Custom Java Script in config file
I started this conversation in another thread but it warrants being in its own thread so others may search more easily.
I'm trying to execute some javascript inside DueUI. There is an example in the wiki that I'm following but without success.
Note that my javascript is "code by example" - so I do not really know what I'm doing
I'd appreciate any pointers.
The top of my DueUIConfig class looks like this:
class DueUIConfig { getProbeNum(state) { var myprobe = "No Probe"; if (Array.isArray(state.sensors.probes[0])) { myprobe = 0; } else if (Array.isArray(state.sensors.probes[1])) { myprobe = 1; } console.log("Probe Number is - ", myprobe); console.log("Probe ", myprobe); return myprobe; }; Later on I do this:
"field": "${state.sensors.probes[DueUIConfig.getProbeNum(state)].value}"
The error I get claims that :
{timestamp: Fri Mar 29 2024 11:07:37 GMT-0600 (Mountain Daylight Time), severity: 'E', message: 'DueUIConfig.getProbeNum is not a function: `${stat…rs.probes[DueUIConfig.getProbeNum(state)].value}`'}
I'm going to test it again later today but I think you're going to have to declare getProbeNum as static...
class DueUIConfig { static getProbeNum(state) { var myprobe = "No Probe"; if (Array.isArray(state.sensors.probes[0])) { -
@gtj0
declaring as static moved a step closer but "no cigar"I tried a bit of debugging. Line 4 (below) gives this error (note there is no probe 0 ). I expected a null or undefined - I suspect deeper in dueui its simply not returning anything on error ??
{timestamp: Fri Mar 29 2024 14:28:00 GMT-0600 (Mountain Daylight Time), severity: 'E', message: "Cannot set properties of null (setting 'value'): `…rs.probes[DueUIConfig.getProbeNum(state)].value}`"}
Test code:
static getProbeNum(state) { var myprobe = "1"; // set to one for testing. If statement below is failing console.log("Checking Probe"); console.log (typeof(state.sensors.probes[0].value)); console.log (state.sensors.probes[1].value); if (Array.isArray(state.sensors.probes[0])) { console.log("Probe 0 found"); myprobe = 0; } else if (Array.isArray(state.sensors.probes[1])) { console.log("Probe 1 found"); myprobe = 1; } console.log("Probe Number is - ", myprobe); return myprobe; }; I ended up backing away from
Array.isArray
and just using this. I'm unsure if the use of the globalmyprobenum
to exit the function early on successive calls buys me much ....static getProbeNum(state) { var myprobe = null; // If already know the probe number just return it if (myprobenum != null) { return myprobenum; }; // otherwise Find the active probe console.log("Checking Probe"); if (state.sensors.probes[0] != null) { console.log("Probe 0 found"); myprobe = 0; } else if (state.sensors.probes[1] != null) { console.log("Probe 1 found"); myprobe = 1; }; myprobenum = myprobe; // assign to the global variable return myprobe; }; -
@stuartofmt You've got a couple of issues...
When you were using Array.isArray, you were testing
andstate.sensors.probes[0]
which are the elements of theprobes
array, not arrays themselves so both tests will always return false.Your second attempt using the global variable will never return
1
becauseprobes
, being an array, can't have an array element at index 1 without there being one at 0.I'm guessing you're using the
K
parameter onM574
to set the probe number? That value only appears in thestate.sensors.endstops
object as theprobe
value. It doesn't control where in either the endstops or probes arrays the probe appears. If you only have 1 probe, that probe will always bestate.sensors.probes[0]
no matter what you have theK
value set to.If I guessed wrong and you're doing something else, let me know and I'll see if I can help.
My somewhat strange use-case stems from some experiments I was doing with a secondary calibration code for auto Z-offset. Because of some limitations in DSF - I could only use probe 0 for the calibration code and therefore relegated my BLT to probe 1.
When not running an auto-z-offset macro (still a wip): The default state is
state.sensors.probes[0] = null
andstate.sensors.probes[1]
is the active probe (and hence has a.value
). The object model does indeed have a element at index zero but it reportsnull
.Aesthetically - the second code attempt is a bit ugly (makes several assumptions) but does work as expected.
you were testing state.sensors.probes[0] and state.sensors.probes[0] which are the elements of the probes array, not arrays themselves
I had assumed (incorectly) that each element of the probes array was itself an array. I should have looked at the object model more closely
@stuartofmt said in Custom Java Script in config file:
: The default state is state.sensors.probes[0] = null
Interesting. So there is an entry at index 0 but it's null? Can you share the relevant config bits that produce that situation? If it's too complicated, no worries, I'm just curious.
This should clarify:
Screenshot of Object Model from DWCRelevant setting on config.g (
global.zprobe_index = 1
);Setup BLTouch as probe 1. This is to allow probe zero to be free for analogue sensor e.g. simple piezo echo "Setting BLTouch" ; K = probe number P= probe type R=Settle time before probing H=Dive Height F=Probe Speed ; T=Speed between probes A=Max probes at each pont S=Repeat deviation M558 K{global.zprobe_index} P9 C"io2.in" R1 H10 F120 T6000 A5 S-1 ;probe 5 times and average M950 S{global.zprobe_index} C"io2.out" ; This is the mod probe - used for deploy and retract G31 K{global.zprobe_index} P25 ; set trigger threshold M280 P{global.zprobe_index} S160 ; reset any error conditions```
