    Hotend alarm heating to slow
    392
      droftarts administrators @ecnsupplies
      @ecnsupplies see https://docs.duet3d.com/User_manual/Reference/Gcodes#m307-set-or-report-heating-process-parameters
      Order dependency
      RRF 3.x: The M307 command must come later in config.g than the M950 command that created the heater number it refers to.
      In your config, M307 H1 comes before M950 H1. Move it to after M950.
      Edit: You can check what heater parameters are being used by sending M307 H1 on its own.
      • ecnsuppliesundefined
        ecnsupplies @fcwilt
        @fcwilt
        Manually in duet 3 web interface. Use drop down and put to 200 and activate .
        When using the auto tune it's m303 to m205 command and it runs all 4 tests. I gave you the last results that I put in the config.g and replaced it with the old one in there.
        The test runs fine and goes up to 205 3 times with no issues.
        Only fails when I do it manually or upload a gcode file to start a project.
        Stupped why it works on auto test but not anyother way. It must be disabling something to run the test that's stoping it from normal use.
          @ecnsupplies it looks like you replaced you bed heater M307 with the one for your hotend. So now you’ll probably need to tune your bed again, unless you have a backup.
          ecnsuppliesundefined 1 Reply Last reply Reply Quote 0
            ecnsupplies @droftarts
            @droftarts
            I have a backup. And the bed works fine. Just the hotend gives the error.
            It's so close to getting to 205. Makes it to 185 in a min. Before it fails.
            • fcwiltundefined
              fcwilt @ecnsupplies
              @ecnsupplies
              I don't see any M570 commands in your config.g file.
              See M570 Heater Fault Detection
                ecnsupplies @fcwilt
                @fcwilt
                Added M570 H1 P4 T15 in config file, shut down, waited 2 minutes then turned back on
                It did not help! Same error at 183.6 deg.
                ecnsuppliesundefined fcwiltundefined 2 Replies Last reply Reply Quote 0
                  ecnsupplies @ecnsupplies
                  @ecnsupplies
                  Swapped the m307H0 R0.532 K0.167:0.000 D13.56 E1.35 S1.00 B0 added it to hotend and put back the bed defaults all working! thank you
                  • fcwiltundefined
                    fcwilt @ecnsupplies
                    @ecnsupplies
                    Glad you got it working.
                    Just FYI the parameter P4 is less than the default which would be P5.
                      ecnsupplies @fcwilt
                      @fcwilt
                      Ok. Will change that.
                      • fcwiltundefined
                        fcwilt @ecnsupplies
                        @ecnsupplies said in Hotend alarm heating to slow:
                        @fcwilt
                        I checked a couple of my printers and they were set to P300 - that is very large and I have no recollection of why I did that. It doesn't seem right at all.
                          @head223a said in Hotend alarm heating to slow:
                          switching to 24v power unit resolved the extremely slow heating issue
                          Was it a 12v power supply before? What voltage are the heaters rated for? Running 12v heaters at 24v is dangerous.
