 F60
                                        G1 Y3 F60
                                        G1 Y0 F60
                                        G1 Y3 F60
                                        M112
                                        G1 Y0 F60
                                        G1 Y1 F60
                                        G1 Y0 F60
                                        G1 Y1 F60
                                        G1 Y0 F60
                                        G1 Y1 F60
                                        G1 Y0 F60
                                        G1 Y1 F60
                                        G1 Y0 F60
                                        G1 Y1 F60
                                        G1 Y0 F60
                                        G1 Y1 F60
                                        without driver timings:
                                        with driver timings (same job file):
                                        • hpizundefined
                                          hpiz @timschneider
                                          @timschneider said in Movement after M112 E-Stop!:
                                          You sir, are a wizard. I spent probably 2 hours looking at the code and IterateDrives was not something I even looked at, I kept going back to the DisableAllDrivers in the platform, which I guess was in the ballpark for the enable signal, but I was mostly looking for step loop hangs.
                                          I loaded up your firmware and after 6 tests (M112 in job, driver error, and DWC EStop) I was unable to get any motion after M112. Bravo, I think I'm gonna keep your firmware until dc42 takes the pull request and releases. I still have a lot of work to do on my machine, although I've taken like a two week break.
                                            dc42 administrators @timschneider
                                            @timschneider thanks for your detailed analysis!
                                            I think the correct fix to IterateDrivers is to change the else if condition to this:
                                            else if (axisOrExtruder < MaxAxesPlusExtruders && LogicalDriveToExtruder(axisOrExtruder) < reprap.GetGCodes().GetNumExtruders())
                                            This will ensure that no action is taken if IterateDrivers is called with a logical drive number that is too high to be an axis but too low to be an extruder.
                                            I agree that an additional layer of protection is needed to guard against CAN delays so I will review your solution, although I think there may already be an 'active' flag that we could use for this purpose.
                                            EDIT: I've reviewed your code that add the preventDriverEnable flag and I don't think it will have the desired effect; because function EnableAllSteppingDrivers doesn't actually enable drivers, it just clears the "don't step" flag that gets set during homing of an axis that has multiple motors with separate endstops. So instead I've changed Move::MoveLoop to self-terminate the Move task when emergency stop has been commanded, thereby preventing further calls to DDA::Prepare.
                                            These changes are now committed to the 3.5-dev branch of RRF. Please test them on your machine.
                                            timschneiderundefined 1 Reply Last reply Reply Quote 1
