    M226 M24 Sequence not working
    423
      Why not just insert your call for the wipe macro at height instead of trying to repurpose pause and resume?
      wifibeagleundefined 1 Reply Last reply Reply Quote 0
      • wifibeagleundefined
        wifibeagle @Phaedrux
        @Phaedrux
        Well, I was hoping it would be that simple unfortunately it is not. I tried replacing the M24 with M98 P"0:/macros/wipe". After the wipe macro nothing happened, no resume. So I selected the DWC resume and the print head moved to the last position and extruded some filament then returned to the wipe position so I cancelled the print. Then I tried adding M24 to a copy of the wipe macro. That functioned just like having the M24 in the print gcode. It is a coreXY printer so the wipe mechanism is mounted to the frame of the printer vs. attached to the bed.I have attached a screen print of the CURA pause at height dialog for reference. I really do not understand the pause/resume process in enough detail.
        Most of the PETG I have printed had tolerable blobs. This 3Kg roll has many more and larger blobs even after reducing the extrusion flow. The nozzle picks up little imperfections in the previous layer(s) which eventually turns into a blob sticking to the print. I mostly print functional parts where appearance is not the primary focus but these blobs are just too big and plentiful.
        Any more suggestions/questions?
        John
        my wipe macro
        if !move.axes[0].homed || !move.axes[1].homed || !move.axes[2].homed
          exit
        if move.axes[2].machinePosition < 35
         G1 Z35 F500
        G1 X-15 Y20 F6000
        while iterations < 4
        	M280 P4 S130
        	G4 S0.3
        	M280 P4 S65
        	G4 S0.3
           continue
        M280 P4 S0
          In the processes gcode file what is the next command after your M98 call to the wipe macro?
          In your wipe macro you could store the current XYZ position as a variable and then return to that position after. It should then resume the print file I would think.
          I note that you're still using the pause at layer height tool, which is still putting it into a pause state. What I am suggesting it post processing the gcode to add the M98 call directly. No pause.
          You could even use a custom gcode of your choice that would call your macro.
          Custom GCodes
          In RepRapFirmware 2.03 and later, you can create custom GCodes, so long as the GCode is not already implemented. If you try to execute a G- or M-command that RRF does not implement, it will execute a system macro of that name if it exists. For example, if you send G40 then it will execute /sys/G40.g if it exists; and if you send M5000 then it will execute /sys/M5000.g if it exists.
          In RRF 3.4 and later this extends to G- and M-commands with fractional numbers, for example if you send M55.6 then RRF will look for file "0:/sys/M55.6.g".
          So you could use M5000 for example, then have a macro called M5000.g in your sys folder and the contents would be your wipe macro. It's been a while since I've used cura, but does it still have insert gcode at height? Then insert the M5000 command to perform the wipe.
            @Phaedrux
            The next command in the process gcode is M104 S230
            The custom code sounds like an interesting approach. I will read more in the documentation to see how I might use that technique.
            Unfortunately, cura does not have a simple way to insert gcode at height. It has insert gcode at layer change but I can't wipe every layer in a 600 layer print! Filament change is an option (M600) but with my limited understanding that seems basically like M226. There is also a time lapse script that uses a user specified Mcode to trigger the camera with a configurable pause.
            I think my basic problem is I don't understand how the system knows to return to the last print location and continue the print if I were to manually insert the wipe macro call into the gcode. That's why I'm stuck on the pause/resume approach. Can you point me to some detailed documentation to help me understand?
            John
              Phaedrux Moderator @wifibeagle
              @wifibeagle said in M226 M24 Sequence not working:
              The following gcode commands are print commands in absolute coordinates. It would just go on it's merry way. The only issue you may have is the Z height since you're raising it up some amount it seems. You'd want to store the current Z height at the start of the wipe macro and then restore it at the end.
                @Phaedrux
                As is often the case I make things more difficult than necessary. I made a copy of my wipe macro with G60 S3 at the beginning and G1 X0 Y0 Z0 F3000 at the end and it worked!
                Thank you for your help and patience. Now I'll see how it works for the 600 layer print.
                John
                  dc42 administrators @wifibeagle
                  Something is different with the M226, M24 sequence vs the DWC pause and resume.
                  M226 causes execution of the current file to pause at that point. So the M24 in that file doesn't get executed. When you manually resume, the file starts executing again, starting with the M24 command. I am guessing that the M24 command is causing the behaviour you described because it's out of context, although I would have expected it to be ignored if a file is already being executed.
                    wifibeagle @wifibeagle
                    @wifibeagle
                    FYI: I found a program called "Gcode Modifyer" that makes it relatively easy to add user gcode at any desired layer. It would be better if CURA had such a post processing feature but this beats manually editing the gcode file. I'm still trying to figure out all the possibilities.
                    https://www.youtube.com/watch?v=ikwa3nVHrO8 shows a demonstration plus links to the program.
                    In my case it inserted the following at each selected layer
                    ;G-Code Modifier DATA Start
                    M98 P"0:/macros/wipe" ;1st Command LAYER
                    ;G-Code Modifier DATA End
                      @wifibeagle
                      On second thought don't bother with Gcode Modifyer. It only allows one change before saving and reloading the file. I think it is just as easy to modify the code in Notepad+. Oh well...
                        You could still use pause at height plugin and find and replace the M226 with notepad++
                        Curious if it has a custom gcode option under method dropdown?
