    Quiet mode
    • Auréundefined
      Auré
      Hello !
      Can you help me please, for set the silent mode on my printer.
      I live in an apartment and prefer silence to speed.
      I see a tutorial on Duet doc but I never set the stealthchop and I don't know how to.
      Thank
      ; generated by RepRapFirmware Configuration Tool v3.2.3 on Fri Jun 04 2021 20:14:20 GMT+0200 (heure d’été d’Europe centrale)
      G90                                                ; send absolute coordinates...
      M83                                                ; ...but relative extruder moves
      M669 K1                                            ; select CoreXY mode
      G4 S4                                              ;wait for expansion boards to start
      M569 P0.0 S0                                       ; physical drive 0.0 goes forwards
      M569 P0.1 S0                                       ; physical drive 0.1 goes forwards
      M569 P0.3 S0                                       ; physical drive 0.3 goes forwards
      M569 P0.4 S0                                       ; physical drive 0.4 goes forwards
      M569 P0.5 S0                                       ; physical drive 0.5 goes forwards
      M569 P121.0 S1                                     ; physical drive 121.0 goes forwards
      M584 X0.0 Y0.1 Z0.3:0.4:0.5 E121.0                 ; set drive mapping
      M671 X-18.109:183.1:384.309 Y-10.413:367.797:-10.413 S50
      M350 X16 Y16 Z16 E16 I1                            ; configure microstepping with interpolation
      M92 X160.00 Y160.00 Z800.00 E335.40                ; set steps per mm
      M566 X500.00 Y500.00 Z30.00 E120.00                ; set maximum instantaneous speed changes (mm/min) // avant M566 X1200.00 Y1200.00 Z30.00 E120.00
      M203 X18000.00 Y18000.00 Z1800.00 E1200.00         ; set maximum speeds (mm/min)
      M201 X500.00 Y500.00 Z100.00 E250.00               ; Réglage accelerations (mm/s^2)
      M906 X1260 Y1260 Z1350 E960 I30                    ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                            ; Set idle timeout
      M591 P1 C"121.io1.in" S1 D0					 	   ; filament monitor connected to E0 endstop
      M208 X0 Y0 Z0 S1                                   ; set axis minima
      M208 X365 Y355 Z335 S0                             ; set axis maxima
      M574 X1 S1 P"121.io2.in"                           ; configure active-high endstop for low end on X via pin 121.io1.in
      M574 Y1 S1 P"io0.in"                               ; configure active-high endstop for low end on Y via pin io0.in
      M574 Z1 S2                                         ; configure Z-probe endstop for low end on Z
      M950 S0 C"121.io0.out"                             ; create servo pin 0 for BLTouch
      M558 P9 C"^121.io0.in" H15 F120 T9000              ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X3 Y-41 Z3.676                            ; set Z probe trigger value, offset and trigger height
      M557 X15:215 Y15:195 S20                           ; define mesh grid
      M308 S0 P"temp0" Y"thermistor" T100000 B4138       ; configure sensor 0 as thermistor on pin temp0
      M950 H0 C"out0" T0                                 ; create bed heater output on out0 and map it to sensor 0
      M307 H0 B0 S1.00                                   ; disable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                            ; map heated bed to heater 0
      M143 H0 S90                                        ; set temperature limit for heater 0 to 100C
      M308 S1 P"121.temp0" Y"thermistor" T100000 B4725 C7.06e-8   ; configure sensor 1 as thermistor on pin 121.temp0
      M950 H1 C"121.out0" T1                             ; create nozzle heater output on 121.out0 and map it to sensor 1
      M307 H1 B0 S1.00                                   ; disable bang-bang mode for heater  and set PWM limit
      M143 H1 S260                                       ; set temperature limit for heater 1 to 280C
      M950 F0 C"121.out1" Q500                           ; create fan 0 on pin 121.out1 and set its frequency
      M106 P0 S0 H T45                                   ; set fan 0 value. Thermostatic control is turned on
      M950 F1 C"121.out2" Q500                           ; create fan 1 on pin 121.out2 and set its frequency
      M106 P1 S0 H-1                                     ; set fan 1 value. Thermostatic control is turned off
      M563 P0 D0 H1 F1                                   ; define tool 0
      G10 P0 X0 Y0 Z0                                    ; set tool 0 axis offsets
      G10 P0 R0 S0                                       ; set initial tool 0 active and standby temperatures to 0C
      M501                                               ; load saved parameters from non-volatile memory
      Reprap core XY, Ender 3 upgraded.
      If you keep trying, you'll eventually succeed. So: the more you fail, the more likely you are to succeed.
      A quote from Jacques Rouxel
        droftarts administrators @Auré
        @Auré Please send M115 in the console and post the response. Without knowing what hardware and firmware version you are using, it is difficult to advise. It looks like you're using a 6HC with a 1LC toolboard; is that correct?
        Usually, the easiest thing for quiet motors is to set the stepper drivers permanently into stealthChop mode, using M569 ... D3 V0 eg:
        M569 P0.0 S0 D3 V0                                 ; physical drive 0.0 goes forwards
        M569 P0.1 S0 D3 V0                                 ; physical drive 0.1 goes forwards
        M569 P0.3 S0 D3 V0                                 ; physical drive 0.3 goes forwards
        M569 P0.4 S0 D3 V0                                 ; physical drive 0.4 goes forwards
        M569 P0.5 S0 D3 V0                                 ; physical drive 0.5 goes forwards
        M569 P121.0 S1 D3 V0                               ; physical drive 121.0 goes forwards
        Note that stealthChop mode does not have the torque of spreadCycle, so you won't be able to run at high speeds.
        Auréundefined 1 Reply Last reply Reply Quote 0
        • Auréundefined
          Auré @droftarts
          @droftarts
          I think I don't need a hight torque.
          Yes I use 6HC with toolboard 1LC, my firmware is 3.5.0-beta.4 .
          I've just added D3 V0 on XY and Z, and sent a G32 for testing, the result is magnificent when the bed goes up but when it goes down the noise is the same because the speed is fast and I believe the spreadCycle is activate.
          For X and Y too, I think I need to change the acceleration parameter.
          Thanks
          Edit: Ok, I left that idea aside, I see my printer's motors doesn't like it too much, when all I'm doing is moving the head at 1250mm/min.
          I hear footsteps jumping.
          Auré
