    reference the X-axis on both rails
    Using Duet Controllers
    2.5k
    • fcwiltundefined
      fcwilt @axiom
      @axiom
      Take a look at this quick-and-dirty video of my 3 Z axis printer with auto-bed leveling.
      3 Z Steppers Level Demo
      I have intentionally put the bed way out of level for this video to demonstrate, what are to me, the benefits of Z axis endstop sensors.
      I home the Z axis as you would the X or Y axis relying on the endstop sensors to stop the motion of each of the Z axis steppers motors.
      The endstop sensors are precisely adjustable and I adjust them (a bit of trial-and-error) so homing the Z axis gets the bed very close to level.
      Then I use the auto bed leveling feature of the firmware (reference G32) to get the bed as level as possible.
      Now you are not likely to have the bed get as far out of level as in this video but it does show that the Z axis endstop sensors make getting the bed close to level quick and easy.
      You could have trouble doing that with a Z probe alone.
      Just my opinion - your mileage may vary.
      axiomundefined 2 Replies Last reply Reply Quote 0
      • axiomundefined
        axiom @fcwilt
        @fcwilt That looks very good....my question now is how I have to declare the probe for homing (axes) in the code in comparison to the sensor for the mesh bed compensation on the head...can you help me?
        This is necessary for me because my bed is 800 x 700mm and the glass plate has 1.5mm fluctuations
        • axiomundefined
          axiom @fcwilt
          @fcwilt Do you also have a link to the sensors you used?
          • fcwiltundefined
            fcwilt @axiom
            @axiom
            The Z probe is configured (reference M950, M558 and G31) just one way for all uses which are:
            • setting the Z=0 Datum
            • auto leveling the bed
            • creating the height map
            There are of course other settings that need to be made for:
            • auto leveling the bed - reference M671 and G30 P#
            • creating the height map - reference M557 and G29
            I can help with the details as needed.
            The sensors I used for the Z axis endstops where typical slotted "beam break" detectors:
            These are like the ones I use but, as typical with Amazon, the specific ones I order are "no longer available":
            Optical Limit Sensors
            I would avoid this style as the connector on the same side of the board as the slotted sensor makes them a bit harder to mount:
            Another style
            Again I can help with the details when you have need.
            • axiomundefined
              axiom @fcwilt
              @fcwilt ;That sounds super interesting! Your “Optical Limit Sensors” are available from German Amazon and I have ordered them and they will arrive tomorrow.
              Then I will replace the mechanical endstops (2 pieces on the x-axis and 1 piece on the y-axis) and try to adjust them and of course first construct brackets for them. To test the z-stop variant (I can't order the expansion board until next week) I would simply connect a sensor. I currently use the capacitive sensor both as an endstop and for bed leveling (G29). If I now connect the optical sensor for the Z axis, I only want to use the capacitive sensor for compensation (G29). So what do I need to change in my code? Here is my current code without the optical sensors:
              Endstops
              M574 X1 S1 P"xstop + e0stop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
              M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
              ; Z-Probe two of them
              M558 K0 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds
              M558 K1 P8 A2 S0.2 C"!zstop" H5 F80 T3000
              G31 P1000 K0 X-1 Y-61 Z0.484 ; set Z probe trigger value, offset and trigger height
              G31 P1000 K1 X0 Y0 Z12.664 ; Second Z-offset
              M557 X0:735 Y-27:573 S35 ; define mesh grid
              • axiomundefined
                axiom @fcwilt
                @fcwilt I can first comment out the second Z-offset in the code "K1"...that is for a later project to use a puck instead of a sheet of paper and is not relevant at the moment...so I also use the z-stop sensor Insert "!zstop" into C
                • fcwiltundefined
                  fcwilt @axiom
                  @axiom
                  As previously posted you have to have a M574 command for all 4 Z endstop sensors:
                  M574 Z1 S1 P"pin_name_for_z_sensor_1 + pin_name_for_z_sensor_2 + pin_name_for_z_sensor_3 + pin_name_for_z_sensor_4"
                  Remember that the order of the pin names must match the order of the steppers in your M584:
                  So lets assume your drive assignments for the Z steppers is like this:
                  M569 P5  S0       ; drive  5 - normal - Z at left front
                  M569 P6  S0       ; drive  6 - normal - Z at left rear
                  M569 P7  S1       ; drive  7 - normal - Z at right rear
                  M569 P8  S1       ; drive  8 - normal - Z at right front
                  M584 Z5:6:7:8    ; set what motors do what
                  And let's also assume sensor 1 will be for drive 5, sensor 2 for drive 6, sensor 3 for drive 7 and sensor 4 for drive 8.
                  The M574 will be as above
                  If the order is not correct the sensor activated will stop the wrong motor.
                  It is easy to check once everything is wired up and configured, asumming the bed is not yet mounted and each Z axis is free to move independently from all the others.
                  • Jog Z down near limit of travel
                  • Start a Z homing move at a nice slow speed
                  • Trigger by hand each sensor and verify that it stops the correct stepper
                  axiomundefined 1 Reply Last reply Reply Quote 1
                  • axiomundefined
                    axiom @fcwilt
                    @fcwilt I understand that, this is for the Enstops...but what do I write for the capacitive sensor for the Meshbed compensation?
                    • fcwiltundefined
                      fcwilt @axiom
                      @axiom
                      As mentioned the configuration of the Z probe does not change.
                      What you have to do is include the commands that tell the firmware how to create the height map
                      M557
                      Xaaa:bbb : Minimum and maximum X coordinates to probe
                      Yaaa:bbb : Minimum and maximum Y coordinates to probe
                      Pxx:yy : Number of points on X axis, number of points on Y axis
                      So for example let's say the min/max limits of your bed on the X axis is -150 to 150 and on the Y axis -100 to 100. I always place X=0 and Y=0 at the center of the bed so the min/max limits are as you see.
                      Now you have to determine where in that area your probe can reach - this is determined by the X and Y offsets of the probe and the possible range of motion outside of the min/max limits.
                      So let's assume your probe has an X offset of 0 and a Y offset of +25.
                      Let us also assume your probe can reach from -150 to +150 on the X axis and from -90 to +100 on the Y axis.
                      You could have an M557 like this:
                      M557 X-150:150 Y-90:150 P20:15
                      Which means the mesh would have 20 points along the X axis and 15 points along the Y axis, for a total of 300 points. And the mesh would span from -150 to 150 on the X axis and from -90 to +100 on the Y axis.
                      So to create the height map you would:
                      • Move to Z=5
                      • Move the probe to the center of the bed, taking into account the probe offset in Y
                      • Execute a G30 to set the Z=0 Datum
                      • Execute a G29 S0 to probe the bed and create the height map
                      Feel free to ask any questions.
                      • axiomundefined
                        axiom @fcwilt
                        @fcwilt Can I also place the Z-probe 10mm below the nozzle and then still move the bed closer to the head...if so, where and how can I enter this in the code?
                        • axiomundefined
                          axiom @fcwilt
                          @fcwilt Sorry, I don't mean the probe but the endstops
                          • fcwiltundefined
                            fcwilt @axiom
                            @axiom
                            Yes - the "flag" that you fashion to slide into the slot and break the beam can travel beyond the slot if needed.
                            You want the position of the sensors to be easily adjustable so you can get them in the same position - or as near as possible.
                            When you execute a G1 move with the H1 parameter the movement stops when the associated endstop sensor is triggered and the logical position of the axis is set to the min/max value as specified in M208. The M574 command that configures the endstop specifies if it is at the "high" end or the low "end" of the axis, thus determining if the max value from M208 is used or the min value.
                            Your Z min value is likely to be 0. But if your endstops trigger at, say, 10mm away from 0, you have a disconnect between the physical Z position (-10) and the logical Z position (0).
                            That is easily dealt with. After the G1 H1 command that does the homing just add a G92 Z### where ### is the actual physical position on the Z axis (-10 in the example above). Now the logical and physical positions will be in sync at -10 and then you can move Z to physical 0.
                            Hope that clears things up.
                            axiomundefined 1 Reply Last reply Reply Quote 0
                            • axiomundefined
                              axiom @fcwilt
                              @fcwilt So I connected the probe to test it and tried it out successfully.
                              The problem is that the Z axis does not stop when the end stop is triggered manually but only when the probe is triggered. But I would like to use the end stops for stopping and the probe only for mesh bed compensation. Here my code:
                              M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                              M558 K0 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds (Kapazitiver Sensor)
                              • fcwiltundefined
                                fcwilt @axiom
                                @axiom
                                Do you have anything else in the config.g file that is already using the "zstop" input?
                                Errors like that don't show up when you boot (or re-boot) the printer.
                                Once up and running you can execute from the DWC console M98 P"config.g" and you may see error messages.
                                And remember to use G32 to do auto bed leveling you will need 4 Z axis endstops and thus 4 unused inputs.
                                • axiomundefined
                                  axiom @fcwilt
                                  @fcwilt said in reference the X-axis on both rails:
                                  M98 P"config.g"
                                  I don't have any error messages. However, it doesn't stop at the z endstop but only at the probe... I'm happy with it. It is clear to me that I will need 4 endstops and 4 motor drivers later. This is about the test...but my Z-endstop should work here too. Here is the whole code again
                                  ; Configuration file for Duet WiFi (firmware version 3.3)
                                  ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sun May 28 2023 15:23:44 GMT+0200 (Mitteleuropäische Sommerzeit)
                                  M550 P"DUKA1300" ; set printer name
                                  M552 S1 ; enable network
                                  M586 P0 S1 ; enable HTTP
                                  M586 P1 S1 ; enable FTP
                                  M586 P2 S1 ; enable Telnet
                                  M569 P4 S0 ; physical drive 3 goes forwards
                                  M584 X0:4 Y1 Z2 E3 ; set drive mapping
                                  M92 X80.00 Y80.00 Z640 E322.58 ; set steps per mm
                                  M566 X900.00 Y900.00 Z100.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                                  M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
                                  M201 X500.00 Y500.00 Z40.00 E250.00 ; set accelerations (mm/s^2)
                                  M906 X1800 Y1800 Z1800 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
                                  M84 S30 ; Set idle timeout
                                  M208 X100 Y0 Z0 S1 ; set axis minima
                                  M208 X750 Y640 Z1220 S0 ; set axis maxima
                                  M574 Z1 S1 P"e1-stop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                                  M558 K0 P5 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds (Kapazitiver Sensor)
                                  ; Bed
                                  M307 H0 R0.283 K0.463:0.000 D7.17 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit
                                  M143 H0 S280 ; set temperature limit for heater 0 to 120C
                                  ;Hotend
                                  M307 H1 R1.797 K0.742:0.000 D7.57 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit
                                  M143 H1 S400 ; set temperature limit for heater 1 to 400C
                                  M950 F2 C"fan2" Q350 ; create fan 2 on pin fan2 and set its frequency
                                  M106 P2 S1 H1 T60 ; set fan 2 value. Thermostatic control is turned on
                                  M563 P0 D0 H1 F0 ; define tool 1
                                  G10 P0 X0 Y0 Z0 ; set tool 1 axis offsets
                                  G10 P0 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                                  ; Filamentsensor
                                  ;M591 D0 P1 C"e1-stop" S1 ;R40:120 E3.0 S1 Filament Sensor
                                  ;Auto Z-Offset
                                  M501
                                  • fcwiltundefined
                                    fcwilt @axiom
                                    @axiom
                                    I don't see anything there in the config.g.
                                    When testing the Z endstop you are doing a G1 H1 Znnn move?
                                    If the endstop switch is not working then that would seem to leave only a hardware problem - defective switch, incorrect wiring.
                                    You are using firmware 3.3.
                                    That has the Object Model Browser doesn't it?
                                    If so, you can use that to look at the Z endstop state and see if it changes with the state of the Z endstop switch.
                                    axiomundefined 3 Replies Last reply Reply Quote 0
                                    • axiomundefined
                                      axiom @fcwilt
                                      @fcwilt I test the endstop with the homing function
                                      • axiomundefined
                                        axiom @fcwilt
                                        @fcwilt I tried the endstop before on the y-axis and it worked there...so the wiring/plugs and the function of the endstop are no longer necessary
                                        • axiomundefined
                                          axiom @fcwilt
                                          @fcwilt Ok...with G1 H1 Z0 it works...homing is probably reserved for the probe
                                          • fcwiltundefined
                                            fcwilt @axiom
                                            @axiom said in reference the X-axis on both rails:
                                            When testing it is usually best to use the smallest bit of code that will do the job, thus the question about G1 H1.
                                            Please post your homing files.
