    Why i can't see anymore the preveuve of the sliced files?
    267
    • Simoneundefined
      Simone
      I use prusaslicer i think i dont have change anything.
      oliofundefined Simoneundefined 3 Replies Last reply Reply Quote 0
      • oliofundefined
        oliof @Simone
        @Simone we can see in the earlier gcode files that the preview is available. So either something changed in the way prusaslicer encodes the images, or the position of the preview images in the gcode file changed so that RRF cannot find it.
        It would help if you shared which RRF version you are using, and maybe the first couple hundred lines of the gcode files that do and do not show the preview image.
        Simoneundefined 4 Replies Last reply Reply Quote 1
        • Simoneundefined
          Simone @oliof
          @oliof Board: biquskr_rrf_e3_1.1 (stm32f4-wifi)
          Firmware: RepRapFirmware for STM32F4 based Boards 3.4.4_103 (2022-11-22)
          Duet WiFi Server Version: 1.27-02S-D
          • Simoneundefined
            Simone @oliof
            @oliof
            this don't show the prewew
            ; generated by PrusaSlicer 2.7.4+win64 on 2024-04-13 at 18:13:16 UTC
            ; external perimeters extrusion width = 0.52mm
            ; perimeters extrusion width = 0.54mm
            ; infill extrusion width = 0.54mm
            ; solid infill extrusion width = 0.54mm
            ; top infill extrusion width = 0.52mm
            ; support material extrusion width = 0.46mm
            ; first layer extrusion width = 0.50mm
            ;TYPE:Custom
            G90 ; use absolute coordinates
            M83 ; extruder relative mode
            M140 S70 ; set final bed temp
            M104 S210 ; set final nozzle temp
            M190 S70 ; wait for bed temp to stabilize
            M109 S210 ; wait for nozzle temp to stabilize
            G28 ; home all axis
            M572 S0.05
            G1 Z10 F240
            G1 X2 Y10 F3000
            G1 Z0.28 F240
            G92 E0
            G1 Y140 E10 F1500 ; prime the nozzle
            G1 X2.3 F5000
            G92 E0
            G1 Y10 E10 F1200 ; prime the nozzle
            G92 E0
            G29 S1
            G21 ; set units to millimeters
            M83 ; use relative distances for extrusion
            ; Filament gcode
            M107
            ;LAYER_CHANGE
            ;Z:0.2
            ;HEIGHT:0.2
            G1 X44.36 Y46.972 F12000
            G1 Z.2
            ;TYPE:Skirt/Brim
            ;WIDTH:0.5
            G1 F1800
            G1 X45.514 Y46.07 E.05288
            G1 X46.814 Y45.352 E.05362
            G1 X48.801 Y44.661 E.07596
            G1 X50.91 Y44.417 E.07666
            G1 X52.564 Y44.527 E.05985
            G1 X104.014 Y54.135 E1.88977
            G1 X105.73 Y54.662 E.06481
            G1 X107.316 Y55.462 E.06414
            G1 X108.76 Y56.528 E.0648
            G1 X109.809 Y57.602 E.05421
            G1 X110.94 Y59.191 E.07042
            G1 X178.03 Y168.864 E4.64201
            G1 X178.661 Y170.209 E.05364
            G1 X179.136 Y171.94 E.06481
            G1 X179.296 Y173.728 E.06482
            G1 X179.136 Y175.496 E.0641
            G1 X178.661 Y177.227 E.06481
            G1 X177.883 Y178.845 E.06482
            G1 X176.83 Y180.298 E.06479
            G1 X175.767 Y181.336 E.05364
            G1 X175.266 Y181.735 E.02312
            G1 X173.738 Y182.675 E.06477
            G1 X172.366 Y183.244 E.05363
            G1 X170.616 Y183.642 E.0648
            G1 X168.843 Y183.722 E.06408
            G1 X167.369 Y183.538 E.05363
            G1 X166.745 Y183.395 E.02311
            G1 X165.057 Y182.787 E.06478
            G1 X163.66 Y182.003 E.05784
            G1 X142.429 Y166.935 E.94001
            G1 X135.741 Y162.111 E.29774
            G1 X130.627 Y158.283 E.23065
            G1 X126.711 Y154.952 E.18562
            G1 X112.72 Y140.667 E.72195
            G1 X78.125 Y103.888 E1.82309
            G1 X62.919 Y87.448 E.80856
            G1 X49.547 Y71.6 E.74868
            G1 X48.714 Y70.303 E.05566
            G1 X42.148 Y59.014 E.47153
            G1 X41.389 Y57.096 E.07448
            G1 X41.051 Y54.999 E.07669
            G1 X41.065 Y53.534 E.0529
            G1 X41.314 Y52.07 E.05362
            G1 X42.012 Y50.086 E.07594
            G1 X42.944 Y48.527 E.06558
            G1 X44.319 Y47.017 E.07374
            G1 X44.319 Y47.017 F12000
            G1 X115.874 Y110.153
            G1 F1800
            G1 X116.609 Y109.768 E.02996
            G1 X117.824 Y109.658 E.04405
            G1 X118.327 Y109.789 E.01877
            G1 X118.703 Y109.983 E.01528
            G1 X119.649 Y110.855 E.04645
            G1 X120.073 Y111.65 E.03253
            • Simoneundefined
              Simone @oliof
              @oliof this does ; generated by PrusaSlicer 2.6.0+win64 on 2023-09-09 at 11:07:14 UTC
              ; thumbnail begin 32x32 1348
              ; iVBORw0KGgoAAAANSUhEUgAAACAAAAAgCAYAAABzenr0AAADuElEQVR4Aa1Xu0okQRStv9gPMN9/2G
              ; DSzWUjMwNBUYxU1kDB9bXIOr7wLcjAqMOAi6OOiqMjrB112lmHk/Uf1N7TcJvbt6tmWlAo6tpTde6z
              ; Tt0yRvyNjo5Wtre3fx8eHnY3NzeDy8vLNmaMs7OzjpZvbm7+Ql5eXg4h83rMvIZnfFtYWGhNT09/N/
              ; qvUql8PTk5+aUVMDgDSlkrksa6ZDjFa0n+OTQ09CVTDq/hgfSKN0uvMLMRLPNvkCcnJ2PeD1kaKHEh
              ; Qyd0GyzEYGDM2msJyvLs7GykQXk/y1jPv7lwr6+v60aDPj8/N1gZwiaBfKC6FrSscaWBhq2WoFoBb/
              ; YpGB4eTjhd0tgyuLkIMJAsOAaSsg8UMkB1PfTDNVKBC5RzzaBYd3V1Fd7d3cU8tra24larFciCLYtr
              ; fGGVucJiKHp7e0vCMLQkW8xy8Ldut5s0Go3ShWxYgT5qkg+azWYklT08PNjb21t7f3+fjna7nX6Ta2
              ; DI8fGxF5dlI0nCFQ1snpubSy4uLjJwAs5FAQZg1Gq1zBCeETkXa7JzRn/gsMEDACC3xJIJ/6/Djgjo
              ; 6Dw+Pua+Yb9mzVwEdJhQVFoZGZLOR0dHdnFx0e7u7kbEZlG1Wo03NjZ6tLegmKNF0UukHnlK0mPI55
              ; wrE95yCJFrDjd5YicmJhIJJIuN9sPTTDn2rq2tIQUF1sxSwOTBqUAFSw8AgjkIgoQ8HshutCZ+enqS
              ; EYiQRkTVVWOFY4jFOowYtKZXlt1QeEiHPhlMSn2peH9/P5Q5l4VUlt1cBYtIuljTyGtThDLNuwwlRh
              ; l2e3l56bpOCwyQ1zQXvZH0yUB0TSauNDDL+djt9fU1cu3DWF9fT/QpgOykYhQS8b31gcEQ5BkFhhnp
              ; 8R1bluv1etd1TRtX74ZF5GnAR0pzvyYf1+AU4ujiGMpaKxCR6tcyS2kOiXBy1Tw+Pm5nZmYsRamgUB
              ; MQcYYlnFjjylrK9QOunvD8/DwgtkuZDqBkUPqd5p7rgsIYGxuzS0tLyHHHh1sgIh+7sYF7e3vhyspK
              ; Ziy11z2iYBSXXV1dtVNTU6nHRLsRjY4r5K4rukDFvt5N9oe8eX5+PsagPAdle0LZzOY6IlejOajpZF
              ; DNbh/uCTksn90TagM/rSf0PUI+2hOmERjUu3HLphVIUM1uZR43jFuqJ9Rp6de+ccTK4O7s7PwzeK0e
              ; HBzU+oH2e/HKKPhe0hqXGLJJHXaVuOJH7oGqH5QS1KXAx279XtKnp6ed9/f3PyMjI9+g+z/BqtBwHo
              ; i26QAAAABJRU5ErkJggg==
              ; thumbnail end
              ; thumbnail begin 400x400 31256
              ; iVBORw0KGgoAAAANSUhEUgAAAZAAAAGQCAYAAACAvzbMAABbWElEQVR4Ae19W7NdxXVu/4vzA/ye1/
              ; PKeaAqVcQXoMpgu8qOISRKBCIOIATeCCQkHGMZCYEQCLRBGAMSthTHlQKLS6w4grh8K9kVJ1EeElUq
              ; SZ23/Q/W2WOdDLnVu7tnX8ZtrtW7ahgjtub8Zo+vx9djdM8xnVujn5tvvvn3Tp48efQv/uIvrt1000
              ; 0LsKeffvoK2Be+8IUt/DMNA0zf+c53/s7Hhn9mGZv/Z5r4fBwwXuBTK9j8cUJsljlnfT5Y8GvILxiv
              ; 06dPn4UY48bPav186lOf+l8PPvjgvhTxtImZm7TwZ9rYUvf3g6E1bDjJtYLhlN+0FweDc/TYwA4dOv
              ; Tenj17vgIxx42f+f/Eso7UhJcmZo1waQTD0lW8RjAsvadGMCz16+BcfDwsc65kPOD3IOaMbGTmP+BA
              ; WBG0TDBuYrZkPVKZUst9pMpGPdgkgmFYTiv9O1LYVo1zlrFhNuLGz7x+SrMODWL2BlruVWtvMOMM1L
              ; 3BjHNx0IuNm3O92CQ41/r3rXMOYtEoac3kp1c8OIlJuZqjDoaU2DiCIVV2wxEMKX0xOKd/LZ8nVJyD
              ; bGSUtAz/gMJTCQcHMXtXWZwk5yhTUJWNuEooFGUjTmxUnKPGRrU44OacNWx43bHBbvCHMuugJqZEDb
              ; k1UEvsW/Q8P/feQE8w5PbrKnOOG1tPpsSx0Auff2ywG/q55ZZbfn/37t2fcDm8h5gSE7l1YkpjqwmG
              ; ktjAaoKh1GGBcCxqOCd1cqrWTxqcs4ptHPdV/uHOOnqIqXWOvrRsxL3KmrrvFDaNsSu5rxa2Ej5pYi
              ; tZHHCU00r9aplzIxtR+IEB379//6bkGfBSYmqRsQSDBWypYCi9sk9hSwVDyZV9ylKLA0ucs4gtxzkL
              ; 2MZxX6EfrayjlJjaATDE5gdDCxPZNz8YWsPmB0Or2OCfFkTXtxCPBdENsVnm3ChpMf6AeJw/f/64FY
              ; f7xPz+97//AZhGWWjKNjY2rr777rt/YxEb+NLquKFfLQWZEJvVsXv++ed/NjjX5leIcaOkRfgDigzK
              ; jDVUKysan5C4srEWbPxVllVsIHDU72X0mr+S5nxJrWfsfM5ZwzY4V29+NWNssBP9xEpWFuqW4UTxsV
              ; khZqy0Ya0LrI8jVUO34FcrwTDHOW1sMRxU7wJRjV2Iw8qCNMW5scHe8YN9rFLdQjWJORVQNIlZgk0r
              ; GE6Jv3YwzJ1OG5ybJ+em7q29IM3xfWywN/zUbJRLE7MmwGkQszSIjC6w7dikM6XBORm/Wufc6KdV8N
              ; NyykqKmK1iJUHMVmxSwbAlq5BaHLSMgVSm1DIGUplSD+e4sbX6R5JztWMw+mllfqY++MTlFKlrcxKz
              ; 99qcwZAKG4dfKXwiwTnN5+P0q/X5wLEgpfAJ4Bob7N4P5bsd1MSknITUxKQO/NSBmjK4UmdK1H4dnB
              ; uck/Tr2GD/nx+uPlYUxORawVEQkxtb76qcAxtV8OLKtig5x5VtDc7Jc44rw1/rfloSb5S3kkqivt1z
              ; D+4ack/ZSKKG3Pr8Uth69qK4OdfTeVhiPrRkShJjZ30+rNUGO4qHxGmHWmJKOLyVmNLYalatUpvK/v
              ; 1qu8BKnbAZnGs3y5yrHQtpzkE2smvXrpvdqv5o9rEqISb3KquHmNIT2Sfm1CTVwgY2FQw1sZVwTjIA
              ; 1o5LTTCnNMucK8nOtTm3kiUtC00QU8TUdPgUMaVXWTlixiaN5Corh21unYetcc4aNrBUoNZa6MXGKI
              ; bNgl9XaoMd+1hpDWiOmFqrrBJiWpnIPjERj0Vsvl8tiK5vIee0Rdc3y5zz8QzO1dnsN9gx62jZGOM2
              ; 6BZ66dKlCxaxARmxC6w1bGCjC+zqYUPOWZ8PlgK071fL8+Gdd945OLtsxP/gkzVlxpWM35HT2moQV1
              ; yWsFnOQHDscLwsd0VuPW0kic3qfLBULUB8YNY5N5t+Wqm9DgvEnNoD0SZmDIcVYsYEg/olNUpsYINz
              ; ZWMX23cbnKvHBmaFc6l9t2PHju01W9Ka2ijXJObUilmTmCWreU1iTm1aagbDqbHTzJRKOWd9Pmj4te
              ; QUluZ8yPHdOudOnz591lRJq6aPlQYxa8gmTcwaskkTs+Z+0ouDmvtpLA6QRyW/qzEfBuf4sWlwrnQs
              ; zGywtx7PlVi1tpJfgpitq08pYrYKqUQwbPXr4NzgnLRfLXMOfl/1uC/0sQIla31wTmJSrJy4iEmBjY
              ; uYlNg4gmHNKitmnGWj3ufmzM6p/Gp9PlD7laoXFud86IkDfj8tJ/VD/VIgJTGpAwQ1MamfdV26wA4/
              ; 9D8rxbUG59qNcnHAwRGRflpcb5RTEJN7FdJDTM5VeS8xJVblPZOGa+U7ODc4l7vGOmZbbB+sAmWSaE
              ; XSSkzKVRY1MTkncu89JLC1BgtJbK2c454PrYFscK5tcWCZc5yiG44B6Qa7dB+rGidKOLyVmFIOjxGz
              ; dJwtn4azesLGOueksbVwTgIbWE2g1uKcRWxk/bRAiTg++FTyAFPEbM0IKGyKmNIOrxkXTWxTAU5adG
              ; P3nuKcpOj6NjjXh80y53L31uKcv8FenY1Y6J7rO38ub8r6DtfENvUGtObYpVJ4C9h8/1nFluKcNrbB
              ; uT6/WsZWlY34faw0gfvOt9qDySemNWzofMSmtcrKYRt9v9qwWeac9fmAC1ILC73Qr5Y5N3ncF7MO6C
              ; xpAXRo0MlUq2Q1ZdiR09JkQYNJYrULLGIDv1rDBjwbnGvHZp1zFrGBL61zbnNz8/EdJS2/ZKW5t5Aa
              ; VMvKjHg0a6m5scOVPeU5dA6/WsZmiXM+HoucQzyWOednIINzddh2bLDH+lhZIWbMyVaIObUHYhWblX
              ; p0jHNW69HUL6lR+9X6fNBekKa4ZY1zITbLnLte0soNnhYxSwKdJjGnxFWTmFPjoknMEr8OzqV9VoJN
              ; i3M5n2kuSKfGRXNBugqccxQPKT2oNQ+pjU2KmLV+kiZmzUmhwbnV5ZxkoK7xkxbnSsZCekFaMxau5I
              ; ISxOyZmBLEbL2HBDFb7yFBzB5s3JlSD+ckAnUv57ixDc61ca71+SU5V/r7rsUxFnvEcBGTChsXMSlW
              ; w1zEpOCLZc5xLQ4oOUeNjeq6nJzrve7gXPnfc7U3oiZmreKVYKMiJrWzKInJhY3ietTYODhHjc0y56
              ; zPB6uco7weJX+pF6Q9ccn13LSHmJylnd5rc9a5KYhJGRRiz91DTE6/9gZqCc61YhucG5xrvbYmNtfz
              ; AK3E5BxUH1sLMSWwgbUQUwpbKzElNpdbx6B3spXY4Fy/X2uwSR1o6OEc955F6xhQ+dVRPEQpMTWOt9
              ; YQk7KcRu1EqYns+6qUmFrYSjgnjc3nUSnnNOaDVb9anw8l8UGDczWLA0rRdVQPMDVoGoPqO98ythwx
              ; pVZZKZsipsQqK2VTi4PBuXbOaWEDG5xr96s05xz1A8SIKb3KSlmMmJoOjznXIrYYMS1hi3FOU3RDHC
              ; nOaQRA3yxzLobDGud8HNoLvRBHjHMcous4HgIdvbGxcdWCw2PYYDCtYfNJKF1OK8WG+Cz6FbBZ5hw0
              ; o7PIOcRkZaHnY7PMOevzQYJzjusBYGChs6SlQQ2xwcBawwbjdenSpQsWVqihAZ7Nzc3L0AXWGjbfr1
              ; Y5B+NmlXNWu8ACHssdatGv68o5R33BUI17j8Fx4ENsVkoJsbHTrkNPYes9esmFDf7dGuf80oZVzgEe
              ; ayvpGOeszwcLfg3Hiqt8Bea4BrXkz7UcnhtsLYfnsGkTM1VO4yRmr1+tc876fNBeHKTKaYNz7X7lwO
              ; YoLlIShDWJWUI6rUBdQjotYpbcVysYDs7JcM4iNk3OlWDT5lzud6g55yhA1zhTkpi12KSJmVplpbBJ
              ; ErN27CSD4SpxTnJxUJttS2fnNdmFdHbe4lfr84HCr64XeMsgSRCzdZAkiNnjQG5i9oioRDAsWWVRPx
              ; f380ssDixzrhebhF9brr8OnHOSoGPXoSYmlThxEZPimbmISfHMXMGQyh8ciwNqzlEH6sE5PWxgXJyj
              ; isE9nHNag0o9EFzYqIjJIUiUxKTOCCmDIfXYUV6Pi3PW50OvXzmqEJQLUurF7apyzkncpPTaPQ7jTL
              ; N7r82ZZvdemxNb7+KAswRAyTlqbP61B+dkOcONrXdB2lpOK7GW+eC0B7X3PlLYWogptQnZSkxO0fWt
              ; hZjSnLOIbXBucE4LW+l9XMkFuUH7VkNMqUH1rZSYGthKiamJreSeEgHQt5qg2zL5KbBZ5pz1+TB1Ty
              ; nRbb2nlOiG2Eru6VK/pOHw0kHTcHjN2Eg7vGZsNP06RUzrnNPGVsI5DWxTY2OFc9awgVmfD7nFEuB2
              ; MZDSq6yc81PYtAbVxxYS0wo2dK5PTG3R9S3GL03RDf06ODc4p4HNMudS2Jz/Sxa7hYIhMTVXWSXOtz
              ; Z2iMlqF1irnPMDtZUAGPOrlYVeDNvgXDs2q5zzYzByzvm/gJ0bLRESsWFHTmsDC2MFTgezhg0MnA1+
              ; tbDSivl1cK593Kx3gbW22Av9aplzVudqyDmHDsc/1K71xoDjgFK+l0GJDceq91goJzZLq9UwLbbIOf
              ; Tj4Fw7Nsucs1YxiHHOWgyOcc6lBlGbmDkHWyAmYMhh03R+CoMFYubGZ3AubynfWeJcOD6WOVdz2kga
              ; G/43TWw53yFulwOnRcyS+2oRswabtPNLx0SLmCX3tc456/NBOlMq9ZdWoE4t9GLPoIFt7pxzUxeSJm
              ; atKEgSs5ZoksSsDbySxGzBJsW5loWINOdq7mWZc5KLg8E5Gc65WodwPUAPubiJ2XN9iUypZJWVMm5i
              ; Uvh1cK7u70pwrvX6Etl5D2+4s/NV45yruQEXMSmcxkVMKqdxEJMSGzUxqTIcrkyJmnPU2Cie2fp8oF
              ; 4cUGHj5BwFNkuccy03oyImR+CiJCa1WFISk3oCUhKTw6/rwDmOBRo15ygFaXBu/pxzWoPCmY71EpM7
              ; VewhplQa20pMilUW17NLcM76fLDKuZ5AzVmuo+IcR0msd3FA4VfX+wC1xJSoz/oDVEtM6lUWpfO4J7
              ; LvI8vYahcHkgcGWgI1co4bW0swG5xr45wUNrBWzlFgcxQPUEpMyUH1nV9yTy1sJcSUFF3fSonJucrq
              ; vefg3OpyTmKhF/OXRc6V3pMam6N6gCliSq2yUpYjpobDY/e3jC12f21sU0GOapXVg80y56zPB6ucy9
              ; 1fQ3R9bFMxmHqh56gfIiSmtsNjA4hYtFZZKeeH46SxykphC4lpya9hoLbOOSvYcpyzgG1wrs1CoeDE
              ; 5jgeAIk5OnLWG2Db3Ny8bBEb4MEmedaw+ZyzILohNuucs4rNMucwMFOd1qI0Kc45LvBWJzM6fnSBbR
              ; 83i52HfWxWOWcx0PhjZ5lz1ueDhawtNOQbJ+ccx6D6zh7lhDILy2lcLwz1jF2YslsJhoNzbRZisco5
              ; /HdLApzinEVsnJxz1MBjIC0QMxdUtIlZsmloEZt2MMztYVnhXIpXg3N92CxzTnNxkOJcyysXJeaoQN
              ; ccIZMkpuUjlb7Dp55Bg5glY8JFTAps/vhaxabFual7Ds61YcPfWxfOOQrgtS8SSk2a2sGSXLW2OFKK
              ; mC3BQzIYDs7JYAOTCtQ9LxJKBOqShV7v80j5lZJzTgp0aNzE7Fk9cROz5/rcxOzxK3cwtMy53hW7BO
              ; cstzLp5Zz1+WCVc73YnPSgclyH45ocxKQK/lzErF1lTV2HGtvgnD42Dr9SPO/gXLtfe67jam/GEVSp
              ; iMlFIipsVknEgY1aLLk4R+EDas5RzgcuzlnERsk5DmzUnKPCBtbKOVcDWiKNtZhi9xKKM8XuJSZ36a
              ; QnGK4z5yyXdSyUTqawWebcKpUSHfdDtzjf4uZtCzGlsLX4SBpb64EBbmyDc31+XSXOcYpu6FerBwZq
              ; F6QuB0jS4eF9p4jJvcrqHRMp0Q3HxOrx0VJianGuJFBrc26KS4Nzq8k5rRhcwjmX+iWtQS0ZOAvYUs
              ; TUxgaWI6ZGAIyNT45zkgGw1HdWOGcRG1iKc1qie1MhrzREt9R3c+CcC3/JgsPDB/AdrO3w2CD62LQn
              ; cogNsVjCFnKME9sf/dEf3WB/+Zd/GbXvf//7S/v444+3wPDf0S5fvrz8s9TfD+/DNXYh/wfnyjlnfT
              ; 74C1IrMRixxDgH/+5851vuyGm1wSAMotVmb0hMqw0GEVvr2KEgfPOb37xBBK5cuWLGQiEKxabVr4Nz
              ; OpzjNMtxDvAA58B8bM7/hY2NjauWwdds7khigzGzOGEQG+DSLA2lrGQyQ5D1BcKSOHCITImwDM61mS
              ; 9uVuMc+tRqDA4558JUrvcYHLXDQ0dr18nDQfUFzXI5wVJpMobtwoULV86cObO1ykLRIy4oLDBmsflg
              ; 1a/W54OFBWnMh1ZiMGJJxWCzm+i5+2sTcwqbJjGnhEKbmIDrhRdeuDbEgk5UBuemOZe6v+WDG3OIc6
              ; 6EGNLEDFdZKdMgZqmwahCzFpsUMbEEBZvTcwrUcxMVEGXI5Abn6u6pkZ2X3lOrIpQTXd9cjSO4H6CF
              ; ZFLEbFkNSBIzLKeVYuMgJm5uj+xCV1AkToS1zAeJBWlLXJAK1D1xzho2V3ph7nSqZ4C4idkrUpzE7M
              ; VGRUw8zjqnILuOgrJKnItZb5ySiHOtscBinHO1N6EOhpQZBAcxa1dZOedTE5Nq7FqIObKM+YtJi6BQ
              ; zTGO7JxjPliNc5TYenzhNAeDo/xERUxObL3O51olTRETRWNOwXLYtJiUZCdcpWKqQE210ON4Zq5YYg
              ; Gb63mA1nRKYm+gh5jUCp9yWis2zhQ7RswhGusjJrHMRINzluZDT5zj3p+liHM993e9D1AbDLkd3uNA
              ; aWy1xORYZaXs4sWL10Z5aoiJ1CGQluycqpxWeq8WbFIHaLTinKN4gNKMgntln8M2dV9Jh9eOiRS2sR
              ; GuZ6+++upic3Nz8dBDDy0efvjhxcbGxuL48eOL5557bvHhhx+qYqPcgC+ZD1Nc15qrpQtSyYWej02j
              ; 87CjfIhUoNZyeAkGjTPgMefnOnJyi6410YBgumfPnmUwxUD6/PPPLz766CNTOCnsRz/60fJZ77vvvs
              ; W99957g4Ds379/8fjjjy8OHjy4ePHFF9WxSglJLhhaiCVziHOxrsgc2Bz1A8yp66UlbGA+MbmxWcw2
              ; zpw5s7j//vuXwdQXEAikTzzxxOLJJ59cqVNfIB5f+9rXigTk8OHDi5dfftkMdgkx8RdPFhZ6IbYwzk
              ; lXV1ImGYMd1wNA0y1sgMhxj17nW+0WCtg4O3JaPXqLwXRKQOCt9lUREXiWGgGx+OzcQgLz03on7rBD
              ; rRXzuyJz3cNxXBQVDztyWhpcxGax8zCusgAb9QtD1vc21lFA4HnnLiDcQoIre412HqWxxGLnYakY7D
              ; iA+4FPsn1B6aD6g2mFmDFsqXpmrc1hYxzKV6UCcv78efPPU2ItAmKpjHWFUUhy80F70Rcrp1kqsYXl
              ; NI4XI9EcJeicczVrhFPO1SZmbmx6N79gMlsOOGFALRGQv/3bv53NM+UMRbNGQOb07LBwoY4l2gvSqV
              ; ihuSAticHUmZKjBD4FjOskQM+g+tikiVkjXK3EnFO5B8pY3/jGN7ICsirigQaiUCogcyzd1WQkNat4
              ; jmBYcs+SOaixIK2NcyaO8bYOlGTXy1pBkCJmy9i1/J05Bp333ntvKSRHjhxZPPvss4u33npr8fbbb8
              ; /qGWoMRTMnIOfOnZvVM4U2JSQt3JYqG/Vg445zrWNAVRFykoNK+fc5r81JzN5r1xJzvE0+DwPRBAPR
              ; fOaZZ1ZWOGNC0rLQ820dul1zYKOoCLlWh1EEV46yEaXDVqHzsPVN12HraSAkjz322Bb1fKBa9FEuIr
              ; k6D1PFpp445zSdFF63ZzC4sfVeF/4+NbYSYkI5ZNX2DYatjrVutOfmQ29g5YwllrG1XNdJPnyJ81sG
              ; hnvTqoeY3NimfAMCsv3fhogMM2vU75D0LEh7y2klsWSVOg87bdCh1QZqybPXtcTkrH/GnB/zEwoIrP
              ; S+973vzSqwDFsvAyGhnA81scFynJN+x6QmbjmrHWotd+SccqYWNrCQmL6AwGmfl156aVZBZdj6GXU2
              ; UtrtWvrdDetxrgSbiwVDC29V5spG3OW0UufPofNwKCBoo6R1o73//vtFNqdnmrNRZyOxOWlhrk51Ht
              ; bEBjbVediFv2RhUGNALWILiaktuiE2wHPs2LGtmICArWpJ6+LFi0vb9s0NBkdkv/3tby+zstD27du3
              ; eOSRR6L26KOPJg3e14Ajt2hvvvnm0j744IPrNqexs2aU2ciIc33Y4J9hcuH8X7LaPRe7XloaVN+wI6
              ; fFsYPgCG87xwQE7NSpU7MKKKFQvP7660sDkQR74IEHFg8++ODyhbyYxcSjV0BS9thjj103+KYJGLzb
              ; MYSlzihPakH8gO6+VuMcdh7WrK6ksMU6DzscVOxQK/WWeA1wVDwLpavQEJPVzsOQgeQEBL8LYr2kBW
              ; 1OoHcU9o/afralWMTMooD4Bm+Yo8EXB8FQWCz7QNMoTmrF4pyluYrxw1oMRnxovsC5WLqktamUG1T8
              ; M4q3JzmxWSEmiu5UBoICAqt3SwEDvkr42muvLf78z//8etda36gEBEpaYPD299GjR5O2LcQ3GJWAxA
              ; xFZWQqO62nQWMYlC3HOStlrFycW26ipwBa6HqZu/e6db1sxVYjIK+88opaYADBwE/Z+tYiIN/61reW
              ; +x3+/gfui3Dh9/c8cB8Ey1a1ApISFO1vo89RRKbmqvaCNLdvaqXzcCqOAS5XchHJQF2jvNIqXXM6Ta
              ; vzcOirGgEBk+ydtbm5uewyC00EQ+GYEhB4Jtz/AOMUBypDgYFyFYpCqYhAU0U0FJN1FpSSklZNfJBe
              ; kLbEOYvYXMkFpYJhiyBIqXSrWEkQM4etVEDgd1BEOCc+iAYIRmg5AQFsuP8BeyHWglmvlYiKLyBzFR
              ; OOclxMRFpfQ5BakLYsyqVeragdA1dzca5gSCFQnCo9VU6jdgrlte+5555qAeHMQmLiEQoI4MKSFhcO
              ; 64EWzBeUlIDExMTSs2BZEvafYM8ISniAk7I9vV/S6p1rnAtSijjAWRFqESinMQhc16POlKixURKzdE
              ; UyFwFZZ8EoMRAGFJQSMXn++edVxQQyRcge/Y+DoYAAPvg4GGVXBOBw70IvNvctduK2FOdc6wNQBEOu
              ; Ny2td+SU7jwMIlIjIJzfUEfBgL0PKGdx3WeVDYQBvhMyJSbwFUcQkrNnz4pjBD5NCQjwj3Kxsl3iJK
              ; +M9JaNuEpPlJ2He67heh6iNRhK1Bpb7yGx39PbebhFuKFWbEFA4KNJnIFr3Qz3P2JiAgLim1RWAtkH
              ; HHQoERDqk3+ULVDCObdKcY4Km+t9gNqAy1nDi2GryZSkNtFaxoIC22233aYuIMP4LMxMQgEBO3DgwO
              ; KFF15gFxItAQHjEJHWOEeNw1qcc1QPMZVOSQfn2L1zgVrihEPK+ZIdOUFEYDLnBITzK4YjA5ExEAjI
              ; OGICAt9YB+MUEjgxVyIgXB0QuETEepzLYeMopznqB7De9dIyttD5nOU0LGkNAVl988XEFxBfSD766C
              ; Py+8KhiJyAcDfz5BCROcQ5SWyO4wH8YKi1ss853+/IyVlOgyDtWwk2dLIEGSEb2bt37w4B4VoVQm18
              ; CIiegZCcOHFih4CAHTp0aHHy5ElyIQF/g0E3gO9+97vL912gzCb1zFwiEsY5beEILew8zFVOc1wPsL
              ; 3i+ZnVrpeA6dKlSxc4sOGR2Ryhc2Lid+TkHgc0EBEUEM52JkNAbBgICWQdoYCgcQiJpnGJCMY5q524
              ; JWKw47goKp7/T64HaMHG1XkYgnANsUMhCTMQqcMGYHDUlzP7ABub87bMFxJfQNDeeeedWT1PzrhOZ4
              ; FZzED8WML1YiSY4wId/rlkMIwZ9x5I63l2fIs2NkbSxOTc+wCDTVXNIDIsbiAkkHWEAgLv6sDLfquS
              ; jVB9VyQVM6gXpK1xLrcHQo3NUV1oKhBrqnQJth6V7n0Z6uOPP97aXgkmx0WCmLXZU61B+WpkILYNhM
              ; IXEhCQp556ammrko30isjUYlj7FFZJnDN1Cqu2Q61G18uady1qsVEGxRy5OYkpEdjxtJdG0BhWZygk
              ; voCAQTZi/cNjJdYiIjXzr3dB2mI1wkAZg13PX9Z+C5LjHjWZEkdAzG2ycxCTO/MAwzeTV7GT7iobZB
              ; 2+gIDB0W/u47cSBryXinNanbg5/l5orgc4RY8Yq10vp1QagjwnwUuykR5iSmYDMFlBQKTuN4zOIBuB
              ; zMMXELBVyEamjtZb7oV10039e8sUFSHXApqjEySFSlM7K/Ws3OLhWyojaX1W6TISZh8Smc4wPgMh8Q
              ; UEbe7ZSO3cbzXKspGlGOykbpQzyu+BUCt9LFOS/GofGtwzJiYlmRKIhgZmMPyC4ChfrYZB5hGKiBa3
              ; KCyW6feu7DljlGScKzGnCTq0VpXuLafVjIGVjWAUFDBoY33x4sVr8E8UCwuTGktXI/tYLYOsI2zIee
              ; rUqVk9g2/+UXqpTty1cU6qq0eteLrSwCl1LK3mftLYHnvssa05TQxNg2Z6FrMP+HY6GrTXeOONN26w
              ; Z555ZmlHjx5dHDt2bIe9+eabS8OvBoK9//77Zp5PymD/A7MRPGEHIjLXfRFYfGnEOalO3DVWUxFyuV
              ; /S7FA7lU5JnHDwTXLfY+7mi4dW9gEC8frrry8N3rB/8MEHlw39QoNvxu/bt2+HQeO/mH3961/fYRsb
              ; G8smgcePH79u0PMJBUbj+aUMshEUELQ5igi8iyURR1rinNbLiSWdh13sl6QVr0YktLDNuc4rabhpji
              ; Z1z9dee20ZvOBt9wceeGCHSQhIaPAtczT4RgeKisSYSBrMDV9AYNEwRxGRjCdTImEtBvs4/HKaC39J
              ; U/Fi5oPVGtTxAlyZ+ZkHZ+kKv58O5RMQjNAsCohv0M4cBAW60mp+t5zSQDB8AQGb26LrD/7gDxaScS
              ; WMc5KduFtiMMZhH5vDX4L/KN0FtuYBEJu0sI3SVZmF4gH/Tnl9FA34vgTa/fffP1sBCQ0EZRXEBPZB
              ; UEDmJCKw2NEUEIxz0CVcI86VGHYe9oXNwf+EGYilB/CxafTTGqWraeMSj83NzaXt3r37BuFYRQFZJT
              ; GBOeOLyBzKWZA5aQpILAZbyUByMdjFNsqtfAgqVk6T7Kc1so+8YYNESvGALANFw7d1EhDf4EuCcxQT
              ; FJE5LMBwAaQlILHXEDT6aU2Jh//niG3yFJbGfkiJAktkStaJr2mwaY0Bm0I8QDjgTWcQhlA81llA8F
              ; vmcxSSOWQewGPk7/aCcS3jXMxKqj3XN9F7LyQ9qD42LpUeG+fpCRcG7h7xCPc1hoDEBQQNPkm7Khvv
              ; Wob7afCtdn8B9MILL1yRjnMlwmA5BruSC0qUjXrKZtQnx0bpaqfBp2hRPMLA3SIeOIFjwjAEJC0gBw
              ; 4cWH5BEL4kOIQkb1BiBW6CYVcEMORPKCCQgXCXjXr2NyQqQrFyWreAUDw893UpVXpsnP/O/NUaigcG
              ; bhCUluvBtdAkBWTXrl1L+9KXvrQ4cuTItdOnT1/5kz/5k63PfOYzC998Lnz2s5+N2pe//OWlHT169N
              ; rhw4e34FkkBQRtCMlOrob7cqGlBAT3QLjKRpZ7YbVe19XeiLpshNkDxbXAelV6ZB//32Aj2w/WoYDU
              ; igf8vi8cnALyxS9+8bp9+tOfjnKOagLGsnMUma985StLjJwCAvbkk08uXnzxxZX59GwtT8F8Tvmi0C
              ; Ig6FeqQE19KIm6ItRTwXEaN8W/z1XX67n2Omcf/rHZMGijgLRkHVj64hAQEPw777xzaZY597nPfW5p
              ; KCrUAgJfDwQDIbHKL0rDvbN77713adQCgtYbqCU4p4nN9TxAq0pLnCxoyZTWLfvw3+iGyZQL2vB7LV
              ; mHn7VQCMhdd90FJYpr2yWias5x149rOQeCAuOy/TxbVAKCtgpfDYwZ7GsgXyUEpCfQSnKuNQb3Cpuj
              ; eIhSldZ4EbBGrFYx+8DOs7iZCI0Ft8dkOWHCYB4L2iAcLfcNxaNHQD7/+c8v7rjjjh2TpoRznCvA3D
              ; 1LAwdOfsxQwuykVUDwq4GWudnCKQj4yCUpAVklzlGX0xzlA+QGTWNQ/UGbwnbhwoUrc5hE0II8PAUE
              ; rcehBbl/iig8bQQbySAcaDkBOXTo0LKU1TPJcaK3Csgf/uEfLoVjlTmX+u8oJjCGPQKyKp+eBYPFj8
              ; 8raQEJ/ZbrUDtHzrWao36AWApv4a12xJHqegntnK1PIkjf4TRRKCCPPPLIjmOotQICwQZEA47rtuLz
              ; xaNVQCDTuOWWW7o4Z6WTQo5zpRlKKCS1ArIKXw3EN8UtCEiKX1Y4l8qUuMppjuMhMChvbGxctdTTxc
              ; cGjcF8bFdmMJHgLDuVgMC1cA+EApu/QmwREL9E1epXmCBz4lytQVYGga5FQDQ/a9xj/ucBuAWklXOa
              ; WQc356bMcT0ADGzYudGK+Z2HQZHnsHmOEwkEBL6MVyIgR44cWRqUveDDShDkOVqs40tatQICotErHD
              ; G/WuUczAeKbte33nrrchFQKyBz/PSs/wIgp4Dcc889XX5ddc6lzFFfMFRjrX5auUFFbIiVYmWGm9Xw
              ; wSCOF7u42qT3WPjxqBoBoRQOy5wLSxuUJxBRSGoEBOzll1+exb5Iil8cAlLbSHFdOReao7xYKpWzkO
              ; KlMPR+5xxKQEBgKBFBWwxoawEvi0HzO6oXu7AGrPV52JLJXSoglMIxV85R18tBSGoEZC5fDQzfKOcS
              ; kJJ3iGJ+DQOydc5xYHMUFymZEBL9tHKDmrpvT/YBBAcSxgQENjthIlNkN0h8ri/8UYjHlIDUTlJqzk
              ; nybYpzaNTz4e67764SEOsiEgoBtYDAYqYm8ygRCAucy/0ONeccBegaZeNMp1qwtQZ4mHxA1CkB6c0a
              ; MPuwUrpKiUdKQKiFYxU41/P7UwbZCOyTlQqIpaw25Bm1gMA+xzYHmrLgwbm4uV7gLUorceStZJB6Ns
              ; 9rBKRnlYfktzKpcyu7UEC4xKOFN1Y4l8NG3VG6VEBeeeUVE/yiFBAUC7DeD0W18kbixelWoaLKlFwP
              ; 6N6BKUnzW5xW6vCe8hIeW+XMQDBgW8k+/BMxOQHZ/v9b1Ck8Fec4yqhU4kS9ar3tttuWp/GmBAS6E1
              ; g74lsrINt/tgUtbii/KmiZc5QxuIdzTgs4GqVK12LrnTQlAtK7x2Il+wi/e54SEMw6KIMhdWCl5DDH
              ; fKCqoXvvY21NCUiriHB2AC4REL9bATXnKIP+HDjXcj1XcxPOdIyi66V040Rs7JYSkHPnznVdu/VjTR
              ; riARaWrHpX5tQTJYatl3Nc86E3gIVjB3yfEpAWEeEUkNwprNQ+Rm+ckuJc6zU4y7At88FpD2rvfVqx
              ; Ub48CO0/4B0QeGHvzTffJHkPBCYPTBauyVlqU/seJS9htRBTmnMWsbUEw9zfgZLWlICA1fCDs+uv/7
              ; 3yMMOdssE5Gc65EuDcoMMHKFXpnkG13tYBJouF77JP7XuUvsFbQ0zuzW4KzkkeRafuArt3796sgNTM
              ; DRAQzqPAuQyXKj5o9LGquSfHXnHpfJi6p0v9kpTiTTk/ho2inCYVgFsMy1fa731Mla7ghAslMS1wzv
              ; p8SN2/dqEH5daUgNSICIgH52IMOdi6OT61OND2q/X5kLs/4HaxX5JWvJzzY9h6B9V67yssM2himCpd
              ; 1YpHjJgS3UKtcI4KWxgMe7ChiMQEpLSUBQICrVE4uXjixInusctxTtqPq8Q55/8Sd+fGVsMHoCqnWR
              ; cQC9lHrnTVIx4hMS1zDrBJlzZKzJ/AveU0EJGUgJRmFhIvI8KCqnfcLHPOx2aVc4jLX+g5/xewc6P2
              ; KjAGHrvnUgyshb2FlGH5ShtD755HqV/XhXPU2GDcqLrAQvfmniwEMhCJPUUKERmco+WcCzdzJN6erA
              ; WOikd1Rt7yBjqcPNEWuFT2QSUe68g5SmwcXWB7shD4HamWKHAvqCC0cM4fN6ucQ2xz4ZxLDSIVMalA
              ; x/5bKzbLAgLioVm+ymUf3H5dZc71Wu7UDkW9/Pbbb2/OQmAfBAREcl7VZCOp8aF4F4ibc5rYSjjncu
              ; C0NnJK7ttz9E4yILdMDO37x8SDokVEyaaldc5Znw89q1bIMFuzEChjwe9Kd/edykhK9k398fVfuIRr
              ; h9aS/awy59zUhSTTqRZRqFXpOZzA0rx/rJNp76Z5rShY55zkqrWW372ZUkpESgI5/J5WY0Y/wIOVcM
              ; 4Xi48//rjqu0A9+zEtoqDBuZLfdTUX5Uzhe1aeNQ6xLCBQPoI9EM37hwLSu+/R41fLnOPOlHrnQ89J
              ; ntimekkWUnt6S1JYfKO89rpzzkkSMwe8V11L65mWBQTEQ3P/A9unUJSuqFJvbs5RYKNeGVIFitZ5Fd
              ; sPKd1Mx98/f/68Go+l50yNP6jmA3V23so5J0lMKtA917R8hFcz+wDz2rF3la44/EoVqDk514uNQyxb
              ; hTwsZZWesvJFxHq7ICqb2hexzrkebE7rxpzpWE6lh4DEDctXKCCtpSuObIGKM5wlsVXsPNwiIGD+37
              G1 F2400
              G1 X75.711 Y70.841 E.92163
              Simoneundefined 1 Reply Last reply Reply Quote 0
              • Simoneundefined
                Simone @Simone
                found the problem!
                • Simoneundefined
                  Simone @Simone
                  @Simone why 2 thumbnails?
                  • Simoneundefined
                    Simone @Simone
                    @Simone This is how i fixed the probem!
                    • Simoneundefined
                      Simone @oliof
                      @oliof thx for the help!
                      • oliofundefined
                        oliof @Simone
                        @Simone there are two versions of the thumbnail so the PanelDue display can show the 32x32 one. Glad you got this sorted out! Also, for slightly smaller size, you can use QOI format.
