    Extruder motor clicks after firmware update
    369
    • ArekRuckiundefined
      ArekRucki
      This post is deleted!
        ArekRucki @gloomyandy
        @gloomyandy
        I've set extruder microstepping to 12000 but nothing has changed.
        I've also noticed that clicking appears only on circular moves. On straights it's all ok.
        I think it has something to do with jerk or acceleration but I can't figure out what parameters should I use.
        With model sliced wit lower resolution also hiccups disappeared.
        Scheduled moves 120, completed 120, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 1], CDDA state -1
        gloomyandyundefined 1 Reply Last reply Reply Quote 0
        • gloomyandyundefined
          gloomyandy @ArekRucki
          @ArekRucki Did you make both this change:
          M350 E4 I0
          and this change:
          M92 X80.00 Y80.00 Z80.00 E12000.00
          Both would be needed. I would have expected the above change to have reduced the number of hiccups seen with your original model, was this not the case?
          In terms of jerk, you could try reducing your E jerk in stages to see if it helps with the clicking. So your current jerk setting is:
          M566 X800.00 Y800.00 Z800.00 E800.00
          Try
          M566 X800.00 Y800.00 Z800.00 E400.00
          If that is better try increasing it until the clicking starts again and then back it off a little.
          ArekRuckiundefined 1 Reply Last reply Reply Quote 0
            @gloomyandy
            yes. I changed both values. then I started to print the model sliced with lower resolution.
            Hiccaps gone but not the clicking and motor was louder.
            I try to set lower jerk but I don't understand why the clicking appears only on circular moves...???
            Thanks for your time...
              @ArekRucki Why did you reslice the file at a lower resolution? That should not really have been needed, the changes I suggested should still have worked with your original test file. Did you ever try the original file with the new settings? I would have expected the hiccups to have been reduced.
              As to jerk settings you may find that increasing the setting helps if your motor is actually capable of that sort of acceleration. Circles will be implemented as a series of short lines, which in effect cause the motors to slow down and speed up if the motor can't cope with this then that may be causing the clicking. But since we have not really identified the cause of clicking it is hard to be sure.
                @gloomyandy
                @gloomyandy said in Extruder motor clicks after firmware update:
                yes, I tried. here is what I got:
                Scheduled moves 147, completed 147, hiccups 10048, stepErrors 0, LaErrors 0, Underruns [0, 0, 19], CDDA state -1
                With resliced model I have 0 hiccups
                But it's interesting that the hiccups also show up with via DWC sent G1 E F command.
                Here is yesterday's output:
                18.05.2024, 12:30:17: g1 e5 f20
                18.05.2024, 12:32:27: m122: === Diagnostics ===
                RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.1 (2024-04-19 14:40:46) running on Duet WiFi 1.02 or later
                Board ID: 0JD0M-9P6B2-NJ4S8-6JKDG-3S86S-1B72M
                Used output buffers: 14 of 26 (20 max)
                Static ram: 23256
                Dynamic ram: 71376 of which 56 recycled
                Never used RAM 18312, free system stack 130 words
                Tasks: NETWORK(2,nWait 6,15.4%,211) HEAT(3,nWait 5,0.0%,378) Move(4,nWait 5,1.1%,298) MAIN(1,running,83.4%,700) IDLE(0,ready,0.1%,29), total 100.0%
                Owned mutexes: WiFi(NETWORK)
                Last reset 00:52:12 ago, cause: power up
                Last software reset at 2023-06-17 16:54, reason: User, Gcodes spinning, available RAM 14184, slot 0
                Error status: 0x00
                Aux0 errors 0,0,0
                MCU temperature: min 27.9, current 33.5, max 34.5
                Supply voltage: min 23.7, current 24.0, max 24.6, under voltage events: 0, over voltage events: 0, power good: yes
                Events: 106 queued, 106 completed
                Driver 0: standstill, SG min 0
                Driver 1: standstill, SG min 0
                Driver 2: standstill, SG min 0
                Driver 3: standstill, SG min 0
                Driver 4: standstill, SG min n/a
                Driver 5:
                Driver 6:
                Driver 7:
                Driver 8:
                Driver 9:
                Driver 10:
                Driver 11:
                Date/time: 2024-05-18 12:32:26
                Slowest loop: 222.65ms; fastest: 0.11ms
                === Storage ===
                Free file entries: 10
                SD card longest read time 27.0ms, write time 30.8ms, max retries 0
                DMs created 83, segments created 6, maxWait 226437ms, bed compensation in use: none, height map offset 0.000, max steps late 1, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00
                no step interrupt scheduled
                Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
                === DDARing 0 ===
                Scheduled moves 571, completed 571, hiccups 40168, stepErrors 0, LaErrors 0, Underruns [0, 0, 119], CDDA state -1
                Bed heaters -1 -1 -1 -1, chamber heaters -1 -1 -1 -1, ordering errs 0
                Movement locks held by null
                HTTP is idle in state(s) 0
                Telnet is idle in state(s) 0
                File is idle in state(s) 0
                USB is idle in state(s) 0
                Aux is idle in state(s) 0
                Trigger is idle in state(s) 0
                Queue is idle in state(s) 0
                LCD is idle in state(s) 0
                Daemon is idle in state(s) 0
                Q0 segments left 0
                Code queue 0 is empty
                === Network ===
                Slowest loop: 249.59ms; fastest: 0.00ms
                Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
                HTTP sessions: 1 of 8
                === WiFi ===
                Interface state: active
                Module is connected to access point
                Failed messages: pending 0, notrdy 0, noresp 0
                Firmware version 2.1.0
                MAC address 48:3f:da:a6:f0:84
                Module reset reason: Power up, Vcc 3.39, flash size 2097152, free heap 39688
                WiFi IP address 192.168.0.179
                Signal strength -67dBm, channel 11, mode 802.11n, reconnections 0
                Clock register 00002002
                I don't know...
                Fortunately the prints come out with correct dimensions.
                  @ArekRucki At the moment it is hard to compare those numbers because it looks like the m122 from yesterday includes more than one print (it has a much higher number of scheduled moves as well as more hiccups) You really need to do the following....
                  0. Power the printer on
                  1. Run a single print of the original file with the new step settings.
                  2. Run M122 and save the results.
                  3. Reset the step settings
                  4. retartt the printer.
                  5. Run the same print again
                  6. run m122
                  If when you compare the results you are getting the same number of hiccups then that probably means that it is not the extruder moves that are causing the problem, but rather the X/Y moves (which may explain why you see a reduction in hiccups when you reduce the resolution). Ideally you do not want to be running with that high number of hiccups, but at the end of the day it is the printed results that matter, so if you get better quality with the higher resolution even with the hiccups then that may be the best solution.
                  Unfortunately it looks like we have not really identified the source of the clicking though. You may need to experiment with jerk and acceleration values. Note that jerk is only used at the junction of two moves, so you will not see any impact of jerk settings when issuing a single move from the console, you need to use a test print.
                    @gloomyandy
                    ok. many thanks. I'll do the test as you suggest.
                    I thought m122 only shows data of the last job, isn't it?
                    how does it actually work?
                    1. power up.
                    2. printing job 1.
                    3. sending m122
                    4. data from job 1
                    5. printing job 2
                    6. sending m122
                    7. data from job 1 + 2 ???
                      @ArekRucki It shows data from either when the board started or the last time M122 was run.
                      ArekRuckiundefined 1 Reply Last reply Reply Quote 1
                        @gloomyandy ok. thx
