Smart Effector set
The reason the note is there is that the smart effector board comes with a custom heatsink made by e3d as standard. the addon part you refer to is the rest of the e3d v6 hotend.
The arms are an option to add as well.
sorry, i can not figure out:
do i need PT100 sensor?
do i need PT100 board?do i need to purchase that " rest of the e3d v6 hotend." separately? it is shown on the pictures…
thank you!P.S. when IR probe will be available?
The E3D hot ends can be used with a thermistor, PT100, or thermocouple temperature sensor. If you use the thermistor, then you don't need the daughter board. The PT100 sensor is more accurate, but you need the daughter board to use it.
David, thanks!
so, to have full set of items for the hot end that includes- smart effector parts , (PCBs etc)
- heat sink,
- thermal barrier
- heater block
- nozzle (by the way, whick size&)
- heater cartridge
- temp sensor
- fan with clip
- silicone sock
i select SmartEffector +e3d PT100 ?
on the top of that i need to order separately
- carbon arms
- PT100 board
are these lists complete ??
thank you!
Yes I think that list is complete.
Regarding IR sensor availability, I don't know why they are showing as out of stock on duet3d.com. I have plenty available to order at escher3d.com. But of course a printer with the Smart Effector doesn't need an IR sensor.
Now i'm affarid to ask - SmartEffector….
i found on thу web that it works as a "strain gauge“, thus works with any surface (including glass)
the precision is about than 7 micronis that correct? thanks!
The repeatability depends on the resolution and repeatability of your tower motors and mechanics too; but yes, that is correct.
David,
im trying to put the order in, there are 2 issues:
- IR probe (for other printer) is listed as out of stock
- i want to pay by UK bank transfer.
order is:
- IR
- PT-100 board
- Delta Smart Effector + Options: 6 Spare Magballs + e3d V6 (no Heatsink, 24V
e3d V6 with PT100
can you please email me your bank details for payment of £146.65
thank you! -
I can supply the IR sensor because I manufacture them (see my site escher3d.com); but I am sorry, I can't help with the other items, which are supplied by Think3DPrint3d of behalf of Duet3D. They are closed until 2 January.
that is ok. i can wait till Jan 2nd… please email me the invoice. thank you!
You will need to email info at duet3d dot come with a list of what you want to order; except that you can order the IR sensor direct from me at escher3d.com now if you wish.
what is a fan voltage and RPM ?
can we use 3-wire fan with speed sensor? -
The fan voltage can be 12V or 24V, whichever you supply from the Duet. There is a 12V/24V jumper on the effector to adjust the lighting current for the supply voltage.
You can use a 3-wire fan if you leave the speed sense wire (normally yellow) disconnected.
David, 2 questions
motor question i moved to appropriate section
https://www.duet3d.com/forum/thread.php?pid=36907#p36907
smart effector has heater cartridge….
what kind of power does it take? is it 2Amp??? (i need to purchase correct cable)
thanks!
The heater cartridge comes with the E3D hot end and is available in 12V and 24V versions. The current will be 1 to 2A for the 24V version, and 2 to 4A for the 12V version.
thank you!
i want to return unused 2-wire PT100 and get 4 wire version. how much that will cost?
E3D doesn't yet sell 4-wire PT100 sensors. What I recommend is to use a 2-wire sensor but to run 4 wires from the effector to the Duet.
ok… is there any other place to buy 4 wire sensor?
We have discussed 4-wire PT100 sensors with E3D. However, the 2-wire version is more than accurate enough, and the Smart Effector lets you run 4 wires from the effector back to the Duet even when you are using a 2-wire PT100 sensor.
