    Creating a GPIO Macro to run a DC Motor
    Gcode meta commands
    • madeinta1wanundefined
      madeinta1wan
      Re: Creating a timed fan Marco and Meta
      Following on this topic, I've got a similar large format Cartesian printer with a 6HC main board and 3HC expansion boards which I've equipped with a small (M5Stack) dc motor to periodically vibrate for a second to make sure pellets are not binding in the feed passage.
      I've got the DC motor connected to the IO_1 of my 3rd 3HC and it runs (constantly, I know this is on 100%, this is just for testing) with this in my config.g -
      ; Pellet Shaker
      M950 P1 C"3.io1.out"  Q450       ; create output/servo
      M42 P1 S1 ; set 100% PWM on GPIO port 1
      What I thought I could do is modify the code that @infiniteloop and @OwenD helped @kmoore for his pellet feed-
      ; filamentmonitor.g
      ; Check filament progress, feed pellets if needed
      if job.file.fileName == null
          M99
      if {{global.filamentProgress + 11500.0} <= move.extruders[0].position} ;
          set global.filamentProgress =   {move.extruders[0].position + 11500.0}
          M106 P0 S255
          G4 S3
          M106 P0 S0
      But in my case, I'd like to switch on a fan connection on the 6HC using the M106 command and pulse the pellets a bit.
      Is there a way of adding control over the DC motor connected to the IO_1 pins within that macro?
      Thanks very much, Nate
      OwenDundefined 1 Reply Last reply Reply Quote 0
      • OwenDundefined
        OwenD @madeinta1wan
        @madeinta1wan
        You need to use M42
        https://docs.duet3d.com/User_manual/Reference/Gcodes#m42-switch-io-pin
        madeinta1wanundefined 1 Reply Last reply Reply Quote 0
          madeinta1wan @OwenD
          @OwenD Thanks, that can be run like the M106 command in the macro?
          • OwenDundefined
            OwenD @madeinta1wan
            @madeinta1wan said in Creating a GPIO Macro to run a DC Motor:
            Yes
                M106 P0 S255
                M42 P1 S1
                G4 S3
                M106 P0 S0
                M42 P1 S0
              madeinta1wan @OwenD
              @OwenD Amazing thanks very much 🤘
