    Reboots/crashes - RRF ≤3.5.0-rc1
    Beta Firmware
    13
    137
    10.1k
    • Exerqtorundefined
      Exerqtor @droftarts
      @droftarts said in Reboots/crashes - RRF 3.5.0-rc1:
      @Exerqtor do you get crashes if you disable daemon.g?
      As in setting the global to false disable, or have a empty daemon.g?
      I can try both, i just set the global to false (i'm pretty sure we tested this earlier, but it's been such a long time since this all started I have a hard time keeping up).
        dc42 administrators @Exerqtor
        @Exerqtor better to have a daemon.g file with just a very long G4 command in it.
        Exerqtorundefined 1 Reply Last reply Reply Quote 0
        • Exerqtorundefined
          Exerqtor @dc42
          @dc42 said in Reboots/crashes - RRF 3.5.0-rc1:
          In general you mean? Or could elaborate on that a little bit?
          I have alot of crap in daemon.g currently, it's mostly disabled since i ditched what i was trying to do with it. Just haven't gotten around to cleaning it up yet.
          Guess i could do that now 🤷‍♂️
            @Exerqtor what I meant was that a daemon.g file with just a long G4 delay in it would result in less S card access than no daemon.g at all. The maximum value for a G4 delay command is about 2 million seconds.
            Conversely, if you try reducing the G4 S1 delay in your current daemon.g file (e.g. try G4 P10) then this will result in more SD card reads. It would be interesting to see if that results in more frequent resets. Please try that.
            Another thing you could do at the same time is to pad out the end of daemon.g with a few long comment lines something like this:
            ;abcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcdbcdabcdabcdabcd
            This might indicate whether the data that overwrites the return address comes from the residue of the sector of daemon.g that is currently past the end of the file. The sector size is 512 bytes so the number of comment characters in total shod be at least that.
            • Exerqtorundefined
              Exerqtor @dc42
              Gotcha!
              I just did the much needed cleanup in my daemon.g, but I've now added what you said mentioned.
              This is how it looks as of now:
              ; /sys/daemon.g  v2.5
              ; Used to execute regular tasks, the firmware executes it and once the end of file is reached it waits. If the file is not found it waits and then looks for it again.
              ; THIS MACRO ONLY WORKS WITH RRF 3.5.0b1 AND LATER!!
              ; Loop, to be able to turn on/off daemon.g
              while global.RunDaemon
                ; Stuff goes below this line
                ; Resume after filament change
                if exists(global.FilamentCHG)
                  if global.FilamentCHG = true && state.status="paused"
                    M24        ; Resume the pause automatically now that the manual filament change is done
                    set global.FilamentCHG = false
                ; Refresh chamber lights status
                if exists(global.chamber_leds)
                  set global.chamber_leds = state.gpOut[0].pwm * 100
                ;Check sb_leds status
                var SB_LEDS = true                                                           ; Turn on(true) / off(false) the Stealthburner led "system"
                if var.SB_LEDS
                  if fileexists("/sys/lib/led/sb_leds-state.g")
                    M98 P"/sys/lib/led/sb_leds-state.g"                                      ; Check if global.sb_leds has changed since last run/loop
                ; Daemon loop delay
                G4 P10        ; Delay running again or next command for at least 1 second (was S1)
                @Exerqtor thanks, let's see if that resets more often than before.
                Exerqtorundefined 2 Replies Last reply Reply Quote 0
                • Exerqtorundefined
                  Exerqtor @dc42
                  EDIT:
                  Started a new thread to keep this one on topic.
                  • Exerqtorundefined
                    Exerqtor @Exerqtor
                    EDIT:
                    • Exerqtorundefined Exerqtor referenced this topic
                    • Exerqtorundefined
                      Exerqtor @dc42
                      Only one new crash since the daemon.g changes was done:
                      M122
                      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.1+ (2023-12-07 09:49:06) running on Duet 3 Mini5plus WiFi (standalone mode)
                      Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
                      Used output buffers: 1 of 40 (40 max)
                      Static ram: 102844
                      Dynamic ram: 123212 of which 12 recycled
                      Never used RAM 12492, free system stack 182 words
                      Tasks: NETWORK(1,ready,1204.8%,209) HEAT(3,nWait,1.4%,353) Move(4,nWait,0.1%,357) CanReceiv(6,nWait,2.7%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.4%,350) TMC(4,nWait,38.1%,108) MAIN(1,running,3867.8%,670) IDLE(0,ready,269.7%,29) AIN(4,delaying,46.5%,264), total 5431.5%
                      Owned mutexes:
                      Last reset 01:37:14 ago, cause: software
                      Last software reset at 2023-12-08 18:27, reason: AssertionFailed, Gcodes spinning, available RAM 11400, slot 1
                      Software reset code 0x4123 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00487000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                      Stack: 00000913 000af408 0002de51 2002bed4 2002be01 000001a7 2002c100 20031510 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0d362e30 00000000 00000000 00000000 2003151c 00000800 20035a28 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000
                      Error status: 0x04
                      Aux0 errors 0,0,0
                      MCU revision 3, ADC conversions started 5834478, completed 5834477, timed out 0, errs 0
                      MCU temperature: min 35.9, current 36.3, max 39.1
                      Supply voltage: min 22.2, current 24.1, max 26.7, under voltage events: 0, over voltage events: 0, power good: yes
                      Heap OK, handles allocated/used 99/27, heap memory allocated/used/recyclable 2048/1544/1192, gc cycles 11635
                      Events: 0 queued, 0 completed
                      Driver 0: standstill, SG min 256, read errors 0, write errors 1, ifcnt 39, reads 44886, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 1: standstill, SG min 240, read errors 0, write errors 1, ifcnt 39, reads 44886, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 80, reads 44886, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 85, reads 44886, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 81, reads 44886, writes 13, timeouts 0, DMA errors 0, CC errors 0
                      Driver 5: not present
                      Driver 6: not present
                      Date/time: 2023-12-08 20:05:11
                      Slowest loop: 12.91ms; fastest: 0.14ms
                      === Storage ===
                      Free file entries: 18
                      SD card longest read time 7.7ms, write time 4.5ms, max retries 0
                      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                      no step interrupt scheduled
                      Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                      === DDARing 0 ===
                      === DDARing 1 ===
                      Heater 1 is on, I-accum = 0.0
                      HTTP is idle in state(s) 0
                      Telnet is idle in state(s) 0
                      File is idle in state(s) 0
                      USB is idle in state(s) 0
                      Aux is idle in state(s) 0
                      Trigger is idle in state(s) 0
                      Queue is idle in state(s) 0
                      LCD is idle in state(s) 0
                      SBC is idle in state(s) 0
                      Daemon is doing "G4 P10" in state(s) 0 0, running macro
                      Aux2 is idle in state(s) 0
                      File2 is idle in state(s) 0
                      Queue2 is idle in state(s) 0
                      Q0 segments left 0, axes/extruders owned 0x0000803
                      Code queue 0 is empty
                      Code queue 1 is empty
                      === Filament sensors ===
                      in 0 notIn 0
                      Extruder 0 sensor: no filament
                      === CAN ===
                      Messages queued 52517, received 119640, lost 0, errs 1, boc 0
                      Longest wait 2ms for reply type 6053, peak Tx sync delay 278, free buffers 26 (min 25), ts 29171/29170/0
                      Tx timeouts 0,0,0,0,0,0
                      === Network ===
                      Slowest loop: 5.96ms; fastest: 0.00ms
                      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                      HTTP sessions: 2 of 8
                      === WiFi ===
                      Interface state: active
                      Module is connected to access point
                      Failed messages: pending 0, notrdy 0, noresp 0
                      Firmware version 2.1beta4
                      MAC address c4:5b:be:ce:91:93
                      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42960
                      WiFi IP address 192.168.10.x
                      Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0
                      Clock register 00002001
                      So i guess that didn't do much 😅.
                      • Exerqtorundefined
                        Exerqtor @Exerqtor
                        And more:
                        M122
                        Static ram: 102844
                        Dynamic ram: 123248 of which 0 recycled
                        Never used RAM 12468, free system stack 180 words
                        Tasks: NETWORK(1,ready,38.7%,232) HEAT(3,nWait,0.2%,328) Move(4,nWait,0.0%,343) CanReceiv(6,nWait,0.4%,774) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.1%,350) TMC(4,nWait,6.2%,108) MAIN(1,running,2.9%,670) IDLE(0,ready,43.9%,29) AIN(4,delaying,7.6%,264), total 100.0%
                        Owned mutexes: WiFi(NETWORK)
                        Last reset 08:58:00 ago, cause: software
                        Last software reset at 2023-12-09 01:46, reason: AssertionFailed, Platform spinning, available RAM 11580, slot 2
                        Software reset code 0x4920 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x20011fbc Task NETW Freestk 495 ok
                        Stack: 00000913 000af408 0002de51 2002bed4 2002be01 000001a7 2002c100 20030440 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0d362e30 00000000 00000000 00000000 2003044c 00000800 20035988 2002c100 20018678 2002bf9d 20018678 2001e888 000300db 00000000 00000000
                        Error status: 0x04
                        Aux0 errors 0,0,0
                        MCU revision 3, ADC conversions started 32280441, completed 32280439, timed out 0, errs 0
                        MCU temperature: min 35.7, current 36.6, max 39.1
                        Supply voltage: min 22.3, current 24.1, max 26.7, under voltage events: 0, over voltage events: 0, power good: yes
                        Heap OK, handles allocated/used 99/26, heap memory allocated/used/recyclable 2048/1936/1596, gc cycles 64514
                        Driver 0: standstill, SG min 16, read errors 0, write errors 1, ifcnt 63, reads 60543, writes 13, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x71
                        Driver 1: standstill, SG min 228, read errors 0, write errors 1, ifcnt 62, reads 60541, writes 13, timeouts 3, DMA errors 0, CC errors 0, failedOp 0x6c
                        Driver 2: standstill, SG min 2, read errors 0, write errors 1, ifcnt 99, reads 60544, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 3: standstill, SG min 2, read errors 0, write errors 1, ifcnt 103, reads 60544, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Driver 4: standstill, SG min 2, read errors 0, write errors 1, ifcnt 99, reads 60545, writes 13, timeouts 0, DMA errors 0, CC errors 0
                        Date/time: 2023-12-09 10:44:02
                        Slowest loop: 12.87ms; fastest: 0.13ms
                        === Storage ===
                        SD card longest read time 7.8ms, write time 4.4ms, max retries 0
                        === DDARing 0 ===
                        === DDARing 1 ===
                        Daemon is idle in state(s) 0 0, running macro
                        in 0 notIn 0
                        === CAN ===
                        Messages queued 290534, received 661804, lost 0, errs 1, boc 0
                        Longest wait 2ms for reply type 6053, peak Tx sync delay 344, free buffers 26 (min 25), ts 161403/161402/0
                        === Network ===
                        Slowest loop: 5.80ms; fastest: 0.00ms
                        HTTP sessions: 3 of 8
                        === WiFi ===
                        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39348
                        Signal strength -48dBm, channel 6, mode 802.11n, reconnections 0
                        dc42undefined 3 Replies Last reply Reply Quote 0
                          @Exerqtor thanks. The text that is overwriting the return address s now "0.6<CR>". The fact that is includes a <CR> suggests that this text comes from a job file or macro file, not from RRF itself, because RRF uses <LF> as a line terminator and almost never generates <CR>.
                          Please can you insert command G4 S10000 at the start of daemon.g and restart, to see if it still crashes.
                            @Exerqtor which browser are you using, and what version? That text ""0.6<CR>" could be the end of a browser version in a HTTP header.
                            PS - also, what language settings do you have in your browser? That text could be the end of an Accept-Language HTTP header.
                              @Exerqtor one more data point please: have you always been running a 2.1beta version of DuetWiFiServer when you had these errors, or did you have them when using version 1.27 also?
                              • Exerqtorundefined
                                Exerqtor @dc42
                                Ok let's see if I'm able to answer all that somewhat effectively 🤣
                                First off, is this what you had in mind?:
                                G4 S10000        ; As per David's instructions
                                  if var.SB_LEDS
                                  ; Daemon loop delay
                                Or would you want it within the "RunDaemon" loop, and remove/comment out the one in the bottom @dc42 ?
                                This is somewhat difficult to answer since i have no idea what Orca Slicer v1.8.1 (English language settings) runs under the hood edit Orca Slicer is running WebView2 /edit (and I have the "Device" tab open within Orca Slicer). For my desktop browser i'm currently using "Chrome x64 version 119.0.6045.200"(Norwegian language settings), but that's being updated all the time.
                                I'm quite positive that I tried several DuetWiFiServer releases once i started having these issues, trying to pinpoint where they came from. But since the crashes also kept happening on 1.27 i updated to the newest 2.1 beta again (if my memory serves right).
                                Other than that it had another crash now while i was about to deploy the changes to daemon.g, so i'll post that first:
                                M122
                                Static ram: 102844
                                Dynamic ram: 123200 of which 0 recycled
                                Never used RAM 12516, free system stack 182 words
                                Tasks: NETWORK(1,ready,19.9%,211) HEAT(3,nWait,0.0%,353) Move(4,nWait,0.0%,357) CanReceiv(6,nWait,0.0%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,114) MAIN(1,running,71.7%,670) IDLE(0,ready,6.8%,29) AIN(4,delaying,0.9%,264), total 100.0%
                                Last reset 00:08:56 ago, cause: software
                                Last software reset at 2023-12-09 11:38, reason: HardFault bfarValid precise, Platform spinning, available RAM 11420, slot 0
                                Software reset code 0x4060 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x0d362e38 SP 0x20011f48 Task NETW Freestk 466 ok
                                Stack: 0d362e30 20032cac 000001bf 00000000 0d362e30 20032cac 000043a8 010f0200 00000001 200117a4 2002bed0 000001bf 000001bf 00000004 0002dd33 2002bed4 2002be01 000001bf 2002c100 20031c70 2002c118 2001e888 362e303d a5a5a5a5 0002ff41 00000000 00000000
                                Error status: 0x04
                                Aux0 errors 0,0,0
                                MCU revision 3, ADC conversions started 536827, completed 536827, timed out 0, errs 0
                                MCU temperature: min 36.8, current 36.8, max 37.2
                                Supply voltage: min 24.0, current 24.1, max 24.1, under voltage events: 0, over voltage events: 0, power good: yes
                                Heap OK, handles allocated/used 99/27, heap memory allocated/used/recyclable 2048/384/32, gc cycles 1064
                                Driver 0: standstill, SG min 16, read errors 0, write errors 0, ifcnt 86, reads 651, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                Driver 1: standstill, SG min 246, read errors 0, write errors 0, ifcnt 85, reads 651, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 117, reads 652, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 122, reads 651, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 117, reads 651, writes 0, timeouts 0, DMA errors 0, CC errors 0
                                Date/time: 2023-12-09 11:47:28
                                Cache data hit count 922088436
                                Slowest loop: 8.47ms; fastest: 0.15ms
                                === Storage ===
                                Free file entries: 17
                                SD card longest read time 4.0ms, write time 4.1ms, max retries 0
                                === DDARing 0 ===
                                === DDARing 1 ===
                                Daemon is idle in state(s) 0 0 0, running macro
                                in 0 notIn 0
                                === CAN ===
                                Messages queued 112, received 251, lost 0, errs 0, boc 0
                                Longest wait 0ms for reply type 0, peak Tx sync delay 3, free buffers 26 (min 26), ts 62/62/0
                                === Network ===
                                Slowest loop: 21.95ms; fastest: 0.07ms
                                === WiFi ===
                                Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43140
                                Signal strength -50dBm, channel 6, mode 802.11n, reconnections 0
                                • Exerqtorundefined
                                  Exerqtor @Exerqtor
                                  I did a little change to daemon.g to avoid "hammering" RRF with a new global.chamber_leds value change every time it's ran, unless the value has changed from last time it was ran. Don't know if this will help this issue, but it should offload RRF a tiny bit at least:
                                      if global.chamber_leds != {state.gpOut[0].pwm * 100}
                                  Another crash btw, it happened while the machine was idle but i pulled the report while printing (if that matters):
                                  M122
                                  Used output buffers: 13 of 40 (40 max)
                                  Static ram: 102844
                                  Dynamic ram: 126540 of which 12 recycled
                                  Never used RAM 7980, free system stack 136 words
                                  Tasks: NETWORK(1,ready,18.2%,195) HEAT(3,nWait,0.0%,353) Move(4,nWait,0.0%,244) CanReceiv(6,nWait,0.1%,797) CanSender(5,nWait,0.0%,336) CanClock(7,delaying,0.0%,350) TMC(4,nWait,0.7%,74) MAIN(1,running,80.1%,580) IDLE(0,ready,0.0%,29) AIN(4,delaying,0.8%,264), total 100.0%
                                  Owned mutexes:
                                  Last reset 00:59:00 ago, cause: software
                                  Last software reset at 2023-12-09 15:05, reason: HardFault bfarValid precise, Gcodes spinning, available RAM 6040, slot 2
                                  Software reset code 0x4063 HFSR 0x40000000 CFSR 0x00008200 ICSR 0x00000803 BFAR 0x362e303d SP 0x20011f60 Task NETW Freestk 472 ok
                                  Stack: 362e303d 20032cfd 00000047 362e303c 20032ebc 0002dd33 00004434 210f0000 0002dce5 2002bed4 2002be01 000001c0 2002c100 200314b0 2002c118 2001e888 a5a5a5a5 a5a5a5a5 0002ff41 00000000 00000000 00000000 362e303d 00000800 200359c8 2002c100 20018678
                                  Error status: 0x04
                                  Aux0 errors 0,0,0
                                  MCU revision 3, ADC conversions started 3541025, completed 3541025, timed out 0, errs 0
                                  MCU temperature: min 35.9, current 40.2, max 41.2
                                  Supply voltage: min 22.9, current 24.2, max 26.1, under voltage events: 0, over voltage events: 0, power good: yes
                                  Heap OK, handles allocated/used 198/22, heap memory allocated/used/recyclable 2048/2008/1700, gc cycles 7
                                  Driver 0: standstill, SG min 0, read errors 0, write errors 1, ifcnt 179, reads 55243, writes 31, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 1: standstill, SG min 0, read errors 0, write errors 1, ifcnt 177, reads 55243, writes 31, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 2: standstill, SG min 0, read errors 0, write errors 1, ifcnt 172, reads 55253, writes 20, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 3: standstill, SG min 0, read errors 0, write errors 1, ifcnt 176, reads 55252, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                  Driver 4: standstill, SG min 0, read errors 0, write errors 1, ifcnt 171, reads 55253, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                  Date/time: 2023-12-09 16:04:56
                                  Slowest loop: 223.45ms; fastest: 0.09ms
                                  === Storage ===
                                  Free file entries: 15
                                  SD card longest read time 5.0ms, write time 4.6ms, max retries 0
                                  DMs created 83, segments created 16, maxWait 3438848ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
                                  Moves shaped first try 20, on retry 14, too short 0, wrong shape 7, maybepossible 0
                                  === DDARing 0 ===
                                  Scheduled moves 129, completed 129, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                                  === DDARing 1 ===
                                  Heater 0 is on, I-accum = 0.6
                                  File is doing "M116 H1" in state(s) 0 0, running macro
                                  Daemon is doing "G4 S10000" in state(s) 0 0, running macro
                                  File2 is idle in state(s) 0, sync state 1
                                  in 0 notIn 0
                                  === CAN ===
                                  Messages queued 31998, received 72814, lost 0, errs 1, boc 0
                                  Longest wait 6ms for reply type 6013, peak Tx sync delay 265, free buffers 26 (min 25), ts 17705/17704/0
                                  === Network ===
                                  Slowest loop: 71.81ms; fastest: 0.00ms
                                  === WiFi ===
                                  Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42944
                                    @Exerqtor please try the firmware binary at https://www.dropbox.com/scl/fo/uf8gsgetc2mfbh34hm3up/h?rlkey=bx1aavry6xplebwxhv5rx7xee&dl=0 and test it both for the WiFi resetting issue and the extruder reversal issue.
                                    I've repeated this message in your other thread so that we can keep track of the two issues independently.
                                    Exerqtorundefined 1 Reply Last reply Reply Quote 1
                                    • Exerqtorundefined
                                      Exerqtor @dc42
                                      @dc42 Ok let's see, I've installed those last binaries and the "normal" 3.5.0rc1+ release on the 1LC.
                                      After that I tried one of the jobs that failed earlier, and it completed without reversing the extruder (or crashing).
                                      I'll try some of the other jobs that has failed too now and see of they also complete.
                                      Should i still leave the "stuff" we put in daemon.g be there for a while btw?
                                      (Copying this response to the other thread too, since it's refering to the same binaries)
                                        @Exerqtor I don't think the stuff in daemon.g is relevant.
                                        Are you able to take a Wireshark trace of your browser talking to the Duet? I have a theory that the "0.6<CR>" may be from the Accept-Language header that Chrome is sending
                                        Exerqtorundefined timschneiderundefined 3 Replies Last reply Reply Quote 2
                                        • Exerqtorundefined
                                          Exerqtor @dc42
                                          Okol, i'll remove the G4 before the loop in daemon.g, and keep the rest.
                                          And I will try to look into the Wireshark trace. Have to read up on what it is first 🙈
                                          But I do also think the issue is Chrome, the last 24 hours I have only had two instances of Orca Slicer with the "Device" tab open and it haven't crashed once. If i do the same thing with two chrome tabs open it would have.
                                          • Exerqtorundefined
                                            Exerqtor @dc42
                                            I THINK, I've managed to do that trace now. But i can't see "0.6<CR>" in any of the data I managed to grab, or should i keep a trace going until it crashes and track it down?
                                            Here is a HTTP trace from Chrome:
                                            Frame 456: 475 bytes on wire (3800 bits), 475 bytes captured (3800 bits) on interface \Device\NPF_{DF4300F0-1489-452B-B73B-3870E63C20C9}, id 0
                                            Ethernet II, Src: LiteonTechno_0e:23:17 (c8:ff:28:0e:23:17), Dst: Espressif_ce:91:93 (c4:5b:be:ce:91:93)
                                            Internet Protocol Version 4, Src: 192.168.10.xx, Dst: 192.168.10.x
                                            Transmission Control Protocol, Src Port: 63171, Dst Port: 80, Seq: 1, Ack: 1, Len: 421
                                            Hypertext Transfer Protocol
                                                GET /rr_model?flags=d99fno HTTP/1.1\r\n
                                                Host: 192.168.10.x\r\n
                                                Connection: keep-alive\r\n
                                                X-Session-Key: 1319375919\r\n
                                                User-Agent: Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/120.0.0.0 Safari/537.36\r\n
                                                Accept: */*\r\n
                                                Referer: http://192.168.10.x/\r\n
                                                Accept-Encoding: gzip, deflate\r\n
                                                Accept-Language: nb-NO,nb;q=0.9,no;q=0.8,nn;q=0.7,en-US;q=0.6,en;q=0.5,sv;q=0.4,da;q=0.3,de;q=0.2,pt;q=0.1\r\n
                                                \r\n
                                                [Full request URI: http://192.168.10.x/rr_model?flags=d99fno]
                                                [HTTP request 1/1]
                                                [Response in frame: 470]
                                            And one from Orca Slicer:
                                            Frame 457: 479 bytes on wire (3832 bits), 479 bytes captured (3832 bits) on interface \Device\NPF_{DF4300F0-1489-452B-B73B-3870E63C20C9}, id 0
                                            Transmission Control Protocol, Src Port: 63170, Dst Port: 80, Seq: 1, Ack: 1, Len: 425
                                                X-Session-Key: 4102879531\r\n
                                                User-Agent: BBL-Slicer/v01.07.07.89 (dark) Mozilla/5.0 (Windows NT 10.0; Win64; x64) AppleWebKit/537.36 (KHTML, like Gecko) Chrome/107.0.0.0 Safari/537.36 Edg/107.0.1418.52\r\n
                                                Accept: */*\r\n
                                                Accept-Language: nb,no;q=0.9,en;q=0.8,en-GB;q=0.7,en-US;q=0.6\r\n
                                                \r\n
                                                [HTTP request 1/1]
                                                [Response in frame: 466]
                                            NeoDueundefined dc42undefined 2 Replies Last reply Reply Quote 0
