    3.5.0-rc.1 LED Issuse
    Beta Firmware
    1.5k
    • RYANPDXundefined
      RYANPDX
      @droftarts my brain skipped past the U option probably 20 times over the past couple days. That 100% solved the issue! Sorry to confuse the OP with an unrelated issue, I was just trying to keep it clean and grouped with similar issue.
      I've got full control over 144 LEDs 🙂
        droftarts administrators @RYANPDX
        @RYANPDX Did you change the data rate as well, or did you leave that at 3Mhz?
        RYANPDXundefined 1 Reply Last reply Reply Quote 0
        • RYANPDXundefined
          RYANPDX @droftarts
          @droftarts reduced the data rate as well per your advice. Thank you so much!
          FYI I picked up the default from: https://docs.duet3d.com/en/User_manual/Connecting_hardware/IO_Neopixel_DotStar
          de4fae7e-f09a-4592-b597-71918337c348-CleanShot 2023-11-14 at 15.25.16@2x.png
          droftartsundefined 2 Replies Last reply Reply Quote 0
            @RYANPDX Yes, it's in M150 as an example, too. I'll check with @dc42 because it's not clear if the Q parameter sets the data rate (in bits per second) or the SPI frequency (in Hz), or if they are actually the same anyway!
            If Q800000 is working for you, though, I'll take that as a good sign, and it might help @Ce72 .
              @RYANPDX my mistake! According to @dc42 ” The SPI clock frequency is 4x the bit rate” so 3KHz (or even 3.2KHz) should be fine. Lower rates will take longer to update the LEDs, and might be noticeable on long LED strings. I’ll update the documentation.
              • danzaywerundefined
                danzaywer
                I have a strange behavior on the leds with the 3.5rc1 too, on duet2 wifi . Basically, the first set is successful if done at the same time as the print starts (I have the M80 command in the start.g and M150 R255 S3) after which with any other M150 the green on the first LED remains lit as a residue. For example, with
                M150 E0 R0 U0 B0 S3
                the first remains green, with
                M150 E0 R255 U0 B0 S3
                the first is orange (red + green) the other two red, with
                M150 E0 R0 U0 B0 W250 S3
                the first green, the other 2 white. I have 3 neopixel rgbw leds for the stealthburner, port CONN_LCD and a 74HCT08, older firmware all worked. I also wired 3 other LEDs to another connector with 5V logic of the Duex5, without 74HCT08, and configured E1 strip but the behavior is the same. If power on outside print and send an M150 the issue is present at first shot.
                gloomyandyundefined DonStaufferundefined 2 Replies Last reply Reply Quote 0
                • gloomyandyundefined
                  gloomyandy @danzaywer
                  @danzaywer Can you post your M950 command showing how you define the pin used to access the pixels.
                  danzaywerundefined 1 Reply Last reply Reply Quote 0
                    danzaywer @gloomyandy
                    @gloomyandy Certainly
                    M950 E0 C"connlcd.5" U3 T2
                    gloomyandyundefined 1 Reply Last reply Reply Quote 0
                      @danzaywer Can you try running M950 E0 in the console and post the output here.
                        @gloomyandy
                        M950 E0
                        NeoPixel_RGBW strip on port "(connlcd.np,connlcd.db7,connlcd.5)" uses bit-banging, frequency 2500000Hz, max strip length 3
                          danzaywer @danzaywer
                          @danzaywer default frequency should be 3000000Hz ?
                          gloomyandyundefined droftartsundefined 2 Replies Last reply Reply Quote 0
                            @danzaywer I'd try different frequencies from 2000000 up to say 3200000. I've found that different pixels sometimes need the frequency to be adjusted a little. You should be able to change the settings (and set the pixels) from the console to try out different configurations.
                              droftarts administrators @danzaywer
                              @danzaywer Are you definitely getting a 5V signal on the data line to the first LED? I've been playing around with LEDs for the last couple of days on a variety of Duet boards, and have a similar effect when controlling them from 3.3V pins.
                                @gloomyandy Nope
                                I try from 3200000 to 2000000, also 1600000 and 8000, 800 500 just to try, green is always on everytime i send an M150. Maybe an hardware foult of my duet? on
                                M950 E1 C"duex.pwm5" T2
                                is same same .
                                  @danzaywer And it worked okay in older firmware? What version? If so, I doubt it's a hardware fault. Maybe, just maybe ... a ... firmware ... bug!?
                                    danzaywer @droftarts
                                    @droftarts On duex.pwm5 I should have 5v from external source, I have atx 5v rail connected on "EXT 5v" and "5v AUX" jumper is on "5v ext", while the strip on CONN_LCD have signal on a 74HCT08.
                                      @droftarts Yes, it worked fine. BTW no a great issue, if set blue I have cyan....
                                        @danzaywer If you go back to an older version of the firmware (which version did you have?), does it work?
                                          @gloomyandy It worked on 3.4.6, could not try downgrade at the moment, too many changes to do
                                            @danzaywer I’ll test later. The LEDs I have all work on 5V and 3.3V signalling on Duet 3 (except if I use them on an io.in pin), but the first LED (of 7) doesn’t respond correctly on Duet 2, and the string goes full on on Maestro whatever I send (which hasn’t supported Neopixels before 3.5). So it does feel like something is not quite right.
