    reference the X-axis on both rails
    Using Duet Controllers
    2.5k
    • axiomundefined
      axiom @fcwilt
      @fcwilt I can first comment out the second Z-offset in the code "K1"...that is for a later project to use a puck instead of a sheet of paper and is not relevant at the moment...so I also use the z-stop sensor Insert "!zstop" into C
      • fcwiltundefined
        fcwilt @axiom
        @axiom
        As previously posted you have to have a M574 command for all 4 Z endstop sensors:
        M574 Z1 S1 P"pin_name_for_z_sensor_1 + pin_name_for_z_sensor_2 + pin_name_for_z_sensor_3 + pin_name_for_z_sensor_4"
        Remember that the order of the pin names must match the order of the steppers in your M584:
        So lets assume your drive assignments for the Z steppers is like this:
        M569 P5  S0       ; drive  5 - normal - Z at left front
        M569 P6  S0       ; drive  6 - normal - Z at left rear
        M569 P7  S1       ; drive  7 - normal - Z at right rear
        M569 P8  S1       ; drive  8 - normal - Z at right front
        M584 Z5:6:7:8    ; set what motors do what
        And let's also assume sensor 1 will be for drive 5, sensor 2 for drive 6, sensor 3 for drive 7 and sensor 4 for drive 8.
        The M574 will be as above
        If the order is not correct the sensor activated will stop the wrong motor.
        It is easy to check once everything is wired up and configured, asumming the bed is not yet mounted and each Z axis is free to move independently from all the others.
        • Jog Z down near limit of travel
        • Start a Z homing move at a nice slow speed
        • Trigger by hand each sensor and verify that it stops the correct stepper
        axiomundefined 1 Reply Last reply Reply Quote 1
        • axiomundefined
          axiom @fcwilt
          @fcwilt I understand that, this is for the Enstops...but what do I write for the capacitive sensor for the Meshbed compensation?
          • fcwiltundefined
            fcwilt @axiom
            @axiom
            As mentioned the configuration of the Z probe does not change.
            What you have to do is include the commands that tell the firmware how to create the height map
            M557
            Xaaa:bbb : Minimum and maximum X coordinates to probe
            Yaaa:bbb : Minimum and maximum Y coordinates to probe
            Pxx:yy : Number of points on X axis, number of points on Y axis
            So for example let's say the min/max limits of your bed on the X axis is -150 to 150 and on the Y axis -100 to 100. I always place X=0 and Y=0 at the center of the bed so the min/max limits are as you see.
            Now you have to determine where in that area your probe can reach - this is determined by the X and Y offsets of the probe and the possible range of motion outside of the min/max limits.
            So let's assume your probe has an X offset of 0 and a Y offset of +25.
            Let us also assume your probe can reach from -150 to +150 on the X axis and from -90 to +100 on the Y axis.
            You could have an M557 like this:
            M557 X-150:150 Y-90:150 P20:15
            Which means the mesh would have 20 points along the X axis and 15 points along the Y axis, for a total of 300 points. And the mesh would span from -150 to 150 on the X axis and from -90 to +100 on the Y axis.
            So to create the height map you would:
            • Move to Z=5
            • Move the probe to the center of the bed, taking into account the probe offset in Y
            • Execute a G30 to set the Z=0 Datum
            • Execute a G29 S0 to probe the bed and create the height map
            Feel free to ask any questions.
            axiomundefined 2 Replies Last reply Reply Quote 0
            • axiomundefined
              axiom @fcwilt
              @fcwilt Can I also place the Z-probe 10mm below the nozzle and then still move the bed closer to the head...if so, where and how can I enter this in the code?
              • axiomundefined
                axiom @fcwilt
                @fcwilt Sorry, I don't mean the probe but the endstops
                • fcwiltundefined
                  fcwilt @axiom
                  @axiom
                  Yes - the "flag" that you fashion to slide into the slot and break the beam can travel beyond the slot if needed.
                  You want the position of the sensors to be easily adjustable so you can get them in the same position - or as near as possible.
                  When you execute a G1 move with the H1 parameter the movement stops when the associated endstop sensor is triggered and the logical position of the axis is set to the min/max value as specified in M208. The M574 command that configures the endstop specifies if it is at the "high" end or the low "end" of the axis, thus determining if the max value from M208 is used or the min value.
                  Your Z min value is likely to be 0. But if your endstops trigger at, say, 10mm away from 0, you have a disconnect between the physical Z position (-10) and the logical Z position (0).
                  That is easily dealt with. After the G1 H1 command that does the homing just add a G92 Z### where ### is the actual physical position on the Z axis (-10 in the example above). Now the logical and physical positions will be in sync at -10 and then you can move Z to physical 0.
                  Hope that clears things up.
                  axiomundefined 1 Reply Last reply Reply Quote 0
                  • axiomundefined
                    axiom @fcwilt
                    @fcwilt So I connected the probe to test it and tried it out successfully.
                    The problem is that the Z axis does not stop when the end stop is triggered manually but only when the probe is triggered. But I would like to use the end stops for stopping and the probe only for mesh bed compensation. Here my code:
                    M574 X1 S1 P"xstop + e0stop" ; configure switch-type (e.g. microswitch) endstop for low end on X via pin xstop
                    M574 Y1 S1 P"ystop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                    M574 Z1 S1 P"zstop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                    M558 K0 P1 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds (Kapazitiver Sensor)
                    M557 X0:735 Y-27:573 S35 ; define mesh grid
                    • fcwiltundefined
                      fcwilt @axiom
                      @axiom
                      Do you have anything else in the config.g file that is already using the "zstop" input?
                      Errors like that don't show up when you boot (or re-boot) the printer.
                      Once up and running you can execute from the DWC console M98 P"config.g" and you may see error messages.
                      And remember to use G32 to do auto bed leveling you will need 4 Z axis endstops and thus 4 unused inputs.
                      • axiomundefined
                        axiom @fcwilt
                        @fcwilt said in reference the X-axis on both rails:
                        M98 P"config.g"
                        I don't have any error messages. However, it doesn't stop at the z endstop but only at the probe... I'm happy with it. It is clear to me that I will need 4 endstops and 4 motor drivers later. This is about the test...but my Z-endstop should work here too. Here is the whole code again
                        ; Configuration file for Duet WiFi (firmware version 3.3)
                        ; generated by RepRapFirmware Configuration Tool v3.3.16 on Sun May 28 2023 15:23:44 GMT+0200 (Mitteleuropäische Sommerzeit)
                        M550 P"DUKA1300" ; set printer name
                        M552 S1 ; enable network
                        M586 P0 S1 ; enable HTTP
                        M586 P1 S1 ; enable FTP
                        M586 P2 S1 ; enable Telnet
                        M569 P4 S0 ; physical drive 3 goes forwards
                        M584 X0:4 Y1 Z2 E3 ; set drive mapping
                        M92 X80.00 Y80.00 Z640 E322.58 ; set steps per mm
                        M566 X900.00 Y900.00 Z100.00 E120.00 ; set maximum instantaneous speed changes (mm/min)
                        M203 X6000.00 Y6000.00 Z300.00 E1200.00 ; set maximum speeds (mm/min)
                        M201 X500.00 Y500.00 Z40.00 E250.00 ; set accelerations (mm/s^2)
                        M906 X1800 Y1800 Z1800 E1600 I30 ; set motor currents (mA) and motor idle factor in per cent
                        M84 S30 ; Set idle timeout
                        M208 X100 Y0 Z0 S1 ; set axis minima
                        M208 X750 Y640 Z1220 S0 ; set axis maxima
                        M574 Z1 S1 P"e1-stop" ; configure switch-type (e.g. microswitch) endstop for low end on Y via pin ystop
                        M558 K0 P5 C"!zprobe.in" H5 F120 T6000 ; set Z probe type to unmodulated and the dive height + speeds (Kapazitiver Sensor)
                        ; Bed
                        M307 H0 R0.283 K0.463:0.000 D7.17 E1.35 S1.00 B0 ; enable bang-bang mode for the bed heater and set PWM limit
                        M143 H0 S280 ; set temperature limit for heater 0 to 120C
                        ;Hotend
                        M307 H1 R1.797 K0.742:0.000 D7.57 E1.35 S1.00 B0 V23.8 ; disable bang-bang mode for heater and set PWM limit
                        M143 H1 S400 ; set temperature limit for heater 1 to 400C
                        M950 F2 C"fan2" Q350 ; create fan 2 on pin fan2 and set its frequency
                        M106 P2 S1 H1 T60 ; set fan 2 value. Thermostatic control is turned on
                        M563 P0 D0 H1 F0 ; define tool 1
                        G10 P0 X0 Y0 Z0 ; set tool 1 axis offsets
                        G10 P0 R0 S0 ; set initial tool 1 active and standby temperatures to 0C
                        ; Filamentsensor
                        ;M591 D0 P1 C"e1-stop" S1 ;R40:120 E3.0 S1 Filament Sensor
                        ;Auto Z-Offset
                        M501
                        • fcwiltundefined
                          fcwilt @axiom
                          @axiom
                          I don't see anything there in the config.g.
                          When testing the Z endstop you are doing a G1 H1 Znnn move?
                          If the endstop switch is not working then that would seem to leave only a hardware problem - defective switch, incorrect wiring.
                          You are using firmware 3.3.
                          That has the Object Model Browser doesn't it?
                          If so, you can use that to look at the Z endstop state and see if it changes with the state of the Z endstop switch.
                          axiomundefined 3 Replies Last reply Reply Quote 0
                          • axiomundefined
                            axiom @fcwilt
                            @fcwilt I test the endstop with the homing function
                            • axiomundefined
                              axiom @fcwilt
                              @fcwilt I tried the endstop before on the y-axis and it worked there...so the wiring/plugs and the function of the endstop are no longer necessary
                              • axiomundefined
                                axiom @fcwilt
                                @fcwilt Ok...with G1 H1 Z0 it works...homing is probably reserved for the probe
                                • fcwiltundefined
                                  fcwilt @axiom
                                  @axiom said in reference the X-axis on both rails:
                                  When testing it is usually best to use the smallest bit of code that will do the job, thus the question about G1 H1.
                                  Please post your homing files.
                                  • axiomundefined
                                    axiom @fcwilt
                                    @fcwilt Ok here they are:
                                    ; homeall.g
                                    ; called to home all axes
                                    G91 ; relative positioning
                                    G1 H1 X-755 Y-643 F1500 ; move quickly to X and Y axis endstops and stop there (first pass)
                                    G1 H2 X5 Y5 F6000 ; go back a few mm
                                    G1 H1 X-755 Y-643 F360 ; move slowly to X and Y axis endstops once more (second pass)
                                    G90 ; absolute positioning
                                    G1 X10 Y10 F6000 ; go to first bed probe point and home Z
                                    ;G91 ; relative positioning
                                    ;G90 ; absolute positioning
                                    ; homex.g
                                    ; called to home the X axis
                                    G1 H1 X-755 F1500 ; move quickly to X axis endstop and stop there (first pass)
                                    G1 H2 X5 F6000 ; go back a few mm
                                    G1 H1 X-755 F360 ; move slowly to X axis endstop once more (second pass)
                                    G1 H2 Z-5 F6000 ; lower Z again
                                    ; homey.g
                                    ; called to home the Y axis
                                    G1 H1 Y-643 F1500 ; move quickly to Y axis endstop and stop there (first pass)
                                    G1 H2 Y5 F6000 ; go back a few mm
                                    G1 H1 Y-643 F360 ; move slowly to Y axis endstop once more (second pass)
                                    ; homez.g
                                    ; called to home the Z axis
                                    G1 X1 Y61 F6000 ; go to first probe point
                                    • fcwiltundefined
                                      fcwilt @axiom
                                      @axiom
                                      As I expected homing of Z is being done with the probe.
                                      Once you have the Z endstop sensor (or multiple sensors) in place you can use them instead of the Z probe to home the Z axis.
                                      It will make the homing a bit simpler.
                                      Just FYI.
                                      I don't like having actual homing code in homeall.g.
                                      I simply have this:
                                      M98 P"homeZ.g"
                                      M98 P"homeX.g"
                                      M98 P"homeY.g"
                                      Remember that I always install Z endstop sensors on my printers so I can home Z first. Also I don't use the Z probe during homing at all, it is not necessary.
                                      Yes, by putting actual homing code in homeall.g you can optimize things slightly but I don't consider it worth it for the added complexity of having essentially duplicate code in two places.
                                      • axiomundefined
                                        axiom @fcwilt
                                        @fcwilt What do I have to write into the Homing.g files instead of the G30 command?
                                        • axiomundefined
                                          axiom @fcwilt
                                          @fcwilt or to put it another way...if I delete homeall.g, how do I correct homez.g?
                                          • fcwiltundefined
                                            fcwilt @axiom
                                            @axiom
                                            Do you have the Z endstop sensor installed and ready to use? Good job.
                                            OK as to the code...
                                            Basically you use the same sort of G1 H1 commands that you do with X and Y axes.
                                            The three files homeX.g, homeY.g and homeZ.g could end up looking pretty much the same.
                                            To provide example code let's assume that all three axes home to the axis minimum. Let's also assume that the range of motion on each axis is a total of 300mm. The essential code would look something like this:
                                            In homeX.g:
                                            G91               ; relative moves
                                            G1 H1 X-310 F6000 ; fast move to min endstop
                                            G1 X20            ; back off a bit
                                            G1 H1 X-25 F600   ; slow move to min endstop
                                            G92 X###          ; where ### is the actual axis position when the motion stopped - usually determined by testing
                                            In homeY.g:
                                            G1 H1 Y-310 F6000 ; fast move to min endstop
                                            G1 Y20            ; back off a bit
                                            G1 H1 Y-25 F600   ; slow move to min endstop
                                            G92 Y###          ; where ### is the actual axis position when the motion stopped - usually determined by testing
                                            In home Z.g:
                                            G1 H1 Z-310 F1200 ; fast move to min endstop
                                            G1 Z20            ; back off a bit
                                            G1 H1 Z-25 F300   ; slow move to min endstop
                                            G92 Z###          ; where ### is the actual axis position when the motion stopped - usually determined by testing
                                            Regards the G92 commands:
                                            Remember that the G1 H1 moves stop when the endstop is triggered and the logical axis position is set to the min/max value from the M208 for that axis, depending on the configured location of the endstop.
                                            But if your endstops don't actually trigger at exactly the min/max position (mine never do) then you can use G92 so the logical position of the axis (which G92 sets) is in sync with the physical position.
                                            Hope that helps rather than confuses.
