    1LC - extruder randomly stopping/reversing - ≤3.5.0-rc1
    Beta Firmware
    9
    147
    8.7k
    • Exerqtorundefined
      Exerqtor @dc42
      3.5.0-b4 on the Mini & 3.5.0-rc2 on the 1LC:
      • Extruding normally:
      M122
      RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-beta.4 (2023-06-08 23:40:14) running on Duet 3 Mini5plus WiFi (standalone mode)
      Board ID: XNHXF-HR6KL-K65J0-409N2-K9W1Z-RV2MZ
      Used output buffers: 8 of 40 (40 max)
      Static ram: 102996
      Dynamic ram: 127256 of which 0 recycled
      Never used RAM 8660, free system stack 138 words
      Tasks: NETWORK(1,ready,17.6%,195) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.2%,244) CanReceiv(6,nWait,0.0%,796) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,342) TMC(4,nWait,0.7%,74) MAIN(1,running,79.3%,704) IDLE(0,ready,1.3%,29) AIN(4,delaying,0.8%,266), total 100.0%
      Owned mutexes:
      Last reset 00:04:54 ago, cause: software
      Last software reset at 2024-03-09 09:11, reason: User, Gcodes spinning, available RAM 8888, slot 1
      Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00000000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
      Error status: 0x04
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 294487, completed 294487, timed out 0, errs 0
      MCU temperature: min 37.7, current 40.7, max 40.9
      Supply voltage: min 2.8, current 24.2, max 24.7, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1752/1304, gc cycles 68
      Events: 0 queued, 0 completed
      Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 30, reads 15452, writes 30, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 30, reads 15452, writes 30, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 15464, writes 18, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 19, reads 15463, writes 19, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 19, reads 15463, writes 19, timeouts 0, DMA errors 0, CC errors 0
      Driver 5: not present
      Driver 6: not present
      Date/time: 2024-03-09 09:16:38
      Cache data hit count 478900864
      Slowest loop: 226.06ms; fastest: 0.11ms
      === Storage ===
      Free file entries: 16
      SD card longest read time 7.5ms, write time 4.5ms, max retries 0
      DMs created 83, segments created 12, maxWait 181696ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
      next step interrupt due in 82 ticks, enabled
      === DDARing 0 ===
      Scheduled moves 213, completed 176, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 19], CDDA state 3
      === DDARing 1 ===
      Heater 0 is on, I-accum = 0.4
      Heater 1 is on, I-accum = 0.0
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 3
      USB is idle in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      SBC is idle in state(s) 0
      Daemon is doing "G4 P250        " in state(s) 0 0, running macro
      Aux2 is idle in state(s) 0
      File2 is idle in state(s) 0
      Queue2 is idle in state(s) 0
      Q0 segments left 4, axes/extruders owned 0x0000807
      Code queue 0 is empty
      Code queue 1 is empty
      === Filament sensors ===
      Extruder 0 sensor: no filament
      === CAN ===
      Messages queued 2838, received 6028, lost 0, boc 0
      Longest wait 3ms for reply type 6013, peak Tx sync delay 6616, free buffers 18 (min 17), ts 1473/1471/0
      Tx timeouts 0,0,1,0,0,0 last cancelled message type 30 dest 127
      === Network ===
      Slowest loop: 207.05ms; fastest: 0.00ms
      Responder states: MQTT(0) HTTP(0) HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 1 of 8
      = WiFi =
      Interface state: active
      Module is connected to access point
      Firmware version 2.1beta7
      MAC address c4:5b:be:ce:91:93
      Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43044
      WiFi IP address 192.168.10.x
      Signal strength -51dBm, channel 6, mode 802.11n, reconnections 0
      Clock register 00002001
      M122 B121
      Diagnostics for board 121:
      Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.2 (2023-12-14 08:58:51)
      Bootloader ID: SAMC21 bootloader version 2.8 (2023-07-25)
      All averaging filters OK
      Never used RAM 3324, free system stack 89 words
      Tasks: Move(3,nWait,0.0%,75) HEAT(2,nWait,0.4%,97) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,67) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,3.0%,57) MAIN(1,running,91.8%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.8%,114), total 100.0%
      Last reset 00:04:58 ago, cause: power up
      Last software reset data not available
      Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 18259, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 48361
      Moves scheduled 224, completed 219, in progress 1, hiccups 0, segs 12, step errors 0, maxLate 1 maxPrep 323, maxOverdue 1, maxInc 1, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 0.98
      Peak sync jitter -2/9, peak Rx sync delay 213, resyncs 0/0, no timer interrupt scheduled
      VIN voltage: min 23.8, current 24.4, max 25.2
      MCU temperature: min 51.7C, current 57.9C, max 57.9C
      Last sensors broadcast 0x00000012 found 2 4 ticks ago, 0 ordering errs, loop time 0
      CAN messages queued 6146, send timeouts 0, received 2948, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 331, adv 35855/74658
      Accelerometer: LIS3DH, status: 00
      Inductive sensor: not found
      I2C bus errors 0, naks 6, contentions 0, other errors 0
      Interrupt 5726621 to 0us, poll 4 to 1424us
      Driver 0: ok
      • Stopped extruding:
      M122
      Used output buffers: 18 of 40 (40 max)
      Static ram: 102996
      Never used RAM 8036, free system stack 128 words
      Tasks: NETWORK(2,nWait,17.4%,195) HEAT(3,nWait,0.0%,341) Move(4,nWait,2.2%,244) CanReceiv(6,nWait,0.1%,796) CanSender(5,nWait,0.0%,328) CanClock(7,delaying,0.0%,342) TMC(4,nWait,0.7%,74) MAIN(1,running,77.6%,704) IDLE(0,ready,1.1%,29) AIN(4,delaying,0.9%,266), total 100.0%
      Owned mutexes:
      Last reset 00:09:30 ago, cause: software
      Error status: 0x04
      Aux0 errors 0,0,0
      MCU revision 3, ADC conversions started 570547, completed 570545, timed out 0, errs 0
      MCU temperature: min 40.4, current 46.2, max 46.6
      Supply voltage: min 23.5, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
      Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1624/1176, gc cycles 127
      Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 30, reads 14522, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 30, reads 14522, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 14521, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 19, reads 14521, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 19, reads 14522, writes 0, timeouts 0, DMA errors 0, CC errors 0
      Date/time: 2024-03-09 09:21:14
      Cache data hit count 856469051
      Slowest loop: 36.88ms; fastest: 0.10ms
      === Storage ===
      SD card longest read time 6.1ms, write time 4.1ms, max retries 0
      DMs created 83, segments created 38, maxWait 2729ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
      next step interrupt due in 32 ticks, enabled
      === DDARing 0 ===
      Scheduled moves 4006, completed 3990, hiccups 0, stepErrors 0, LaErrors 2, Underruns [0, 0, 0], CDDA state 3
      === DDARing 1 ===
      Heater 0 is on, I-accum = 0.5
      File2 is idle in state(s) 0, sync state 1
      Q0 segments left 3, axes/extruders owned 0x0000807
      === CAN ===
      Messages queued 5946, received 5694, lost 0, boc 0
      Longest wait 5ms for reply type 6024, peak Tx sync delay 194, free buffers 18 (min 16), ts 1380/1380/0
      Tx timeouts 0,0,0,0,0,0
      === Network ===
      Slowest loop: 19.48ms; fastest: 0.06ms
      = WiFi =
      Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 39788
      M122 B121
      Never used RAM 2748, free system stack 89 words
      Tasks: Move(3,nWait,0.3%,75) HEAT(2,nWait,0.4%,97) CanAsync(5,nWait,0.0%,55) CanRecv(3,nWait,0.1%,77) CanClock(5,nWait,0.0%,67) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,3.1%,57) MAIN(1,running,91.2%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.9%,114), total 100.0%
      Last reset 00:09:33 ago, cause: power up
      Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 5970, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 338989
      Moves scheduled 2811, completed 2811, in progress 0, hiccups 2, segs 36, step errors 0, maxLate 1 maxPrep 874, maxOverdue 50, maxInc 49, mcErrs 0, gcmErrs 0, ebfmin -0.99 max inf
      Peak sync jitter -2/9, peak Rx sync delay 232, resyncs 0/0, no timer interrupt scheduled
      VIN voltage: min 24.2, current 24.4, max 25.0
      MCU temperature: min 51.7C, current 59.2C, max 59.6C
      Last sensors broadcast 0x00000012 found 2 41 ticks ago, 0 ordering errs, loop time 0
      CAN messages queued 5665, send timeouts 0, received 5916, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
      dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 350, adv 35868/74657
      I2C bus errors 0, naks 0, contentions 0, other errors 0
      Interrupt 5726621 to 0us, poll 9 to 1504us
      Driver 0: ok
      So it don't look like the issue is in the mainboard code after all, at least not only in the mainboard.
      Exerqtorundefined 1 Reply Last reply Reply Quote 0
      • Exerqtorundefined
        Exerqtor @Exerqtor
        Since I got a way to work past the probe issues i did this as well:
        3.5.0-b4 on the Mini & 3.5.0-rc3+ on the 1LC:
        M122
        Used output buffers: 27 of 40 (40 max)
        Static ram: 102996
        Dynamic ram: 127260 of which 0 recycled
        Never used RAM 8656, free system stack 150 words
        Tasks: NETWORK(2,nWait,17.5%,197) HEAT(3,nWait,0.0%,352) Move(4,nWait,0.2%,244) CanReceiv(6,nWait,0.0%,796) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,342) TMC(4,nWait,0.7%,82) MAIN(1,running,79.4%,704) IDLE(0,ready,1.3%,29) AIN(4,delaying,0.8%,266), total 100.0%
        Owned mutexes:
        Last reset 00:05:09 ago, cause: software
        Last software reset at 2024-03-09 09:24, reason: User, Gcodes spinning, available RAM 7988, slot 2
        Software reset code 0x0003 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x00489000 BFAR 0xe000ed38 SP 0x00000000 Task MAIN Freestk 0 n/a
        Error status: 0x04
        Aux0 errors 0,0,0
        MCU revision 3, ADC conversions started 309345, completed 309344, timed out 0, errs 0
        MCU temperature: min 40.7, current 43.4, max 46.9
        Supply voltage: min 3.1, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/856/408, gc cycles 73
        Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 29, reads 16231, writes 29, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 29, reads 16231, writes 29, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 16241, writes 18, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 19, reads 16240, writes 19, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 16242, writes 18, timeouts 0, DMA errors 0, CC errors 0
        Date/time: 2024-03-09 09:29:23
        Cache data hit count 506679104
        Slowest loop: 223.78ms; fastest: 0.11ms
        === Storage ===
        SD card longest read time 7.6ms, write time 4.5ms, max retries 0
        DMs created 83, segments created 12, maxWait 172094ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
        next step interrupt due in 44 ticks, enabled
        === DDARing 0 ===
        Scheduled moves 269, completed 252, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 18], CDDA state 3
        === DDARing 1 ===
        File is doing "G1 X107.869 Y122.529 E.04289" in state(s) 0
        Q0 segments left 1, axes/extruders owned 0x0000807
        === CAN ===
        Messages queued 3040, received 6331, lost 0, boc 0
        Longest wait 2ms for reply type 6053, peak Tx sync delay 5048, free buffers 18 (min 17), ts 1547/1545/0
        === Network ===
        Slowest loop: 184.60ms; fastest: 0.00ms
        HTTP sessions: 2 of 8
        = WiFi =
        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 39792
        Signal strength -52dBm, channel 6, mode 802.11n, reconnections 0
        M122 B121
        Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.3+ (2024-02-26 15:24:37)
        Never used RAM 3688, free system stack 91 words
        Tasks: Move(3,nWait 7,0.0%,91) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,55) CanRecv(3,nWait 1,0.0%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,nWait 6,3.4%,53) MAIN(1,running,91.1%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.0%,112), total 100.0%
        Owned mutexes:
        Last reset 00:05:12 ago, cause: power up
        Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 24882, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 53570
        Moves scheduled 271, completed 270, in progress 1, hiccups 5, segs 13, step errors 0, maxLate 0 maxPrep 295, maxOverdue 40, maxInc 35, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 0.98
        Peak sync jitter -2/8, peak Rx sync delay 219, resyncs 0/0, no timer interrupt scheduled
        VIN voltage: min 23.7, current 24.4, max 24.9
        MCU temperature: min 58.5C, current 61.9C, max 62.0C
        Last sensors broadcast 0x00000012 found 2 133 ticks ago, 0 ordering errs, loop time 1
        CAN messages queued 6419, send timeouts 0, received 3114, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 328, adv 35863/74658
        I2C bus errors 0, naks 3, contentions 0, other errors 0
        Interrupt 5726621 to 0us, poll 2 to 1454us
        Driver 0: ok
        M122
        Used output buffers: 21 of 40 (40 max)
        Static ram: 102996
        Never used RAM 8032, free system stack 140 words
        Tasks: NETWORK(2,nWait,17.6%,197) HEAT(3,nWait,0.0%,335) Move(4,nWait,2.2%,244) CanReceiv(6,nWait,0.1%,796) CanSender(5,nWait,0.0%,337) CanClock(7,delaying,0.0%,342) TMC(4,nWait,0.7%,74) MAIN(1,running,77.4%,704) IDLE(0,ready,1.1%,29) AIN(4,delaying,0.9%,266), total 100.0%
        Owned mutexes: WiFi(NETWORK)
        Last reset 00:09:27 ago, cause: software
        Error status: 0x04
        Aux0 errors 0,0,0
        MCU revision 3, ADC conversions started 568045, completed 568045, timed out 0, errs 0
        MCU temperature: min 43.2, current 46.0, max 46.4
        Supply voltage: min 23.5, current 24.0, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
        Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1272/824, gc cycles 128
        Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 29, reads 13609, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 29, reads 13609, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 13609, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 19, reads 13609, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 13609, writes 0, timeouts 0, DMA errors 0, CC errors 0
        Date/time: 2024-03-09 09:33:42
        Cache data hit count 860251471
        Slowest loop: 36.33ms; fastest: 0.10ms
        === Storage ===
        SD card longest read time 7.5ms, write time 4.0ms, max retries 0
        DMs created 83, segments created 38, maxWait 2148ms, bed compensation in use: mesh, height map offset 0.000, ebfmin 0.00, ebfmax 0.00
        next step interrupt due in 5 ticks, enabled
        === DDARing 0 ===
        Scheduled moves 3705, completed 3665, hiccups 0, stepErrors 0, LaErrors 2, Underruns [0, 0, 0], CDDA state 3
        === DDARing 1 ===
        File is doing "G1 X145.416 Y154.045 E.00174" in state(s) 0
        === CAN ===
        Messages queued 5454, received 5335, lost 0, boc 0
        Longest wait 6ms for reply type 6024, peak Tx sync delay 225, free buffers 18 (min 17), ts 1293/1293/0
        === Network ===
        Slowest loop: 20.02ms; fastest: 0.06ms
        HTTP sessions: 3 of 8
        = WiFi =
        Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42740
        Signal strength -50dBm, channel 6, mode 802.11n, reconnections 0
        M122 B121
        Never used RAM 3136, free system stack 71 words
        Tasks: Move(3,nWait 7,0.3%,91) HEAT(2,nWait 6,0.4%,99) CanAsync(5,nWait 4,0.0%,55) CanRecv(3,nWait 1,0.1%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.5%,53) MAIN(1,running,90.6%,315) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,112), total 100.0%
        Owned mutexes:
        Last reset 00:09:30 ago, cause: power up
        Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 63379, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 329047
        Moves scheduled 2800, completed 2800, in progress 0, hiccups 100, segs 36, step errors 0, maxLate 0 maxPrep 871, maxOverdue 95, maxInc 81, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
        Peak sync jitter -2/9, peak Rx sync delay 216, resyncs 0/0, no timer interrupt scheduled
        VIN voltage: min 24.2, current 24.5, max 24.9
        MCU temperature: min 58.5C, current 64.3C, max 64.5C
        Last sensors broadcast 0x00000012 found 2 238 ticks ago, 0 ordering errs, loop time 0
        CAN messages queued 5331, send timeouts 0, received 5502, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 381, adv 35806/107891
        Interrupt 5726621 to 0us, poll 9 to 1434us
        Driver 0: ok
        • Exerqtorundefined
          Exerqtor @Exerqtor
          And for the sake of testing, I swaped the setup around, law and behold it don't stop extruding.
          So i think we can say with some amount of certainty that the issue is within the tool board code don't you think @dc42? 🤔
          3.5.0-rc3+ on the Mini & 3.5.0-b4 on the 1LC:
          M122
          RepRapFirmware for Duet 3 Mini 5+ version 3.5.0-rc.3+ (2024-02-27 13:52:47) running on Duet 3 Mini5plus WiFi (standalone mode)
          Used output buffers: 24 of 40 (40 max)
          Static ram: 103264
          Dynamic ram: 125884 of which 24 recycled
          Never used RAM 9052, free system stack 151 words
          Tasks: NETWORK(2,nWait 7,15.8%,196) HEAT(3,nWait 6,0.0%,351) Move(4,nWait 6,0.2%,241) CanReceiv(6,nWait 1,0.1%,555) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.8%,68) MAIN(1,running,80.6%,667) IDLE(0,ready,1.5%,30) AIN(4,delaying,0.9%,260), total 100.0%
          Last reset 00:03:44 ago, cause: software
          Last software reset at 2024-03-09 09:39, reason: User, Gcodes spinning, available RAM 9400, slot 0
          Error status: 0x04
          Aux0 errors 0,0,0
          MCU revision 3, ADC conversions started 224703, completed 224702, timed out 0, errs 0
          MCU temperature: min 42.3, current 45.2, max 45.4
          Supply voltage: min 2.9, current 23.7, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/2008/1560, gc cycles 56
          Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 11755, writes 31, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 11754, writes 32, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 11762, writes 24, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 11762, writes 24, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 11763, writes 23, timeouts 0, DMA errors 0, CC errors 0
          Date/time: 2024-03-09 09:43:18
          Cache data hit count 362270903
          Slowest loop: 217.97ms; fastest: 0.10ms
          === Storage ===
          SD card longest read time 6.0ms, write time 7.0ms, max retries 0
          DMs created 83, segments created 14, maxWait 87892ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
          next step interrupt due in 63 ticks, enabled
          Moves shaped first try 7, on retry 0, too short 2, wrong shape 147, maybepossible 1
          === DDARing 0 ===
          Scheduled moves 206, completed 167, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 25], CDDA state 3
          === DDARing 1 ===
          Daemon is doing "G4 P250" in state(s) 0 0, running macro
          Q0 segments left 6, axes/extruders owned 0x0000807
          check 0 clear 0
          === CAN ===
          Messages queued 2200, received 4594, lost 0, errs 1357, boc 0
          Longest wait 3ms for reply type 6053, peak Tx sync delay 16014, free buffers 26 (min 25), ts 1122/1120/0
          === Network ===
          Slowest loop: 212.55ms; fastest: 0.00ms
          === WiFi ===
          Failed messages: pending 0, notrdy 0, noresp 0
          Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 43064
          M122 B121
          Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-beta.4 (2023-06-08 16:22:30)
          Never used RAM 1496, free system stack 88 words
          Tasks: Move(3,nWait,0.0%,111) HEAT(2,nWait,0.6%,67) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.0%,75) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,delaying,3.0%,57) MAIN(1,running,91.5%,346) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.9%,142), total 100.0%
          Last reset 00:03:47 ago, cause: power up
          Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 48316, writes 13, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 46224
          Moves scheduled 194, completed 193, in progress 1, hiccups 7, step errors 0, maxPrep 563, maxOverdue 71, maxInc 71, mcErrs 0, gcmErrs 0, ebfmin 0.00, ebfmax 1.00
          Peak sync jitter -2/9, peak Rx sync delay 215, resyncs 0/0, no timer interrupt scheduled
          VIN voltage: min 23.7, current 24.5, max 24.9
          MCU temperature: min 62.7C, current 66.0C, max 66.1C
          Last sensors broadcast 0x00000012 found 2 108 ticks ago, 0 ordering errs, loop time 1
          CAN messages queued 4696, send timeouts 0, received 2281, lost 0, free buffers 18, min 18, error reg 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 325, adv 35765/74646
          I2C bus errors 0, naks 3, other errors 0
          Interrupt 5726621 to 0us, poll 4 to 2096us
          Driver 0: ok
          • LAYER 18 / Z 16.45 (still extruding):
          M122
          Used output buffers: 23 of 40 (40 max)
          Static ram: 103264
          Never used RAM 8476, free system stack 132 words
          Tasks: NETWORK(2,nWait 7,17.0%,196) HEAT(3,nWait 6,0.0%,342) Move(4,nWait 6,2.5%,237) CanReceiv(6,nWait 1,0.1%,555) CanSender(5,nWait 7,0.1%,328) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.9%,68) MAIN(1,running,77.1%,667) IDLE(0,ready,1.4%,30) AIN(4,delaying,0.9%,260), total 100.0%
          Last reset 00:12:56 ago, cause: software
          Error status: 0x04
          Aux0 errors 0,0,0
          MCU revision 3, ADC conversions started 777401, completed 777401, timed out 0, errs 0
          MCU temperature: min 44.9, current 46.0, max 46.6
          Supply voltage: min 23.7, current 23.8, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
          Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1368/920, gc cycles 174
          Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 31, reads 29074, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 32, reads 29074, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 29074, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 24, reads 29073, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 23, reads 29074, writes 0, timeouts 0, DMA errors 0, CC errors 0
          Date/time: 2024-03-09 09:52:31
          Cache data hit count 1142083576
          Slowest loop: 32.68ms; fastest: 0.10ms
          === Storage ===
          SD card longest read time 9.6ms, write time 9.2ms, max retries 0
          DMs created 83, segments created 38, maxWait 2726ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
          next step interrupt due in 68 ticks, enabled
          Moves shaped first try 1226, on retry 351, too short 400, wrong shape 6579, maybepossible 230
          === DDARing 0 ===
          Scheduled moves 11221, completed 11183, hiccups 0, stepErrors 0, LaErrors 14, Underruns [0, 0, 0], CDDA state 3
          === DDARing 1 ===
          File is doing "G1 Z3.75 F21000" in state(s) 0
          Q0 segments left 0, axes/extruders owned 0x0000807
          check 0 clear 0
          === CAN ===
          Messages queued 14546, received 11362, lost 0, errs 0, boc 0
          Longest wait 5ms for reply type 6024, peak Tx sync delay 240, free buffers 26 (min 25), ts 2763/2763/0
          === Network ===
          Slowest loop: 20.28ms; fastest: 0.06ms
          === WiFi ===
          Signal strength -53dBm, channel 6, mode 802.11n, reconnections 0
          M122 B121
          Never used RAM 920, free system stack 88 words
          Tasks: Move(3,nWait,0.7%,111) HEAT(2,nWait,0.6%,65) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.1%,75) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,delaying,3.2%,57) MAIN(1,running,90.3%,346) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,142), total 100.0%
          Last reset 00:13:01 ago, cause: power up
          Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 13, reads 12625, writes 0, timeouts 1, DMA errors 0, CC errors 0, failedOp 0x6a, steps req 0 done 1021829
          Moves scheduled 9744, completed 9742, in progress 1, hiccups 973, step errors 0, maxPrep 1118, maxOverdue 13312, maxInc 10770, mcErrs 0, gcmErrs 0, ebfmin -0.99, ebfmax 1.00
          Peak sync jitter -2/10, peak Rx sync delay 282, resyncs 0/0, no timer interrupt scheduled
          VIN voltage: min 24.2, current 24.5, max 24.7
          MCU temperature: min 62.7C, current 70.2C, max 70.3C
          Last sensors broadcast 0x00000012 found 2 185 ticks ago, 0 ordering errs, loop time 1
          CAN messages queued 11375, send timeouts 0, received 14606, lost 0, free buffers 18, min 17, error reg 0
          dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 494, adv 35801/110985
          I2C bus errors 0, naks 0, other errors 0
          Interrupt 5726621 to 0us, poll 10 to 3404us
          Driver 0: ok
          I'm going to let the print finish just to make sure that the issue haven't moved further out in the job, but i'm quite sure it will finish. I'll report back once it's done.
          And the print finished without issues👌
          dc42undefined 1 Reply Last reply Reply Quote 2
            dc42 administrators @Exerqtor
            @Exerqtor thanks, so it does look as though it's the 1LC firmware that has introduced this issue. Please can you try upgrading the 1LC firmware to 3.5.0-rc.1 and see whether that fails or not.
            Exerqtorundefined 1 Reply Last reply Reply Quote 1
            • Exerqtorundefined
              Exerqtor @dc42
              @dc42 It sure does, I can test it out in a little while 👌
              3.5.0-rc3+ on the Mini & 3.5.0-rc1 on the 1LC:
              M122
              Used output buffers: 17 of 40 (40 max)
              Static ram: 103264
              Dynamic ram: 125500 of which 12 recycled
              Never used RAM 9448, free system stack 138 words
              Tasks: NETWORK(2,nWait 7,14.6%,196) HEAT(3,nWait 6,0.0%,351) Move(4,nWait 6,0.1%,241) CanReceiv(6,nWait 1,0.1%,796) CanSender(5,nWait 7,0.0%,337) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.8%,68) MAIN(1,running,82.6%,667) IDLE(0,ready,1.0%,30) AIN(4,delaying,0.8%,260), total 100.0%
              Last reset 00:23:02 ago, cause: software
              Last software reset at 2024-03-10 13:33, reason: User, Gcodes spinning, available RAM 9172, slot 1
              Error status: 0x04
              Aux0 errors 0,0,0
              MCU revision 3, ADC conversions started 1383174, completed 1383173, timed out 0, errs 0
              MCU temperature: min 38.0, current 44.0, max 44.0
              Supply voltage: min 2.6, current 24.2, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1204/756, gc cycles 309
              Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 30, reads 7189, writes 30, timeouts 0, DMA errors 0, CC errors 0
              Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 30, reads 7189, writes 30, timeouts 0, DMA errors 0, CC errors 0
              Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 19, reads 7200, writes 19, timeouts 0, DMA errors 0, CC errors 0
              Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 7201, writes 18, timeouts 0, DMA errors 0, CC errors 0
              Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 7201, writes 18, timeouts 0, DMA errors 0, CC errors 0
              Date/time: 2024-03-11 17:14:50
              Cache data hit count 2316538982
              Slowest loop: 299.22ms; fastest: 0.10ms
              === Storage ===
              SD card longest read time 7.5ms, write time 63.4ms, max retries 0
              DMs created 83, segments created 14, maxWait 1218190ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
              next step interrupt due in 117 ticks, enabled
              Moves shaped first try 9, on retry 0, too short 5, wrong shape 300, maybepossible 2
              === DDARing 0 ===
              Scheduled moves 334, completed 328, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 34], CDDA state 3
              === DDARing 1 ===
              File is doing "G1 X108.466 Y133.806 E.04107" in state(s) 0
              check 0 clear 0
              === CAN ===
              Messages queued 12780, received 28337, lost 0, errs 1324, boc 0
              Longest wait 2ms for reply type 6053, peak Tx sync delay 10816, free buffers 26 (min 25), ts 6914/6912/0
              === Network ===
              Slowest loop: 14.35ms; fastest: 0.00ms
              === WiFi ===
              Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42872
              	M122 B121
              Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.1 (2023-08-31 16:30:01)
              Never used RAM 3384, free system stack 89 words
              Tasks: Move(3,nWait,0.0%,75) HEAT(2,nWait,0.4%,107) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,3.0%,57) MAIN(1,running,91.5%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,112), total 100.0%
              Last reset 00:23:07 ago, cause: VDD brownout
              Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 38438, writes 12, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 65509
              Moves scheduled 356, completed 355, in progress 1, hiccups 0, segs 13, step errors 0, maxPrep 290, maxOverdue 1, maxInc 1, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
              Peak sync jitter -3/8, peak Rx sync delay 214, resyncs 0/0, no timer interrupt scheduled
              VIN voltage: min 23.6, current 24.4, max 24.9
              MCU temperature: min 46.4C, current 65.2C, max 65.3C
              Last sensors broadcast 0x00000012 found 2 230 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 28465, send timeouts 0, received 12877, lost 0, free buffers 18, min 18, error reg 0
              dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 322, adv 35697/74648
              Interrupt 5726621 to 0us, poll 4 to 1437us
              Driver 0: ok
              M122
              Used output buffers: 14 of 40 (40 max)
              Static ram: 103264
              Never used RAM 8872, free system stack 128 words
              Tasks: NETWORK(1,ready,16.7%,196) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,2.3%,240) CanReceiv(6,nWait 1,0.1%,773) CanSender(5,nWait 7,0.0%,328) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.9%,68) MAIN(1,running,77.6%,659) IDLE(0,ready,1.4%,30) AIN(4,delaying,0.9%,260), total 100.0%
              Owned mutexes:
              Last reset 00:27:12 ago, cause: software
              Error status: 0x04
              Aux0 errors 0,0,0
              MCU revision 3, ADC conversions started 1633084, completed 1633084, timed out 0, errs 0
              MCU temperature: min 43.8, current 46.4, max 46.8
              Supply voltage: min 23.6, current 24.1, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/2040/1592, gc cycles 362
              Driver 0: ok, SG min 0, read errors 0, write errors 0, ifcnt 30, reads 13146, writes 0, timeouts 0, DMA errors 0, CC errors 0
              Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 30, reads 13146, writes 0, timeouts 0, DMA errors 0, CC errors 0
              Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 19, reads 13146, writes 0, timeouts 0, DMA errors 0, CC errors 0
              Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 13145, writes 0, timeouts 0, DMA errors 0, CC errors 0
              Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 18, reads 13146, writes 0, timeouts 0, DMA errors 0, CC errors 0
              Date/time: 2024-03-11 17:19:00
              Cache data hit count 2675121857
              Slowest loop: 34.84ms; fastest: 0.10ms
              === Storage ===
              SD card longest read time 7.1ms, write time 6.0ms, max retries 0
              DMs created 83, segments created 38, maxWait 2305ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
              next step interrupt due in 272 ticks, enabled
              Moves shaped first try 253, on retry 49, too short 114, wrong shape 2260, maybepossible 58
              === DDARing 0 ===
              Scheduled moves 3593, completed 3554, hiccups 0, stepErrors 0, LaErrors 1, Underruns [0, 0, 0], CDDA state 3
              === DDARing 1 ===
              File is doing "G1 X188.696 Y188.718 E.0072" in state(s) 0
              check 0 clear 0
              === CAN ===
              Messages queued 5207, received 5155, lost 0, errs 0, boc 0
              Longest wait 4ms for reply type 6024, peak Tx sync delay 263, free buffers 26 (min 25), ts 1249/1249/0
              === Network ===
              Slowest loop: 20.16ms; fastest: 0.06ms
              === WiFi ===
              Module reset reason: Power up, Vcc 3.37, flash size 2097152, free heap 42872
              M122 B121
              Never used RAM 2832, free system stack 89 words
              Tasks: Move(3,nWait,0.3%,71) HEAT(2,nWait,0.4%,91) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.1%,77) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,nWait,3.1%,57) MAIN(1,running,90.9%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.2%,112), total 100.0%
              Last reset 00:27:16 ago, cause: VDD brownout
              Driver 0: pos 0, 568.8 steps/mm, standstill, SG min 0, read errors 0, write errors 0, ifcnt 12, reads 58528, writes 0, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 314498
              Moves scheduled 2788, completed 2788, in progress 0, hiccups 2, segs 36, step errors 0, maxPrep 840, maxOverdue 38, maxInc 37, mcErrs 0, gcmErrs 0, ebfmin -0.98 max inf
              Peak sync jitter -1/9, peak Rx sync delay 212, resyncs 0/0, no timer interrupt scheduled
              MCU temperature: min 46.4C, current 65.1C, max 65.4C
              Last sensors broadcast 0x00000012 found 2 3 ticks ago, 0 ordering errs, loop time 0
              CAN messages queued 5135, send timeouts 0, received 5266, lost 0, free buffers 18, min 18, error reg 0
              dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 351, adv 35831/110862
              Interrupt 5726621 to 0us, poll 9 to 1468us
              Driver 0: ok
              I have also identified WHEN (within a rather small margin) in the job file it stops extruding if that's worth anything?
              It completes the extrusion of line 3451, but does not extrude again when it's supposed to in line 3460, here is a snippet of the code ("first" line is 3448, "last" line is 3468):
              G1 X213.815 Y214.442 E.49134
              G1 X213.947 Y214.66 E.00721
              G1 X213.972 Y214.832 E.00489
              G1 X213.89 Y215.025 E.00591  ;      <---- Line 3451
              M205 X12 Y12
              G1 X213.598 Y215.13 F21000
              M204 P3000
              M205 X7 Y7
              ;TYPE:Outer wall
              ;WIDTH:0.522543
              G1 F7200
              G1 X213.945 Y215.33
              G1 X214.019 Y215.33 E.00282  ;      <---- Line 3460
              ;WIDTH:0.481695
              G1 X214.093 Y215.33 E.00258
              ;WIDTH:0.440847
              G1 X214.167 Y215.33 E.00234
              ;WIDTH:0.399999
              G1 X214.24 Y215.374 E.00239
              G1 X226.558 Y227.686 E.49124
              G1 X226.61 Y227.812 E.00386
                @Exerqtor thanks! I'll look at what changed in the tool board firmware between beta4 and rc1.
                PS - the extrusion amount is very small, 0.00282mm. Is that the first point in the file where it is so small?
                • Exerqtorundefined
                  Exerqtor @dc42
                  @dc42 said in 1LC - extruder randomly stopping/reversing - ≤3.5.0-rc1:
                  Np, lets hope it's rather easy to identify and patch out 😅
                  Uum, i don't think it's the first? If you have a look at the job file I included earlier you can see that it's several of the same-ish size, the same point og the previous layer for instance, here is a snippet of the exact same point from the previous layer (where it completed/didn't stop extruding):
                  G1 X214.492 Y215.123 E.49127
                  G1 X214.275 Y214.991 E.00716
                  G1 X214.104 Y214.966 E.00489
                  G1 X213.911 Y215.048 E.00589
                  M205 X12 Y12
                  G1 X213.598 Y215.132 F210001  ;      <---- Line 2631
                  M204 P3000
                  M205 X7 Y7
                  ;TYPE:Outer wall
                  ;WIDTH:0.522148
                  G1 F7200
                  G1 X213.945 Y215.332
                  G1 X214.019 Y215.332 E.00281  ;      <---- Line 2640
                  ;WIDTH:0.481432
                  G1 X214.093 Y215.332 E.00257
                  ;WIDTH:0.440716
                  G1 X214.168 Y215.332 E.00234
                  ;WIDTH:0.399999
                  G1 X214.24 Y215.375 E.00239
                  G1 X226.557 Y227.689 E.49127
                  G1 X226.61 Y227.815 E.00386
                    droftarts administrators @Exerqtor
                    @Exerqtor Is that sliced with Bambuslicer, or Orcaslicer? The M205 jerk changes mid-job are odd. Changes in jerk may be upsetting PA or something. I'd definitely try turning that off.
                    (Sorry, still haven't got my machine running yet!)
                    • Exerqtorundefined
                      Exerqtor @droftarts
                      @droftarts said in 1LC - extruder randomly stopping/reversing - ≤3.5.0-rc1:
                      @droftarts Yes it's sliced in Orcaslicer, i've got "Emit limits to G-code" un-ticked in the slicer, but it still hammers in M204 & M205 commands. We touched on it in a separate thread earlier, and i opened a issue on their github regarding it, but it haven't gotten any traction.
                      Anywho i can do a quick "replace "M205" with ";M205" in my text editor just to see how that fairs right away. And run the job another time.
                      Np, must say i'm curious to how it will react though!
                      • Exerqtorundefined
                        Exerqtor @Exerqtor
                        @Exerqtor said in 1LC - extruder randomly stopping/reversing - ≤3.5.0-rc1:
                        I just tried that, and that just makes it stop extruding at the second part of my purge line. So the M205's ain't the root issue.
                        Here is a set of reports when it's not extruding with M205 removed:
                        M122
                        Used output buffers: 2 of 40 (40 max)
                        Static ram: 103264
                        Tasks: NETWORK(1,ready,15.5%,182) HEAT(3,nWait 6,0.0%,326) Move(4,nWait 6,0.2%,240) CanReceiv(6,nWait 1,0.1%,773) CanSender(5,nWait 7,0.0%,328) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.8%,68) MAIN(1,running,81.6%,659) IDLE(0,ready,1.0%,30) AIN(4,delaying,0.8%,260), total 100.0%
                        Owned mutexes:
                        Last reset 01:47:22 ago, cause: software
                        Error status: 0x04
                        Aux0 errors 0,0,0
                        MCU revision 3, ADC conversions started 6442810, completed 6442810, timed out 0, errs 0
                        MCU temperature: min 38.0, current 46.2, max 46.6
                        Supply voltage: min 23.4, current 24.3, max 24.5, under voltage events: 0, over voltage events: 0, power good: yes
                        Heap OK, handles allocated/used 99/32, heap memory allocated/used/recyclable 2048/1720/1272, gc cycles 1382
                        Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 50, reads 56501, writes 20, timeouts 0, DMA errors 0, CC errors 0
                        Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 50, reads 56501, writes 20, timeouts 0, DMA errors 0, CC errors 0
                        Driver 2: ok, SG min 0, read errors 0, write errors 0, ifcnt 26, reads 56514, writes 7, timeouts 0, DMA errors 0, CC errors 0
                        Driver 3: ok, SG min 0, read errors 0, write errors 0, ifcnt 26, reads 56514, writes 8, timeouts 0, DMA errors 0, CC errors 0
                        Driver 4: ok, SG min 0, read errors 0, write errors 0, ifcnt 25, reads 56515, writes 7, timeouts 0, DMA errors 0, CC errors 0
                        Date/time: 2024-03-11 18:39:09
                        Slowest loop: 292.67ms; fastest: 0.10ms
                        === Storage ===
                        SD card longest read time 9.6ms, write time 45.2ms, max retries 0
                        DMs created 83, segments created 38, maxWait 4329567ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                        next step interrupt due in 99 ticks, enabled
                        Moves shaped first try 388, on retry 98, too short 144, wrong shape 3086, maybepossible 73
                        === DDARing 0 ===
                        Scheduled moves 2137, completed 2129, hiccups 0, stepErrors 0, LaErrors 5, Underruns [0, 0, 21], CDDA state 3
                        === DDARing 1 ===
                        File is doing "G1 Z.25" in state(s) 0
                        check 0 clear 0
                        === CAN ===
                        Messages queued 47396, received 98649, lost 0, errs 0, boc 0
                        Longest wait 5ms for reply type 6024, peak Tx sync delay 257, free buffers 26 (min 25), ts 24049/24049/0
                        === Network ===
                        Slowest loop: 207.34ms; fastest: 0.06ms
                        === WiFi ===
                        M122 B121
                        Tasks: Move(3,nWait,0.0%,71) HEAT(2,nWait,0.4%,91) CanAsync(5,nWait,0.0%,54) CanRecv(3,nWait,0.0%,77) CanClock(5,nWait,0.0%,66) ACCEL(3,nWait,0.0%,53) TMC(2,delaying,3.0%,57) MAIN(1,running,91.5%,316) IDLE(0,ready,0.0%,27) AIN(2,delaying,5.1%,112), total 100.0%
                        Last reset 01:47:24 ago, cause: VDD brownout
                        Driver 0: pos 0, 568.8 steps/mm, ok, SG min 0, read errors 0, write errors 0, ifcnt 14, reads 44318, writes 2, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 74258
                        Moves scheduled 2941, completed 2941, in progress 0, hiccups 4, segs 36, step errors 0, maxPrep 889, maxOverdue 0, maxInc 0, mcErrs 0, gcmErrs 0, ebfmin 0.00 max inf
                        Peak sync jitter -3/9, peak Rx sync delay 215, resyncs 0/0, no timer interrupt scheduled
                        MCU temperature: min 46.4C, current 58.2C, max 65.6C
                        Last sensors broadcast 0x00000012 found 2 224 ticks ago, 0 ordering errs, loop time 0
                        CAN messages queued 98607, send timeouts 0, received 47273, lost 0, free buffers 18, min 18, error reg 0
                        dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 328, adv 35585/110985
                        Interrupt 5726621 to 0us, poll 6 to 1585us
                        Driver 0: ok
                          @Exerqtor Can you try with the M204 commands commented out as well?
                            Moves scheduled 451072, completed 451072, in progress 0, hiccups 6856, segs 42, step errors 0, maxLate 2 maxPrep 759, maxOverdue 7315, maxInc 2784, mcErrs 0, gcmErrs 0, ebfmin -1.00 max inf
                            I just noticed that in several of the tool board M122 reports after extrusion stops, ebfmax (maximum extrusion brought forwards) shows as infinity. That gives me something to look at.
                            • Exerqtorundefined
                              Exerqtor @droftarts
                              I can give it a go this evening.
                              Goodie!
                                @Exerqtor please try this TOOL1LC firmware. It should be compatible with the 3.5.0-rc.3+ firmware you have already. I am interested in (1) any debug messages that appear in the DWC console (or alternatively on USB if you don't have DWC connected), and (2) whether extrusion still stops working properly.
                                Duet3Firmware_TOOL1LC.bin
                                • Exerqtorundefined
                                  Exerqtor @dc42
                                  @dc42 Ok I'll give it a go later today.
                                  I've got log level 3 running so i can post that whole "transcript" from when i run the test.
                                  Want me to run M122 reports as well?
                                    @Exerqtor I'd like M122 reports if it still stops extruding, or at the end if it no longer stops extruding,
                                    If it no longer stops extruding, there may be small extrusion defects where it would previously have done so. In this build I detect when the infinity occurs, produce debug info to help me determine why, and attempt to recover from it (which is where the defects may occur).
                                    • Exerqtorundefined
                                      Exerqtor @dc42
                                      @dc42 I'm running the test print now, and it's passed the point where it used to fail earlier (it's throwing debug info, so it looks like you're on to something).
                                      I'm going to let it complete and report back with the things you wanted.
                                      As of writing this reply this is the following debug that's appeared in DWC:
                                      12.3.2024, 16:52:22	Debug from 121: pex xpend=inf effsm=0.01 dsf=inf dbf=4.569
                                      Debug from 121: 0 d=inf t=0.0
                                      Debug from 121: b=inf c=7.5001e+3 a=2.6666e-4
                                      Debug from 121: 1 d=inf t=0.0
                                      Debug from 121: b=inf c=-7.5000e+3 a=-2.6667e-4
                                      12.3.2024, 16:50:07	Debug from 121: pex xpend=inf effsm=0.01 dsf=inf dbf=133.702
                                      Debug from 121: b=inf c=3.7500e+3 a=5.3333e-4
                                      Debug from 121: b=inf c=-3.7501e+3 a=-5.3332e-4
                                      12.3.2024, 16:49:46	Debug from 121: pex xpend=inf effsm=0.01 dsf=inf dbf=154.050
                                      12.3.2024, 16:49:24	Debug from 121: pex xpend=inf effsm=0.01 dsf=inf dbf=77.951
                                      Debug from 121: b=inf c=-3.7496e+3 a=-5.3339e-4
                                      12.3.2024, 16:49:03	Debug from 121: pex xpend=inf effsm=0.01 dsf=inf dbf=89.540
                                      Debug from 121: b=inf c=-3.7499e+3 a=-5.3334e-4
                                      dc42undefined Exerqtorundefined 3 Replies Last reply Reply Quote 1
                                        @Exerqtor thanks, the fact that it recovers now tells me that the infinity was responsible for the failing extrusion, and the debug tells me which of two places the infinity is generated in. You can stop the print if you wish.
                                          @Exerqtor if I produce another tool board firmware in the next 30 mins or so, will you be able to test it?
                                          • Exerqtorundefined
                                            Exerqtor @Exerqtor
                                            Well that fun didn't last long, all of a sudden i got a error in DWC that boar 121 had reconnected. Extrusion stopped at that point, and the tool heater reads offline & 2000.0C.
                                            I grabbed M122 reports once i saw what had happened, then paused and canceled the print.
                                            Here is the reports:
                                            M122
                                            Used output buffers: 1 of 40 (40 max)
                                            Static ram: 103264
                                            Dynamic ram: 128780 of which 24 recycled
                                            Never used RAM 2724, free system stack 135 words
                                            Tasks: NETWORK(1,ready,15.9%,196) HEAT(3,nWait 6,0.0%,336) Move(4,nWait 6,0.5%,238) CanReceiv(6,nWait 1,0.1%,543) CanSender(5,nWait 7,0.0%,328) CanClock(7,delaying,0.0%,340) TMC(4,nWait 6,0.8%,68) MAIN(1,running,80.8%,596) IDLE(0,ready,1.1%,30) AIN(4,delaying,0.8%,260), total 100.0%
                                            Owned mutexes:
                                            Last reset 01:06:39 ago, cause: software
                                            Last software reset at 2024-03-12 15:49, reason: User, Gcodes spinning, available RAM 8824, slot 2
                                            Error status: 0x04
                                            Aux0 errors 0,0,0
                                            MCU revision 3, ADC conversions started 4000082, completed 4000081, timed out 0, errs 0
                                            MCU temperature: min 35.7, current 46.0, max 46.8
                                            Supply voltage: min 2.8, current 24.0, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                                            Heap OK, handles allocated/used 198/33, heap memory allocated/used/recyclable 4096/2560/2100, gc cycles 788
                                            Events: 1 queued, 1 completed
                                            Driver 0: standstill, SG min 0, read errors 0, write errors 0, ifcnt 33, reads 13838, writes 33, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 1: ok, SG min 0, read errors 0, write errors 0, ifcnt 33, reads 13838, writes 33, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 2: standstill, SG min 0, read errors 0, write errors 0, ifcnt 21, reads 13850, writes 21, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 3: standstill, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 13851, writes 20, timeouts 0, DMA errors 0, CC errors 0
                                            Driver 4: standstill, SG min 0, read errors 0, write errors 0, ifcnt 20, reads 13851, writes 20, timeouts 0, DMA errors 0, CC errors 0
                                            Date/time: 2024-03-12 16:56:32
                                            Slowest loop: 217.34ms; fastest: 0.09ms
                                            === Storage ===
                                            SD card longest read time 10.0ms, write time 60.0ms, max retries 0
                                            DMs created 83, segments created 38, maxWait 3169000ms, bed compensation in use: mesh, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                                            next step interrupt due in 48 ticks, enabled
                                            Moves shaped first try 1751, on retry 490, too short 531, wrong shape 8784, maybepossible 304
                                            === DDARing 0 ===
                                            Scheduled moves 15147, completed 15107, hiccups 0, stepErrors 0, LaErrors 23, Underruns [0, 0, 1], CDDA state 3
                                            === DDARing 1 ===
                                            File is doing "G1 X183.425 Y192.988 E.00782" in state(s) 0
                                            check 0 clear 0
                                            === CAN ===
                                            Messages queued 49079, received 81477, lost 0, errs 1563, boc 0
                                            Longest wait 3ms for reply type 6013, peak Tx sync delay 25557, free buffers 26 (min 25), ts 19999/19997/0
                                            === Network ===
                                            Slowest loop: 204.80ms; fastest: 0.00ms
                                            === WiFi ===
                                            Module reset reason: Power up, Vcc 3.38, flash size 2097152, free heap 42896
                                            M122 B121
                                            Duet TOOL1LC rev 1.1 or later firmware version 3.5.0-rc.3+db (2024-03-12 08:07:55)
                                            Never used RAM 3948, free system stack 69 words
                                            Tasks: Move(3,nWait 7,0.5%,5) HEAT(2,nWait 6,0.1%,131) CanAsync(5,nWait 4,0.0%,55) CanRecv(3,nWait 1,0.2%,71) CanClock(5,nWait 1,0.0%,59) ACCEL(3,nWait 6,0.0%,53) TMC(2,delaying,3.6%,53) MAIN(1,running,91.1%,419) IDLE(0,ready,0.0%,27) AIN(2,delaying,4.6%,112), total 100.0%
                                            Owned mutexes:
                                            Last reset 00:01:08 ago, cause: software
                                            Last software reset at 2024-03-12 16:55, reason: StackOverflow, available RAM 2968, slot 0
                                            Software reset code 0x0100 ICSR 0x0042600e SP 0x20007f34 Task Move Freestk 3342 ok
                                            Stack: 20004a80 20004ab4 0001cf33 20004c98 20004938 00000000 0001c011 20003320 fffffffd a5a5a5a5 00000000 20007f8c 00000000 20007f8c 0001cc97 00000000 200017c4 20001748 0001c4d7 20001748 200017c4 00000032 454c4449 00022700 0001ac77 200018e0 200018e0
                                            Driver 0: pos 0, 80.0 steps/mm, standstill, SG min 0, read errors 0, write errors 1, ifcnt 23, reads 33962, writes 9, timeouts 0, DMA errors 0, CC errors 0, steps req 0 done 98869
                                            Moves scheduled 1525, completed 1525, in progress 0, hiccups 52, segs 20, step errors 0, maxLate 0 maxPrep 2886, maxOverdue 1344316502, maxInc 1344316502, mcErrs 0, gcmErrs 0, ebfmin 0.00 max 1.00
                                            Peak sync jitter -1/8, peak Rx sync delay 219, resyncs 0/0, no timer interrupt scheduled
                                            VIN voltage: min 24.5, current 24.6, max 24.8
                                            MCU temperature: min 67.2C, current 67.2C, max 69.5C
                                            Last sensors broadcast 0x00000000 found 0 103 ticks ago, 0 ordering errs, loop time 0
                                            CAN messages queued 587, send timeouts 0, received 2159, lost 0, errs 0, boc 0, free buffers 18, min 18, error reg 0
                                            dup 0, oos 0/0/0/0, bm 0, wbm 0, rxMotionDelay 347, adv -1344256972/74642
                                            And i'll upload the entire debug log from the point where i started the print from DWC until i canceled it "here". It's INSANELY much getting printed all of a sudden for some reason, so i'll switch to log level 1 instead. It's not added this much to the log before!
