Deux5 and 24V fan
I am using a 115/230Vac, 24Vdc, 14.6A, 350W power supply with Duet 2 wifi board and Deux5 board connected. I want to use the Deux5 board to run a 24V fan. Do I need to solder some jumpers or can I just plug in the fans and run them with the appropriate gcode?
@ObiWan2Print I read the information here: https://docs.duet3d.com/User_manual/Connecting_hardware/Fans_connecting
However, it is not clear if you have to set jumpers for VIN and if this is what is used with 24V fans. Can someone clarify?
Have you seen the documentation for the Duex5 itself?
https://docs.duet3d.com/en/Duet3D_hardware/Duet_2_family/DueX2_and_DueX5#power-jumpers
If your fans and VIN are both 24v you would jumper the VIN position.
Place the fan voltage select jumper in the 5V, 12V or VIN position according to your needs
