    Moving several axes simultaneously - XYZ and UVW
    340
    • Salvatoreundefined
      Salvatore
      Hello everyone,
      I have built a 3D Bio-Printer and I use XYZ to move the end effector of the printer which extrudes bio-materials. At the same time, I need to control UVW in a different way and at the same time, I use UVW to control the syringe pump as you can see in the pictures, and I might want to control these pumps at the same time as the XYZ process. Is it possible to run a G-code to handle XYZ and UVW at the same time?
      197c2a3e-b858-4713-8414-1a4332cd44b7-image.png Syring pumps UVW
      For example, I would like something similar.
      I could run these two lines
      G1 U200 F0.1
      G1 U100 V100 F0.1
      while these other lines are executed independently for XYZ
      G1 X100 Y10 F600
      G1 X-100 Y10 F600
      G1 X100 Y10 F600
      G1 X-100 Y10 F600
      Could I do it?
      dc42undefined T3P3Tonyundefined 2 Replies Last reply Reply Quote 0
        dc42 administrators @Salvatore
        @Salvatore this is possible using the dual motion systems feature, which is available on Duet 3 boards running RRF 3.5. See https://docs.duet3d.com/en/User_manual/RepRapFirmware/Multiple_motion_systems.
        Salvatoreundefined 3 Replies Last reply Reply Quote 1
          T3P3Tony administrators @Salvatore
          @Salvatore one thing that is unclear to me from your description is if the syringe pumps should be synchronised with the XYZ movement or not?
          Salvatoreundefined 1 Reply Last reply Reply Quote 0
            deckingman
            ......or another approach is to post process the sliced gcode file to add the additional axes moves. That's what I used to do when I ran a CoreXYUVAB.
              Salvatore @dc42
              This post is deleted!
                Salvatore @T3P3Tony
                @T3P3Tony you are right, I was not clear. The the UVW (syringe pumps) are not sinchronised with XYZ movements at the moment. But in the future a will need it.
                  Salvatore @dc42
                  @dc42 thanks so much, I tried to follow this chapter but I had difficoultes to do that. There is an example that can be usefull?
                    @Salvatore If they need to be synchronised then rather than using multiple motion systems, you can send:
                    G1 Xnnn Ynnn Znnn Unnn Vnnn Wnnn Fnnn
                    in each command
                      Salvatore @dc42
                      @dc42 I wanted to update you that I managed to do everything and the Multiple Motion System is very powerful, thank you very much everyone!
                      • Phaedruxundefined Phaedrux marked this topic as a regular topic
                      • Phaedruxundefined Phaedrux has marked this topic as solved
