    Problem with heaters
    • AverageUserundefined
      AverageUser
      Hi guys, im having a really bad time figuring this one out. I would really appreciate the help...
      As you can see in the picture: i have no tools/heaters... I cannot start a printing process because of that.
      Here you can see the version of my RepRap and so on.
      Here is my config:
      ; Configuration file for Duet WiFi (firmware version 3.3)
      ; generated by RepRapFirmware Configuration Tool v3.3.16 on Tue Dec 19 2023 12:57:23 GMT+0100 (Mitteleuropäische Normalzeit)
      G90                                           ; send absolute coordinates...
      M83                                           ; ...but relative extruder moves
      M550 P"Modix Big60"                           ; set printer name
      M575 P1 B57600 S1							  ; Set auxiliary serial port baud rate and require checksum (for PanelDue)
      M551 P"Big60"                                 ; set password
      M552 S1                                       ; enable network
      M586 P0 S1                                    ; enable HTTP
      M586 P1 S0                                    ; disable FTP
      M586 P2 S0                                    ; disable Telnet
      M569 P3 S1                                    ; Physical drive 3 goes forwards. X-Axis.
      M569 P4 S0                     		          ; Physical drive 4 goes backwards. X-Axis 2
      M569 P1 S1                                    ; Physical drive 1 goes backwards. Y-Axis.
      M569 P0 S1                                    ; Physical drive 0 goes forwards. E0-Extruder.
      M569 P5 S0								; Physical drive 5 goes backwards. Z-Axis
      M569 P6 S0								; Physical drive 6 goes backwards. Z-Axis
      M569 P7 S0								; Physical drive 7 goes backwards. Z-Axis
      M569 P8 S0								; Physical drive 8 goes backwards. Z-Axis
      M584 X3:4 Y1 Z5:6:7:8 E0					  ; Mapping X to phyisical drive 3 and 4, Y to drive 1, Z to 5, 6, 7, 8 and the Extruder to 0
      M350 X16 Y16 Z16 E16 I1                       ; configure microstepping with interpolation
      M92 X100.00 Y100.00 Z2000.00 E418.00          ; set steps per mm
      M566 X360 Y360 Z30.00 E120.00 P1       ; Set maximum instantaneous speed changes (mm/min)
      M203 X6000.00 Y6000.00 Z180.00 E1200.00       ; set maximum speeds (mm/min)
      M201 X1000.00 Y1000.00 Z120.00 E250.00           ; set accelerations (mm/s^2)
      M906 X1800 Y1800 Z1800 E1200 I30              ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                       ; Set idle timeout
      M208 X0 Y0 Z-1 S1                              ; set axis minima
      M208 X600 Y600 Z600 S0                        ; set axis maxima
      M574 X1 S1 P"xstop"                           ; configure switch-type (e.g. microswitch) endstop for LOW end on X via pin xstop
      M574 Y1 S1 P"ystop"                           ; configure switch-type (e.g. microswitch) endstop for HIGH end on Y via pin ystop
      M574 Z2 S2                                    ; configure Z-probe endstop for  end on Z
      M558 P5 C"^zprobe.in" H5 F120 T9000           ; set Z probe type to switch and the dive height + speeds
      G31 P500 X-14 Y21 Z0.77                           ; set Z probe trigger value, offset and trigger height
      M557 X-14:584.5 Y21:619 S66.5                      ; define mesh grid. 100 points
      M140 H-1                                      ; disable heated bed (overrides default heater mapping)
      M308 S0 P"e0temp" Y"thermistor" T100000 B4725 C7.060000e-8 R4700   ; configure sensor 0 as thermistor on pin e0temp
      M950 H0 C"e0heat" T0                          ; create nozzle heater output on e0heat and map it to sensor 0
      M307 H0 B0 S1.00                              ; disable bang-bang mode for heater  and set PWM limit
      M143 H0 S280                                  ; set temperature limit for heater 0 to 280C
      M950 F0 C"fan0" Q500                          ; create fan 0 on pin fan0 and set its frequency
      M106 P0 S0 H-1                                ; set fan 0 value. Thermostatic control is turned off
      M950 F1 C"fan1" Q500                          ; create fan 1 on pin fan1 and set its frequency
      M106 P1 S1 H0 T45                             ; set fan 1 value. Thermostatic control is turned on
      M563 P0 D0 F0                                 ; define tool 0
      G10 P0 X0 Y0 Z0                               ; set tool 0 axis offsets
      G10 P0 R0 S0                                  ; set initial tool 0 active and standby temperatures to 0C
      I dont know if this is of any help: i erased the old Firmware, i think it was 2.05 completely. Then I flashed the Duet 2 via Bossa with the Duet2CombinedFirmware.bin that i found here: https://github.com/Duet3D/RepRapFirmware/releases/tag/3.4.6 to the newest stable version 3.4.6.
      I use the super volcano hotend. Is there something special to the thermistor there maybe?
      Do i have to flash anything else onto the board? Or is the config.g false.. I would really appreciate some help. Thank you
        droftarts administrators @AverageUser
        @AverageUser said in Problem with heaters:
        M563 P0 D0 F0
        There's no heater specified in the tool. Add the heater H0 to this line, eg:
        M563 P0 H0 D0 F0
        You will want to tune that before trying to print. Run through the steps here: https://docs.duet3d.com/en/How_to_guides/Commissioning
        AverageUserundefined 1 Reply Last reply Reply Quote 1
          AverageUser @droftarts
          @droftarts said in Problem with heaters:
          M563 P0 H0 D0 F0
          Yeah that solved it! Thank you very much!!!👍 👍 👍 👍
          • droftartsundefined droftarts marked this topic as a question
          • droftartsundefined droftarts has marked this topic as solved
