    Duet PI Bookworm Motion install failure
    Firmware installation
    • Alex.crundefined
      Alex.cr
      @chrishamm
      Hoping you or someone else can help me out. I am trying to install the Motion plugin through DWC. I have upgraded to Bookworm (64 bit) and have all of the latest updates and firmware, 3.5.1. I am using a Pi4.
      When installing the plugin I am running into an error as seen below. Any ideas?
      Voron2.4/Duet3 SBC+6HC+3HC+1LC+1HCL(x2) - Delta/Duet2 Wifi - CubePro/Duet2 Wifi+Duex5 - Laser/Duet3 Mini5+ - Cel Robox - U̶p̶3̶0̶0̶+/D̶u̶e̶t̶3̶ ̶6̶H̶C̶+̶LC1̶ - F̶T̶-̶5̶/̶D̶u̶e̶t̶2̶ ̶W̶i̶f̶i̶ - S̶o̶l̶i̶d̶o̶o̶d̶l̶e̶
      T3P3Tonyundefined chrishammundefined 2 Replies Last reply Reply Quote 0
        T3P3Tony administrators @Alex.cr
        @Alex-cr I think in Bookworm we moved to using spyglass instead of motion.
        • chrishammundefined
          chrishamm administrators @Alex.cr
          @Alex-cr I just published a new Motion webcam server plugin. That version is compatible with Debian Buster and Bookworm. See https://github.com/Duet3D/MotionWebcamServerPlugin/releases/tag/v3.5.1
          Duet software engineer
