sd card almost full .. new printer set up
sys dir
is it safe to delete these files .. thanks
@Richard-F
ok im doing a override format and try and figure it out myself -
@Richard-F
NOOOO! -
@jens55 lol woops then
@Richard-F It's fine to use the Quick format option with the SD Card Formatter.
@Richard-F
ok i re-formatted copied files back on .. eveything seem ok no error msgs -
@Richard-F
If you deleted any .bin files that have 'mini5plus' in the title then you need to replace them from the release files.
What was suggested was to back up all the files, reformat the SD card, set up a single partition (boot) and restore all the files. This will give you another 6 gig of usable drive space.
If it was me, I would leave the original card alone, squirrel it away for a rainy day, get a 32 GB card and format it as a single partion. Re-install all the files and Bob is your uncle .... -
Ahhh I see you are back in business - excellent!
Keep in mind that all the print files you send to the printer are stored on the card so look at the old 'jobs' files and do some house cleaning on occasion.
@jens55
thanks for your help , if i have any more problems ill do my best to read the duet docs
