Meta gcode result variable inconsistent with docs
Not sure if this is a bug with the
result
variable or an issue with the documentation but here - https://docs.duet3d.com/User_manual/Reference/Gcode_meta_commands#named-constants - theresult
variable states that clicking a "Close" button on an active, blocking M291 window should setresult
to-1
:0 if the last G-, M- or T-command on this input channel was successful, 1 if it returned a warning, 2 if it returned an error, or -1 if it was a blocking M291 message box command that had a Close button, and either the Close button was pressed or the message box timed out. Meta commands do not change 'result'.
The first problem with this is that the only message box that actually has a Close button is non-blocking (
S1
). The second problem with this is that you would assume that this would apply to Cancel buttons that can be added to other message box types (e.g.S4 J1
) - however, clicking the Cancel button on a blocking message box type appears to execute abort, or something similar to M99 and does not end up evaluating any if statement checking for the value ofresult
.I suspect this is actually a bug with
result
or the handling ofM291
message boxes as the documentation seems to express the obvious behaviour, but I thought I'd confirm first.To reproduce, run as a gcode 'job' file:
M291 P{"Blah, unimportant."} R"Big Title" S4 K{"Yes","No"} T0 J1 echo { "Result: " ^ result } echo { "Input: " ^ input }
Based on the documentation, I would expect this to return something like
-1
andnull
if I clicked the Cancel button on the modal in DWC, or0
and0
if I selected "Yes", but what actually happens is the print file is cancelled and the subsequent echo lines are not run.This makes it pretty difficult to account for users wanting to cancel out of a process (say for example during a probing routine where they selected to probe a Z surface instead of an X surface or whatever), and actually recover successfully.
When this code is run outside of a print file, it looks like the M291 just acts like
M99
which leaves any calling macros unsure of the state of the macro they ran - did the macro finish cleanly or did it abort early and not do what you expected? -
@NineMile In the short term we need to update the documentation to more correctly describe what "Cancel" does when its pressed. We need to discuss what the impact will be on existing users who are relying on cancel to abort the macro/job if we change it not to do that as a work around for your requirement you can use this
echo { "Input: " ^ input }M291 P{"Blah, unimportant."} R"Big Title" S4 K{"Yes","No","Cancel"} T0 echo { "Result: " ^ result } echo { "Input: " ^ input }
@NineMile I think the documentation meant to say Cancel instead of Close. As to it aborting instead of returning -1 I can think of a few possibilities:
- Change it to return -1 instead of aborting the macro. As Tony says, this might break macros for some users.
- Change the M291 J parameter so that J1 aborts if Cancel is pressed as now, but J2 sets result to -1 instead.
- Leave the behaviour as now but add some sort of exception-catching mechanism to meta GCode.
@T3P3Tony said in Meta gcode result variable inconsistent with docs:
@NineMile if you don't mind please raise a feature request for the J2 option as @dc42 suggests
Done - the
J2
option looks like a nice, clean way to implement both behaviours without breaking existing code. -
