NeoPixel driver results
I've had good results so far with the NeoDriver.
In order to get around the inability to use M150 to control NeoPixels during printer moves, I got the $7.50 Adafruit NeoDriver card, which receives instructions for the NeoPixels via I2C, and takes care of the critical timing issue for controlling the NeoPixels.
I have it working now, using M260 to send I2C transactions. It seems to work fine, although I haven't yet had time to test it during printer moves. I think G29 will be my first attempt.
Once I got the correct transactions, it works as easily as M150 did, though quite differently. As expected, it's slower, but perfectly adequate for progress bars and the like. I'd say an update takes about 100ms. So my chasers go kind of at a moderate speed, not like greased lightning. That's fine for my purposes.
I'll update this when I have tested during moves. Hopefully the daemon will still operate during moves. That's my main concern.
Initialization script (run once - maybe from config.g):
; Initializes NeoDriver and turns off LEDs var FUNC_REGISTER_PIN = 0x01 var FUNC_REGISTER_SPEED = 0x02 var FUNC_REGISTER_BUF_LENGTH = 0x03 ;var FUNC_REGISTER_BUF = 0x04 ;var FUNC_REGISTER_SHOW = 0x05 var BASE_ADDR_NEO_PIX = 0x0E ; Parameters var I2CAddress = 0x60 var NeoPixelPinNum = 0x0F var LEDCount = 28 if exists(param.A) set var.I2CAddress = param.A if exists(param.N) set var.NeoPixelPinNum = param.N if exists(param.L) set var.LEDCount = param.L ; Set NeoDriver pin #, speed = 800,000, Buffer size var BufferSize = 3 * var.LEDCount M260 A{var.I2CAddress} B{var.BASE_ADDR_NEO_PIX,var.FUNC_REGISTER_PIN,var.NeoPixelPinNum} M260 A{var.I2CAddress} B{var.BASE_ADDR_NEO_PIX,var.FUNC_REGISTER_SPEED,1} M260 A{var.I2CAddress} B{var.BASE_ADDR_NEO_PIX,var.FUNC_REGISTER_BUF_LENGTH,var.BufferSize,0} ; Turn all LEDs off M98 P"/macros/Lights/NeoPixel/SetNeoPix" M98 P"/macros/Lights/NeoPixel/ShowNeoPix" -
SetNeoPix macro:
; Changes NeoPixel LED Color Values var FUNC_REGISTER_BUF = 0x04 var FUNC_REGISTER_SHOW = 0x05 var BASE_ADDR_NEO_PIX = 0x0E ; Parameters var I2CAddress = 0x60 var Red = 0 var Green = 0 var Blue = 0 var StartLEDNum = 0 var SetLEDCount = 1 var LEDCount = 28 if exists(param.A) set var.I2CAddress = param.A if exists(param.R) set var.Red = param.R if exists(param.U) set var.Green = param.U if exists(param.B) set var.Blue = param.B if exists(param.S) set var.StartLEDNum = param.S if exists(param.N) set var.SetLEDCount = param.N if exists(param.L) set var.LEDCount = param.L ; Set LEDs var StartAddress = 3 * var.StartLEDNum var Data = vector(7, null) set var.Data[0] = var.BASE_ADDR_NEO_PIX set var.Data[1] = var.FUNC_REGISTER_BUF set var.Data[2] = 0 set var.Data[4] = var.Green set var.Data[5] = var.Red set var.Data[6] = var.Blue while iterations < var.SetLEDCount set var.Data[3] = var.StartAddress + iterations * 3 M260 A{var.I2CAddress} B{var.Data} -
@DonStauffer ShowNeoPix macro:
; Makes NeoPixel LED Changes Visible var FUNC_REGISTER_SHOW = 0x05 var BASE_ADDR_NEO_PIX = 0x0E ; Parameters var I2CAddress = 0x60 if exists(param.A) set var.I2CAddress = param.A M260 A{var.I2CAddress} B{var.BASE_ADDR_NEO_PIX,var.FUNC_REGISTER_SHOW} -
Just to be clear, Duet 3 main boards provide a dedicated LED port that can be updated while movement is in progress. Older Duets do not, so they have to bit-bang the LEDs to meet the timing requirements, and that requires movement to be stopped.
Still a great achievement to show how to handle I2C peripherals in a more integrated fashion without depending on firmware changes to make them work. Kudos @DonStauffer !
