    Test cube is half the size it should be on test print.
    271
    • fcwiltundefined
      fcwilt @ecnsupplies
      @ecnsupplies
      Perhaps you inadvertently told the slicer to scale the print?
      P.S. And I see you are still using bed.g instead of mesh.g
      ecnsuppliesundefined 1 Reply Last reply Reply Quote 0
      • ecnsuppliesundefined
        ecnsupplies @fcwilt
        @fcwilt no check and told it to print 20mm on all axis. Using cura.!20231119_204958.jpg
        • fcwiltundefined
          fcwilt @ecnsupplies
          @ecnsupplies said in Test cube is half the size it should be on test print.:
          What do you mean by "told it"?
          Normally the STL you slice determines the size.
          If the STL is not too big post it here.
          Thanks?
          ecnsuppliesundefined 3 Replies Last reply Reply Quote 0
            ecnsupplies @fcwilt
            @fcwilt
            I ment to say I double checked it. The stl says it's 20mm all sides.
            See picture. This is the stick test cubes size.
              ecnsupplies
              xyzCalibration_cube.stl
              • fcwiltundefined
                fcwilt @ecnsupplies
                @ecnsupplies
                OK. I don't use CURA but I fired it up and saw what you were talking about.
                So that would seem to leave your duet configuration wrong as the problem BUT you verified movement by measuring.
                From the DWC console execute a M579 and see what it repots.
                  ecnsupplies @fcwilt
                  Made a test pattern to measure 25mm on each axis and jogged to each. They are exact.
                    ecnsupplies @fcwilt
                    @fcwilt
                    One forum said it might be z accep and jerk are to high. Any clue were this would be?
                      ecnsupplies @fcwilt
                      @fcwilt
                      M579. Axis scale factors x1.000, y:1.000 z:1.000
                      • fcwiltundefined
                        fcwilt @ecnsupplies
                        @ecnsupplies
                        So M587 is not the culprit either.
                        I don't think your acceleration or "jerk" settings are too high. They are higher than mine but I don't think it would drastically affect the size.
                          ecnsupplies @fcwilt
                          @fcwilt
                          Duet recommend cura so that's what I installed.
                          • fcwiltundefined
                            fcwilt @ecnsupplies
                            @ecnsupplies
                            CURA is fine based on the large numbers of users.
                            I just never could get good prints out of it using it's typical settings.
                            Since my "goto" slicer works for me I have never taken to the time to work with CURA to get good results.
                              ecnsupplies @fcwilt
                              @fcwilt
                              I downloaded a different slicer and will run it tonight just so I can say I did.
                              Let you know tomorrow
