    RRF 3.5B2 Error: meta command: unknown variable
    Beta Firmware
    596
    • jp.douarvil 0undefined
      jp.douarvil 0
      Hello all,
      I run RRF 3.5B2 on Duet 3 in standalone mode.
      I am puzzled by an unexpected "unknown variable error".
      Here is an extract from "G103.g":
      var uClean = false
      if {var.uClean}
      	G90 G1 H2 Y{125+random(226)} X{var.xForth} U{var.uForth}
      else
      if {var.uClean && var.xClean && {global.ioMotV!=null} && {global.ioMotW!=null}}
      	G90 G1 H2 V{var.vDive} W{var.wDive} F{move.axes[4].speed}
      elif {var.xClean && {global.ioMotV!=null}}
      And there the extract from the "eventlog.txt":
      YYYY-MM-DD HH:MM:SS [warn] Error: in file macro line 7 column 16: meta command: unknown variable 'uClean'
      However the "var.uClean" variable is being called (several times in the full "G103g" file) between its declaration line 1 and its call line 7 the error occurs line 7 nonetheless.
      Has anybody an idea of the possible reason for this issue?
      Thank you in advance for your help.
      Regards,
      Exerqtorundefined infiniteloopundefined dc42undefined 3 Replies Last reply Reply Quote 0
      • Exerqtorundefined
        Exerqtor @jp.douarvil 0
        @jp-douarvil-0
        I've been having some weird variable issues too (since 3.4 tbh).
        Try this out and see what happens
        var uClean = 0
        set var.uClean = false
        • infiniteloopundefined
          infiniteloop @jp.douarvil 0
          @jp-douarvil-0
          Did you verify the vars and expressions following 'uClean'? The error message blames 'uClean', but points at the following column.
          @Exerqtor
          Maybe a problem with type coercion? In line 1, 'uClean' might be set up as an int. To verify that, change line 1 to
          var uClean = false
            dc42 administrators @jp.douarvil 0
            @jp-douarvil-0 please attach your G103.g file to a post in this thread. It might contain a non-printing character; if not then I will try out your file here.
            PS - I suspect this is caused by the multiple file readers in RRF 3.5 and is related to https://forum.duet3d.com/topic/31812/3-5b2-macros-called-from-a-job-lose-parameters. I have added it to my list to investigate.
            • chrishammundefined
              chrishamm administrators @Exerqtor
              @Exerqtor I've been able to reproduce your example and fixed the underlying bug. Unforunately, I have been unable to reproduce the other two reports so far.
              Duet software engineer
              AndMazundefined 1 Reply Last reply Reply Quote 1
              • AndMazundefined
                AndMaz @chrishamm
                @chrishamm can you provide more details about the actual bug? What versions firmware version did it affect? Only 3.5B2?
                I'm asking this because I'm facing something similar and I can't find a way to isolate the issue.
                I have a g-file with 20 local vars. and I'm getting a unknown variable
                To give you a better idea, here are (simplified) contents of the file
                var convertedAstart=0
                var convertedAEnd=0
                var periodAStartHr=19
                var periodAStartMin=0
                var periodAEndHr=9
                var periodAEndMin=0
                set var.periodAStartHrToSec=var.periodAStartHr*3600
                set var.periodAStartMinToSec=var.periodAStartMin*60
                set var.convertedAstart=var.periodAStartHrToSec+var.periodAStartMinToSec
                set var.periodAEndHrToSec=var.periodAEndHr*3600
                set var.periodAEndMinToSec=var.periodAEndMin*60
                set var.convertedAEnd=var.periodAEndHrToSec+var.periodAEndMinToSec
                while true
                  if (var.convertedAstart<=global.legacyEpochSeconds || global.legacyEpochSeconds<=var.convertedAEnd)
                    ; Do stuff here
                And here's the error that I receive:
                Error: in GCode file line 45 column 26: meta command: unknown variable 'convertedAstart'
                The file is called with M98 P"<path-to-file>".
                This error usually happens when I call M25, M0 and then M98 P"<path-to-file>" to start printing again.
                ATM rebooting the device solves the issue, ie, after reboot M98 P"<path-to-file>" does not throw any error.
                  chrishamm administrators @AndMaz
                  @AndMaz The problem was that an invalid statement in a macro called by a job file caused the print to abort. The function aborting the print cleared all the variables from the scope of both file readers executing a macro file causing one file reader to output a bad error message.
                  • T3P3Tonyundefined
                    T3P3Tony administrators @chrishamm
                    @Exerqtor please can you confirm if this is fixed for you in 3.5.0-beta4 ?
                    www.duet3d.com
                    Exerqtorundefined 1 Reply Last reply Reply Quote 0
                    • Exerqtorundefined
                      Exerqtor @T3P3Tony
                      @T3P3Tony I haven't been able to run beta4 because of the crashing issues i'm having with it for more than one print. But if I remeber correctly this specific issue was fixed.
                      • dc42undefined dc42 marked this topic as a question
                      • niocio01undefined niocio01 referenced this topic
