    how to add the z-probe status?
    Duet Web Control
    994
    • moth4017undefined
      moth4017 @Simone
      @Simone the
      DWC interface does not always update fast enough to show the z-probe status , this is normal
      • moth4017undefined
        moth4017 @Simone
        @Simone if you do a G29 do you get similar results in your console
        25 points probed, min error -0.065, max error 0.266, mean -0.012, deviation 0.062
        Height map saved to file 0:/sys/heightmap.csv
        Probe Drop Off
        Simoneundefined 1 Reply Last reply Reply Quote 0
        • Simoneundefined
          Simone @moth4017
          @moth4017 the command G29 get interrupted after 2 measures
          moth4017undefined 1 Reply Last reply Reply Quote 0
          • moth4017undefined
            moth4017 @Simone
            @Simone did you do a G32 first?
            • Simoneundefined
              Simone @moth4017
              @moth4017 same error in G32
              • moth4017undefined
                moth4017 @Simone
                @Simone is this a new build printer?
                • Simoneundefined
                  Simone @moth4017
                  @moth4017 modified ender 3 whit a E3 RRF V1.1 and the KlackEnder-Probe
                  moth4017undefined Simoneundefined 4 Replies Last reply Reply Quote 0
                  • moth4017undefined
                    moth4017 @Simone
                    @Simone have you gone through this commissioning yet?
                    https://docs.duet3d.com/en/How_to_guides/Commissioning
                    • Simoneundefined
                      Simone @Simone
                      @Simone a simple normally closed endstop switch
                      • Simoneundefined
                        Simone @Simone
                        @Simone nop i will do it!
                        • Simoneundefined
                          Simone @Simone
                          @moth4017 thank you so much for your help! I'll continue tomorrow after doing all the ceks thanks again!
                          • moth4017undefined
                            moth4017 @Simone
                            @Simone ok
                            • Simoneundefined
                              Simone
                              i see the probe push the bed down
                                droftarts administrators @Simone
                                @Simone Please send M115 in the console and post the response so we know what hardware and firmware you are using. Please also post your config.g, homeall.g and homez.g.
                                A Normally-Closed (NC) microswitch should not need inverting, ie no ! in the M558 C parameter, eg:
                                M558 P5 C"probe1" H15 F2000:300 T20000 A2 S0.01
                                I'm not sure what a Klicky probe should report when not connected, but probably '1000'. When connected it should read '0'. When triggered by touching the bed (or your finger, for testing) it should read '1000'.
                                If the probe is responding correctly, as above, most likely your homing macros are not correct, and it is still trying to find the Z endstop rather than using the probe.
                                Probe testing, see: https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_testing
                                Example homeall.g, homez.g using probe: https://docs.duet3d.com/User_manual/Machine_configuration/Configuration_cartesian#homing-z
                                • Simoneundefined
                                  Simone @droftarts
                                  @droftarts I managed to solve the problem using Pull-up resistor, but now i have onother one ahhahah,Screenshot 2023-12-14 140732.png
                                  what is z=0 datum?
                                  • Simoneundefined
                                    Simone @Simone
                                    @Simone 12f6aa17-c517-4aed-b71f-7284ee87b933-image.png found it
                                    • Simoneundefined
                                      Simone @Simone
                                      @Simone how i tell the difference in height between the probe and the nozzle to the height map?
                                        @Simone said in how to add the z-probe status?:
                                        See https://docs.duet3d.com/User_manual/Connecting_hardware/Z_probe_testing#calibrate-the-z-probe-trigger-height
                                        It would help you a lot, and speed up helping you, if you did what I asked for earlier:
                                        Please post these as text, not images. Ideally, post code within code tags, by clicking the button that looks like </> in the toolbar.
