Feedrate reformatting post script
3D Printing General Chat
    justinkg
    I am looking for help with writing a post process script to adjust the formatting of the feedrate call outs from PrusaSlicer.
    Right now the format is like this:
    1 G1 E.1 F2400
    2 ;TYPE:Skirt/Brim
    3 ;WIDTH:1.7
    4 G1 F4799.988
    5 G1 X487.836 Y463.711 E.82895
    But this causes issues where my machine doesn't recognize the G1 F4799.988 command and maintains the feed rate of F2400 from line 1.
    I need it to look something like this (which comes from Simplify3D, but I want to use organic tree supports).
    6 G1 Z0.900 F1800
    7 G1 X483.600 Y469.844 F21000
    8 G1 X490.044 Y463.400 E4.6282 F3600
    9 G1 X549.956 Y463.400 E35.0570
    Any help would be appreciated.
    undefined undefined 2 Replies Last reply 29 Nov 2023, 14:59 Reply Quote 0
      jay_s_uk @justinkg
      @justinkg it would be better to tell us what firmware you are running so the "bug" can be addressed rather than trying to fix the output.
      Lots of people use prusaslicer.
      A sample gcode file would also b e helpful
        justinkg
        The machine uses a yaskawa controller and apparently how it interprets the gcode is part of the firmware. No way for me to change anything in there. The slicer firmware is RepRap/Sprinter.
        undefined 1 Reply Last reply 29 Nov 2023, 16:28 Reply Quote 0
          jay_s_uk @justinkg
          @justinkg oh, so nothing to do with RRF. You're just after general help. gotcha
          • undefined Phaedrux moved this topic from Gcode meta commands 29 Nov 2023, 18:03
            justinkg
            Yeah. From what I can gather. I need to write a script to go through the entire gcode and automate moving the feedrate to the end of the following line. I am going to try to write it in python, but its been a while.
              OwenD @justinkg
              @justinkg
              Just a guess as I have no experience with Yaskawa controllers.
              However some CNC controllers accept a feed rate command on its own
              So try changing
              G1 F3600
              to
              F3600
                justinkg
                I was able to write a script in python that does what I want. Posting it here for others to reference if needed.
                import sys
                import re
                flag = False
                out = open('YOUR FILE NAME HERE'+'_adjusted'+'.gcode', 'w')
                with open('YOUR FILE NAME HERE.gcode') as f:
                for r in f:
                if re.search('G1 F', r):
                feedrate = r[3:]
                flag = True
                print(r[:-1] + ' ' + feedrate) # get rid of new line
                elif flag:
                r = r[:-1] + ' ' + feedrate
                out.write(r)
                flag = False # Reset flag
                else:
                out.write(r)
                4 out of 7
