    [3.5.0-rc.1] Variable occasionally not found
    Beta Firmware
    604
    • niocio01undefined
      niocio01
      I'm running a Duet 3 MB6HC on 3.5.0-rc.1 using SBC (RPi-4) and some Toolboards v1.1
      Occasionally I get the error:
      Error: in file daemon.g line 12: in file macro line 1: unknown variable 'currentTemp'
      The deamon.g looks like this:
      var tolearance = 3
      var setpoint = 0
      var currentTemp = 0
      while true
      	if {global.Idle == false}
      		set var.currentTemp = heat.heaters[{global.IO_NR[0][global.IO_HEATER]}].current
      		if heat.heaters[{global.IO_NR[0][global.IO_HEATER]}].state == "off"
      			if var.currentTemp < 50
      				M98 P"0:/macros/Lights/T0_Status.g" S"Off"
      			else
      				M98 P"0:/macros/Lights/T0_Status.g" S"Blue"
      		else
      			if heat.heaters[{global.IO_NR[0][global.IO_HEATER]}].state == "active"
      				set var.setpoint = heat.heaters[{global.IO_NR[0][global.IO_HEATER]}].active
      			else ; standby
      				set var.setpoint = heat.heaters[{global.IO_NR[0][global.IO_HEATER]}].standby
      			if var.currentTemp >= {var.setpoint + {var.tolearance}}
      				M98 P"0:/macros/Lights/T0_Status.g" S"Blue" ; cooling
      			elif var.currentTemp <= {var.setpoint - {var.tolearance}}
      				M98 P"0:/macros/Lights/T0_Status.g" S"Red" ; heating
      			else
      				M98 P"0:/macros/Lights/T0_Status.g" S"Green" ; at setpoint
      	G4 P2000 ; loop every 2s
      It's not a big problem in this case, since It's just turning some LED's different colors, but it still shouldn't happen.
      It only happens maybe once an hour, so I cant reproduce it reliably.
      I don't think I'm doing anything wrong, since it works most of the time without any issues.
      Maybe it is related to: rrf-3-5b2-error-meta-command-unknown-variable
      timschneiderundefined 1 Reply Last reply Reply Quote 1
      • timschneiderundefined
        timschneider @niocio01
        @niocio01
        thank you for reporting!
        this is maybe related to https://forum.duet3d.com/post/326392 as we have talked about at formnext.
        I was able to get around this problem by using global variables in the job file.
        EDIT
        this is a minimal working (not working) example of maybe the same problem.
        tested on
        RepRapFirmware for Duet 3 MB6HC version 3.4.6 (2023-07-21 14:11:38) running on Duet 3 MB6HC v1.02 or later (SBC mode)
        content of 0:/gcodes/variable-gcode.gcode
        G10 P0 S180 ; sets the temperature
        M140 P0 S90 ; set bed temp
        M107                                        ; fan off
        M144 P0 S1                                  ; activate bed 1 heater
        T0                                          ; select tool 0
        M98 P"0:/sys/meltingplot/home_if_necessary" ; check homing
        G29 S1                                      ; load stored hight map
        M83 ; use relative distances for extrusion
        G90 ; use absolute coordinates
        G21 ; set units to millimeters
        M116                                        ; wait for all heaters
        G11 ; unretract
        G1 Z300 F3600                               ; raise z=20mm
        G53 G1 X50 Y50 F14400                       ; move printhead to center
        G92 E0                                       ; reset e-steps
        var testVar1 = 0
        set var.testVar1 = var.testVar1 + 1
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        echo var.testVar1
        G4 P100
        G10                                          ; retract
        G10 P0 R0 S0                        ; disable hotend
        M140 S0 R0                          ; set bed heater to 0°
        M140 P0 S-273.1                     ; disable bed heater
        T-1                                          ; unselect tool
        the printjob will fail
        after 10 iterations.
          dc42 administrators @timschneider
          @timschneider thanks for your example. I've tried it (with a few changes to work on my machine, e.g. removing the macro call) under 3.5.0-rc.1+ and it doesn't fail for me. Does it also fail for you under 3.5.0-rc.1+ ? If so, please add a M122 shortly before the point of failure and post the result of that M122, because I suspect that this issue may depend on the state of the heap when the failing 'set' command is executed.
          timschneiderundefined 2 Replies Last reply Reply Quote 1
            timschneider @dc42
            This post is deleted!
            timschneiderundefined 1 Reply Last reply Reply Quote 0
              timschneider @timschneider
                  timschneider @dc42
                  ok, i had to reread your message again to understand what I should do 🙂
                  new printing job with added M122 after the echo 10
                  M107                                        ; fan off
                  T0                                          ; select tool 0
                  G11 ; unretract
                  var testVar1 = 0
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  M122
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  echo var.testVar1
                  G4 P100
                  G10                                          ; retract
                  T-1                                          ; unselect tool
                  content of 0:/sys/meltingplot/home_if_necessary
                  if move.axes[0].homed == false || move.axes[1].homed == false || move.axes[2].homed == false
                    G28 ; home all axes
                  result in next post.
                    @timschneider
                    27.11.2023, 19:07:23 	=== Diagnostics ===
                    RepRapFirmware for Duet 3 MB6HC version 3.5.0-rc.1 (2023-08-31 16:19:24) running on Duet 3 MB6HC v1.02 or later (SBC mode)
                    Board ID: 08DJM-9P63L-DJ3T8-6JKD4-3SJ6K-9A77A
                    Used output buffers: 1 of 40 (17 max)
                    Static ram: 154852
                    Dynamic ram: 87620 of which 4216 recycled
                    Never used RAM 95920, free system stack 138 words
                    Tasks: SBC(2,rWait:,0.7%,406) HEAT(3,nWait,0.0%,325) Move(4,nWait,0.0%,241) CanReceiv(6,nWait,0.0%,941) CanSender(5,nWait,0.0%,335) CanClock(7,delaying,0.0%,343) TMC(4,nWait,8.6%,61) MAIN(2,running,90.2%,137) IDLE(0,ready,0.4%,30), total 100.0%
                    Owned mutexes: File(MAIN)
                    Last reset 00:11:35 ago, cause: power up
                    Last software reset at 2023-11-27 09:02, reason: User, Gcodes spinning, available RAM 124940, slot 0
                    Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0044a000 BFAR 0x00000000 SP 0x00000000 Task SBC Freestk 0 n/a
                    Error status: 0x00
                    MCU temperature: min 22.7, current 33.2, max 33.6
                    Supply voltage: min 0.1, current 24.1, max 24.2, under voltage events: 0, over voltage events: 0, power good: yes
                    12V rail voltage: min 0.1, current 12.2, max 12.9, under voltage events: 0
                    Heap OK, handles allocated/used 99/1, heap memory allocated/used/recyclable 2048/24/12, gc cycles 0
                    Events: 0 queued, 0 completed
                    Driver 0: standstill, SG min 0, mspos 552, reads 16149, writes 31 timeouts 0
                    Driver 1: standstill, SG min 0, mspos 168, reads 16149, writes 31 timeouts 0
                    Driver 2: standstill, SG min 0, mspos 456, reads 16144, writes 36 timeouts 0
                    Driver 3: standstill, SG min 0, mspos 216, reads 16144, writes 36 timeouts 0
                    Driver 4: standstill, SG min 0, mspos 8, reads 16144, writes 36 timeouts 0
                    Driver 5: standstill, SG min 0, mspos 4, reads 16159, writes 21 timeouts 0
                    Date/time: 2023-11-27 19:07:22
                    Slowest loop: 489.59ms; fastest: 0.06ms
                    === Storage ===
                    Free file entries: 20
                    DMs created 125, segments created 22, maxWait 458419ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                    no step interrupt scheduled
                    Moves shaped first try 19, on retry 0, too short 0, wrong shape 19, maybepossible 0
                    === DDARing 0 ===
                    Scheduled moves 79, completed 79, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                    === DDARing 1 ===
                    Bed heaters 0 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                    Heater 0 is on, I-accum = 1.0
                    Heater 1 is on, I-accum = 0.2
                    HTTP* is idle in state(s) 0
                    Telnet is idle in state(s) 0
                    File* is doing "M122" in state(s) 0
                    USB is idle in state(s) 0
                    Aux is idle in state(s) 0
                    Queue is idle in state(s) 0
                    LCD is idle in state(s) 0
                    SBC is idle in state(s) 0
                    Daemon is idle in state(s) 0
                    Aux2 is idle in state(s) 0
                    File2* is idle in state(s) 0
                    Queue2 is idle in state(s) 0
                    Q0 segments left 0, axes/extruders owned 0x80000003
                    Code queue 0 is empty
                    Code queue 1 is empty
                    === Filament sensors ===
                    Extruder 0: pos 0.00, errs: frame 0 parity 0 ovrun 0 pol 0 ovdue 0
                    === CAN ===
                    Messages queued 6108, received 0, lost 0, boc 0
                    Longest wait 0ms for reply type 0, peak Tx sync delay 0, free buffers 50 (min 50), ts 3477/0/0
                    Tx timeouts 0,0,3476,0,0,2630 last cancelled message type 30 dest 127
                    === SBC interface ===
                    Transfer state: 5, failed transfers: 0, checksum errors: 0
                    RX/TX seq numbers: 26561/26561
                    SPI underruns 0, overruns 0
                    State: 5, disconnects: 0, timeouts: 0 total, 0 by SBC, IAP RAM available 0x25a98
                    Buffer RX/TX: 0/0-0, open files: 0
                    === Duet Control Server ===
                    Duet Control Server version 3.5.0-rc.1 (2023-09-01 07:22:07)
                    File+ProcessInternally:
                    > Executing set var.testVar1 = var.testVar1 + 1 (30 more codes pending)
                    File /opt/dsf/sd/gcodes/variable-gcode.gcode is selected, processing
                    Failed to deserialize the following properties:
                    - MoveSegmentation -> Int32 from 1.0
                    Code buffer space: 4096
                    Configured SPI speed: 8000000Hz, TfrRdy pin glitches: 0
                    Full transfers per second: 4.02, max time between full transfers: 234.0ms, max pin wait times: 34.4ms/1.4ms
                    Codes per second: 0.05
                    Maximum length of RX/TX data transfers: 4380/916
                      some more infos from system log (journalctl -xe). I'm able to reproduce the error, so the following is a log from today.
                      Nov 28 09:23:54 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [info] Finished macro file 0:/sys/bed.g
                      Nov 28 09:24:02 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [info] Finished macro file 0:/sys/homez.g
                      Nov 28 09:24:02 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [info] Finished macro file homeall.g
                      Nov 28 09:24:02 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [info] Finished macro file 0:/sys/meltingplot/home_if_necessary
                      Nov 28 09:24:03 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [info] 1
                      Nov 28 09:24:05 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [error] File2: Failed to execute code set var.testVar1 = var.testVar1 + 1 on internal processing stage
                      Nov 28 09:24:05 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    DuetAPI.CodeParserException: unknown variable 'var.testVar1'
                      Nov 28 09:24:05 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    at DuetControlServer.Codes.Handlers.Keywords.Process(Code code) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Codes/Handlers/Keywords.cs:line 245
                      Nov 28 09:24:05 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    at DuetControlServer.Commands.Code.ProcessInternally() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Commands/Generic/Code.cs:line 228
                      Nov 28 09:24:05 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    at DuetControlServer.Codes.Pipelines.ProcessInternally.ProcessCodeAsync(Code code) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Codes/Pipelines/ProcessInternally.cs:line 30
                      Nov 28 09:24:05 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [error] in job file (channel File2) line 68: unknown variable 'var.testVar1'
                      Nov 28 09:24:05 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [warn] DuetAPI.CodeParserException: unknown variable 'var.testVar1'
                      Nov 28 09:24:05 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    at DuetControlServer.FileExecution.Job.DoFilePrint(CodeFile file) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/FileExecution/Job.cs:line 371
                      Nov 28 09:24:05 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [error] in job file (channel File2) line 72: unknown variable 'var.testVar1'
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: Maximum length of RX/TX data transfers: 4427/916
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [error] File: Failed to execute code set var.testVar1 = var.testVar1 + 1 on internal processing stage
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    DuetAPI.CodeParserException: unknown variable 'var.testVar1'
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    at DuetControlServer.Codes.Handlers.Keywords.Process(Code code) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Codes/Handlers/Keywords.cs:line 245
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    at DuetControlServer.Commands.Code.ProcessInternally() in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Commands/Generic/Code.cs:line 228
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    at DuetControlServer.Codes.Pipelines.ProcessInternally.ProcessCodeAsync(Code code) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Codes/Pipelines/ProcessInternally.cs:line 30
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [error] in job file (channel File) line 68: unknown variable 'var.testVar1'
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [warn] DuetAPI.CodeParserException: unknown variable 'var.testVar1'
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    at DuetControlServer.FileExecution.Job.DoFilePrint(CodeFile file) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/FileExecution/Job.cs:line 371
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [error] File: Failed to execute code echo var.testVar1 on internal processing stage
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    DuetAPI.CodeParserException: in GCode file line 66: unknown variable 'testVar1'
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    at DuetControlServer.Model.Expressions.EvaluateExpression(Code code, String expression, Boolean onlySbcFields, Boolean encodeResult) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Model/Expressions.cs:line 886
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    at DuetControlServer.Model.Expressions.Evaluate(Code code, Boolean evaluateAll) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Model/Expressions.cs:line 314
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]:    at DuetControlServer.Codes.Handlers.Keywords.Process(Code code) in /home/runner/work/DuetSoftwareFramework/DuetSoftwareFramework/src/DuetControlServer/Codes/Handlers/Keywords.cs:line 141
                      Nov 28 09:24:21 Meltingplot-MBL-480-vaswsq DuetControlServer[1828]: [error] in job file (channel File) line 69: in GCode file line 66: unknown variable 'testVar1'
                        @timschneider thanks, looks like this issue may be specific to SBC mode. I'll ask @chrishamm to take a look.
                          timschneider @dc42
                          yes, i don't see this kind of error in standalone mode.
                          • chrishammundefined
                            chrishamm administrators @timschneider
                            @timschneider Thanks, I've got a bug fix ready for v3.4 and v3.5. I suggest you use conditional G-code only in macro files until a new version is available.
                            Duet software engineer
                              timschneider @chrishamm
                              @chrishamm
                              Hi @chrishamm , thank you for fixing my issue lightning fast - but unfortunately the problem from @niocio01 must be something else, cause as far as I know, the daemon.g is running in the macro branch and is not related to the job processor. I thought it is related due to the message and the G4 in the daemon.g.
                              Maybe he is hitting some special value?
                              For example
                              var testVar1 = 99E9999999999999999999999
                              will crash the duet RRF. Is there a value which is able to reset, unset a variable?
                                @timschneider thanks for pointing out the bug in RRF when you try to set a variable to that very large value. I will fix it in the 3.5 source code.
                                I suggest you use
                                var testVar1 = null
                                instead.
