Accelerometer suggestion for Voron & V6 hotend & Afterburner
    aytact
    Hi, I want to buy an accelerometer for Voron & V6 hotend & Afterburner & Duet 6HC v1.01a.
    Which one do you suggest? Actually all are seem a bit similar to each other, but I am worrying about how I will mount it to the afterburner.
    I can directly mount accelerometer to Duet 6HC v1.01a, isn't it?
    Thank you
    undefined undefined 2 Replies Last reply 21 Mar 2024, 11:52 Reply Quote 0
      droftarts administrators @aytact
      @aytact See https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_Accelerometer
      Yes, you can directly connect an accelerometer to a 6HC. It needs to be of a type listed here, and support depends on the firmware version you are using: https://docs.duet3d.com/en/User_manual/Connecting_hardware/Sensors_Accelerometer#supported-hardware
      3rd party boards (ie not Duet3D boards) come in a variety of shapes and sizes. I'm pretty sure there are some community mods fit them to Afterburner.
        zapta @aytact
        @aytact, I am using the Duet accelerometer with a 3D printed adapter. Easy to install and remove without changing the baby step setting.
        https://forum.duet3d.com/topic/33664/custom-input-shaping-accelerator-board/7?_=1713546874157
