    how to setup a hotend for directly printing metal and ceramic.
    Hardware dev
    2.2k
    • lynnmtundefined
      lynnmt @dc42
      @dc42 is there any way to make it work at faster frequencies? and or to increase the frequency of measurement at the thermocouple?
      my heater can heat and cool at ~1000 C/second, and may need to do this fairly often..
      this is almost 250C degree of change in a 4 hertz update cycle.
      I need at least 5-7 degrees C of heating/cooling precision at the heater during operation to ensure the metal in the hotend does not freeze/melt.
      • lynnmtundefined
        lynnmt @dc42
        when I run M307 per the docs,
        https://docs.duet3d.com/en/User_manual/Connecting_hardware/Heaters_tuning#setting-the-model-parameters-manually
        M307 H1 R1000 K300 D0.25 S0.1 V24
        I get the error "bad model parameters"
        are these values outside the possible ranges specified?
        the command also fails as
        M307 H1 R1000 C4 D0.25 S0.1 V24
        soare0undefined dc42undefined 2 Replies Last reply Reply Quote 0
        • soare0undefined
          soare0 @lynnmt
          @lynnmt External CAN temperature controller? This way you have control from gcode, and higher performance of controller.
          lynnmtundefined 1 Reply Last reply Reply Quote 0
          • lynnmtundefined
            lynnmt @soare0
            @soare0
            do you have a link to such a thing?
            These exist?
            soare0undefined 1 Reply Last reply Reply Quote 0
              dc42 administrators @lynnmt
              @lynnmt your original command:
              fails because K * D > 50. So reduce K or D to make it <= 50. I suspect the dead time of your heater is well below 0.25 (minimum currently supported is 0.1).
              Are you driving the heater from a main board or from an expansion board?
              • lynnmtundefined
                lynnmt @dc42
                Even when i reduce the value to 0.1 it still fails. with the same "bad model parameters" 😞
                I am driving the heater from the main board.
                it only draws about 40-60 watts of power.
                  @lynnmt this works for me for heaters on both main boards and expansion boards, using firmware 3.5.0-rc.3+:
                  M307 H0 R1000 K300 D0.1 S0.1 V24
                  lynnmtundefined 2 Replies Last reply Reply Quote 0
                  • lynnmtundefined
                    lynnmt @dc42
                    I appear to be using reprap firmware for Duet 3 MB6HC 3.3.
                    DSF version 3.4.6
                    The command M307 H1 R1000 C4:2 D0.25 S0.2 V24.0
                    also fails with the same "bad model parameters " error.
                    dc42undefined oliofundefined 2 Replies Last reply Reply Quote 0
                    • soare0undefined
                      soare0 @lynnmt
                      @lynnmt Yes, they are, but interfacing would not be trivial.
                      I worked with some, some years ago, and being straight chinese, it was a pain to use their CAN bus protocoi (as it was rather suggested than described). If you say you are 5 year old technical, then you may not want to do such gymnastics.
                      I would suggest that maybe an Arduino, with CAN and a thermocouple adaptor, may do the trick.
                      Maybe working from a DUET CAN interface board, would be better than from a mainboard? I think this is what dc42 wants to suggest.
                      Anyway, if your requirements are so ... harsh, regular PIDs may not be your best option (usually they are not designed for such high speeds, but probably some custom controller, wich... may be done on Arduino too, or on any other board like this.
                      I needed to do such stuff a long time a go, basically some ramped ON-OFF controllers, for fast precision control, but this is something needing to be tuned ... in house.
                      Normal fast thermoregulators, means 5samples/second. Super fast ones, maybe 40/sec, like these:
                      https://www.tc.co.uk/temperature_control/HA401.html
                      But the fact you can sample with 1ks/s, means nothing. and I find rather difficult to believe that you need such a speed.
                        @lynnmt I suggest you upgrade to 3.5.0-rc.3 then. I know we widened the allowed model parameters at some stage.
                        • oliofundefined
                          oliof @lynnmt
                          @lynnmt you really should be updating to 3.4.6 at least (I also would suggest leaving out the SBC which has no benefit for your current use).
                          lynnmtundefined 1 Reply Last reply Reply Quote -1
                          • lynnmtundefined
                            lynnmt @oliof
                            @oliof
                            I am using the SBC to avoid having to network interface with the Duet.
                            my internet is...unreliable at times.
                            • lynnmtundefined
                              lynnmt @dc42
                              can I actually do this upgrade if i have a Duet 3 MB 6HC V1.01A ?
                                @lynnmt yes, firmware updates can be applied to all production versions of Duet boards.
                                  @lynnmt said in how to setup a hotend for directly printing metal and ceramic.:
                                  @oliof
                                  Duets don't need an internet connection, just a local connection to your PC.
                                  • lynnmtundefined
                                    lynnmt @dc42
                                    so connecting over USB will do?
                                    • lynnmtundefined
                                      lynnmt @dc42
                                      Ok I will run this upgrade and get back to you.
                                      Thanks for the help! 🙂
                                        A local area connection to your PC is best.
                                        • lynnmtundefined
                                          lynnmt @dc42
                                          @dc42 You mean via a LAN (ethernet) port on the duet and on my laptop?
                                          what are the risks of using the SBC here?
                                          I kind of prefer to have the machine running separate from my main computer.
                                          • lynnmtundefined
                                            lynnmt @soare0
                                            @soare0
                                            I want the simplest possible solution that works reliably without too much burden on the user and costs the least amount in the long run.
                                            The conditions of printing metals and ceramics are harsh by default. I am designing around expectation values for a temperature control system that needs to at least keep up with the speed of phase change in semisolid metals.
                                            metals are dense, and excellent coolants. they also have extremely sensitive temperature specific viscosity behaviors. Their working windows are narrow, this necessitates very fast thermal cycling to enable rapid adjustments to changes in flow conditions at the deposition region. The hotend I built is designed to position an extremely wear resistant(about mohs 8.5), non-wetting(to most molten metals), high surface power density (1-10 watt/mm^2) heating element as the nozzle tip in the deposition zone. the faster we can measure and control temperature, the closer we can get to printing pure metals which have windows as thin as 1/10th of a degree C.
                                            this heater is very fast on its own, and has more than sufficient power density to keep the material flowing,and heat the underlying/surrounding layers to bonding temperature while overcoming surface conduction losses.
                                            Hence, fast control and sensing is really needed...
                                            T3P3Tonyundefined soare0undefined 2 Replies Last reply Reply Quote 0
