Unable to install Input Shaping plugin
https://docs.duet3d.com/User_manual/Tuning/Input_shaping_plugin
If I follow these directions (Upload and Start the InputShapingPlugin-master.zip in DWC), I get an error message that "Only a single file can be uploaded and started". I can drag the ZIP file in on the SYSTEM tab - it's gets unpacked and creates a folder for the plugin, but it does not show up on the Plugins tab.I have turned up posts that say the documentation is incorrect, but I haven't found what works.
I have the Duet accelerometer. I have a few machines that are DWC 3.4.6, and a couple that are 3.4.5.
I can usually figure out the basics, but I've come up empty on this one.
You've downloaded this version?
https://github.com/Duet3D/InputShapingPlugin/releases/tag/v3.4.6
And your Duet and DWC are also on 3.4.6?
@Phaedrux No ... That was not the version of the plug I've been messing with. That one went in fine.
It's always the little things :-p. Thanks for the assist.
undefined Phaedrux marked this topic as a question
undefined Phaedrux has marked this topic as solved
