    Can I edit Gcode in DWC
    • damaged_goodsundefined
      damaged_goods
      Hi all. I need to edit a very very large file to recover a failed print but the "edit file" is greyed out in DWC. Can it be done? Any suggestions? Ponterface struggles.
      • chrishammundefined
        chrishamm administrators @damaged_goods
        @damaged_goods DWC has a size limit for G-code files. If that option is greyed out, your file is probably too large. Consider downloading it and edit it using Notepad or another editor of your choice, then upload it again.
        Duet software engineer
        damaged_goodsundefined 1 Reply Last reply Reply Quote 0
          damaged_goods @chrishamm
          @chrishamm thank you
          • SJIundefined
            SJI
            What is the size limit for g code files in dwc
