    Question: Array Assignment
    Gcode meta commands
    1.1k
    • DonStaufferundefined
      DonStauffer @dc42
      @dc42 Workaround, tested a dozen runs with no errors; avoids subscripted assignment of RGB array elements by using 3 discrete variables to build an array to assign in its entirety:
      ;   Add to pending color values, to be sent later
      var LEDNum = null
      var Pend = null
      var r = null
      var g = null
      var b = null
      while iterations < var.Count
          set var.LEDNum = var.Start + iterations
          set var.Pend = global.NeoPixColor[var.PEND][var.LEDNum]
          ;   Check for null pending RGB array
          if var.Pend == null
              set var.Pend = {0, 0, 0}
          ;   Add new color value to pending
          set var.r = var.Pend[0] + var.Color[0]
          set var.g = var.Pend[1] + var.Color[1]
          set var.b = var.Pend[2] + var.Color[2]
          set var.Pend = {{var.r},{var.g},{var.b}}
          set global.NeoPixColor[var.PEND][var.LEDNum] = var.Pend
        dc42 administrators @DonStauffer
        @DonStauffer I believe I have identified an issue when using 'set' to assign an element in an array of arrays, where the nested array whose element is being assigned is a copy of another array. I have created this issue https://github.com/Duet3D/RepRapFirmware/issues/1008.
        Using 'set' with only a single array index should always be safe. For example, I think the following may be unsafe if global.myarray[1] is a copy of another array:
        set global.myarray[1][2] = 1
        whereas the following would be safe:
        var tempArray = global.myArray[1]
        set var.tempArray[2] = 1
        set global.myArray[1] = var.tempArray
        dc42 created this issue in Duet3D/RepRapFirmware
        closed Bug: setting elements of nested arrays sometimes goes wrong #1008
        DonStaufferundefined 2 Replies Last reply Reply Quote 0
          DonStauffer @dc42
          @dc42 Off the top of my head, that sounds like exactly the workaround I tried which didn't work. What ended up working as a workaround was avoiding subscripted assignment to the subarray, but instead constructing the array from discrete variables like
          set global.myArrayrray[1] = {var.A, var.B, var.C}
          I'll look back through my notes and see if I'm remembering right.
          EDIT: Ah, I sort of "half" did it. I was using an array with an array element with an array element, so the original workaround attempt did start with two subscripts. Maybe that was why it didn't work. Anyhow, my workaround reconstructing the subarray "manually" without subscripts did work, so I'm not stuck any more.
          Intermittent problems are tough to trouble shoot. BTW, error messages often don't name the macro they're referring to even when they give line numbers. If it's a complicated tree of nested M98 calls, it only names the outermost one and I have to go searching through the branches. The name of the macro the offending line is actually in would really help.
            droftarts administrators @DonStauffer
            @DonStauffer said in Question: Array Assignment:
            It’s been requested before, but can be quite a memory intensive process. See https://github.com/Duet3D/RepRapFirmware/issues/771
            T3P3 created this issue in Duet3D/RepRapFirmware
            open Busy status to include the macro file that is running when busy #771
            DonStaufferundefined 1 Reply Last reply Reply Quote 1
              DonStauffer @droftarts
              @droftarts Option or command to dump call stack maybe?
              gloomyandyundefined 1 Reply Last reply Reply Quote 0
              • gloomyandyundefined
                gloomyandy @DonStauffer
                You can always create that yourself. Have a global array that you push and pop the name of the macro to and print it out if when you need to. Or just echo the name of the macro at the start may be enough.
                  DonStauffer @gloomyandy
                  @gloomyandy Kind of what I'm doing now. I put something like "echo "MyMacroName" at the beginning of each macro, and "Leaving MyMacroName" as the last line. That clutters the log, but I'm thinking maybe something like:
                  In config.g:
                  global CallStack = vector(<nice large number>, "")
                  global CallStackDepth = 0
                  Then, presumably at the outermost level of whatever I'm running:
                  set global.CallStackDepth = 0
                  Then in my macro:
                  set global.CallStack[global.CallStackDepth] = "MyMacroName"
                  set global.CallStackDepth = global.CallStackDepth + 1
                  set global.CallStackDepth = global.CallStackDepth - 1
                  When I needed it, I could run a DumpCallStack macro:
                  while iterations < global.CallStackDepth
                      echo global.CallStack[iterations]
                  Maintaining the global.CallStackDepth = 0 could be bothersome when running a macro separately from a stack of macros, but at least it's only one simple line. But a bigger problem would be that an error may abort only the macro it's in, and the calling macro then continues. So CallStackDepth will be left too high in that case. Besides that functional problem, the stack would get more added to it after the error, leaving me unable to tell where the error was - the whole point of the stack trace. If there were a way to know about the error and do something when it occurs, this could be solved, but I don't know of a way. I'm not sure when execution continues vs. the entire call stack aborts (in which case this scheme works). I just assumed it was whether execution could continue, based on the severity of the error.
                  I wonder how much processing overhead this would take as compared with a compiled-in RRF solution.
                    @DonStauffer The thing is it takes zero amount of memory and adds zero overhead for the many folks who do not need it. That would not be the case for a firmware based solution. Plus you get to use it now rather than waiting for anyone else to implement it and you can tailor it to your needs.
                    I suspect just echoing the name of the function at the start of a macro is enough for most situations.
                      @gloomyandy That's what I'm doing now, but it's got some problems. Iterative calls add sometimes thousands of lines to the console log, and I have to keep adding and removing these lines of code as I go back and edit macros. I've gotten so I just comment them out and leave them there for the future. But the log clutter is problematic.
                        @gloomyandy I suspect the amount of overhead for a compiled-in version would be very minimal. I don't know what's under the hood in RRF, but if there's a correlation between macros and subroutines, the compiler may already have debugging info stored anyway, and it would just be a matter of having a command to dump that to the log. But I'm speculating.
                          @DonStauffer None of the compiler generated debug information is in the final binary installed on the control board there is nowhere near enough flash space for it. The pressure on RAM and (especially) flash space is already very high on the Duet2 boards so adding anything new requires a lot of thought and consideration.
                            @gloomyandy Makes sense. I imagine it's a real programming challenge, and we users appreciate it! Sometimes I ask about features and I say "I wonder if" because I don't know how it's all structured under the hood. Who knows, a valuable feature that seems difficult might end up being trivial (or vice versa).
                            Thanks!
                              DonStauffer @dc42
                              @dc42 Question:
                              What does & doesn't "count" as "a copy of another array"? Is it pretty much any way of setting the array's values, even initialization, where the right side isn't a scalar? Or is it just a copy from a named array variable which can trigger this problem? For instance, could any of these lines trigger the problem later?
                              var A1= vector(2, vector(2, 0)) ; Presumably, array vector creates is copied to A1?
                              set var.A1[0] = {1, 2} ; Presumably, array constant gets copied to A1[0]?
                              set var.A1[0][0] = vector(2, 0) ; Presumably, array vector creates is copied to A1[0][0]?
                              If I'm understanding correctly, if I want an array with more dimensions than 4 or 5 and therefore can't subscript elements directly, there's no possible way to assign element values without making a copy. (see code)
                              ; So, given:
                              var Inner = vector(2, vector(2, vector(2, vector(2, 0))))
                              var Outer= vector(2, vector(2, vector(2, vector(2, var.Inner))))
                              ; Instead of
                              set var.Outer[0][0][0][0][0][0][0][0] = 5 ; 8 subscripts
                              ; or
                              var A3 = var.Outer[0][0][0][0]
                              set var.A3[0][0][0][0] = 5 ; Dangerous, set using multi-subscript on copy
                              set var.Outer[0][0][0][0] = var.A3 ; (OK because Outer isn't a copy - or is it?)
                              ; I'd have to do something like:
                              ; Presumably, Outer[n][n][n][n] elements all contain copies of Inner
                              var A3 = var.Outer[0][0][0][0] ; OK, assigning to A3, not to element of a copy
                              var A4 = var.A3[0] ; Now A4 contains a copy of var.Outer[0][0][0][0][0] (would be 5 subscripts)
                              var A5 = var.A4[0] ; Now A6 contains a copy of var.Outer[0][0][0][0][0][0] (would be 6 subscripts
                              var A6 = var.A5[0] ; Now A6 contains a copy of var.Outer[0][0][0][0][0][0][0] (would be 7 subscripts)
                              set var.A6[0] = 5 ; OK, only one subscript
                              set var.A5[0] = var.A6; OK, only one subscript
                              set var.A4[0] = var.A5; OK, only one subscript
                              set var.A3[0] = var.A4; OK, only one subscript
                              set var.Outer[0][0][0][0] = var.A3 ; OK? Or is Outer a copy of vector construct?
                              ; ^ Important question above ^
                              gloomyandyundefined DonStaufferundefined 2 Replies Last reply Reply Quote 0
                                @DonStauffer The problem is triggered by any assignment that includes more than one subscript, it's that simple. So in your first example above line 3 may cause a problem, the others are probably ok.
                                I'm not really sure where you are going with all of this stuff to try and get more dimensions than the maximum. But you need to be aware that you can not write to a copy of the array and use that to modify the original. so for instance the moment that you do set var.A6[0] = 5 it will break the relationship between A6 and outer (by making a fresh copy of the values that you can access via A6[<n>] and will set the entry A6[0] to 5, it will not set Outer[0][0][0][0][0][0][0] to 5. If you understand the concept of "copy on write" basically all of the parts of an array are like that. Which in effect means that although you can probably construct an array with more than the max number of dimensions it will be in effect read only and even then you will need to jump through hoops to be able to read it.
                                You should probably try the build that DC42 has made available to you in this thread: https://forum.duet3d.com/topic/35769/error-meta-command-too-many-indices/14
                                It contains the fix that we have come up with for this problem.
                                  gloomyandy @gloomyandy
                                  @gloomyandy Oh and as to that final
                                  It may be ok but it may not, if any of the existing component arrays that make up Var.outer have another variable that happens to reference them then you may be in trouble. So for instance if earlier in the program you had var aa = var.Outer[0][0] or something similar then that could trigger the problem.
                                  Out of interest why do you need so many indices?
                                  DonStaufferundefined 1 Reply Last reply Reply Quote 0
                                    DonStauffer @DonStauffer
                                    @DonStauffer I didn't realize he had the build up already. That's fast work!
                                    Where I'm going is simple: I don't want the global namespace cluttered, so I put all the global data I need for a project into a single global variable name. Were I to consider changing my project for this purpose right now, I'd probably wait, but I had already gone to the trouble of making all the changes when I discovered these unexpected challenges.
                                    Sure, delayed writing is a performance trick. But I didn't expect to be able to take advantage of any link to the original. I'm not sure why it would be read only. That's why my code steps back through each subscript and assigns to the previous copy, until it gets back to the original array. It seems like that should work. Not efficient, but it's supposed to be a workaround.
                                    Given a deep array, first, assign an element of the first dimension to a variable. Whether it's linked under the hood at this point doesn't matter. Now, assign an element of the first dimension of THAT variable to a second variable. Continue, until you are at the penultimate dimension. That variable gets the intended value assigned. Then, assign that to the same subscript of the prior variable that it came from. Then assign THAT variable to the same subscript of the prior variable that it came from. Etc., until you assign the first variable to the same subscript of the original array it came from. No link is needed to the original. Not an easy way to assign, but it seems like it makes it possible. I'm copying a branch node by node then reassembling the branch after assigning to the disassembled leaf node. Without the subscript bug, I'd only need to do this at level 4 or 5 without percolating all the way through the depth of the array. Much simpler.
                                      @gloomyandy OK, this being a deferred write issue really clarifies what's going on. I get it now.
                                        @gloomyandy OK, I got the update and so far it looks good. And to get a depth over 5, this seems to work fine:
                                        ;   BigArray Macro
                                        ;   Demonstrates how to effectively have array depths over 5 subscripts
                                        ;   Define an array with a depth of 7
                                        var Inner = vector(2, vector(2, 0))
                                        var Outer = vector(2, vector(2, vector(2, vector(2, vector(2, var.Inner)))))
                                        ;   Write access
                                        var Inner1 = var.Outer[0][0][0][0][0] ; Copy part of branch
                                        set var.Inner1[0][0] = 1 ; Not the original array. It is a copy of part of it
                                        set var.Outer[0][0][0][0][0] = var.Inner1 ; Copy back whole copied branch part
                                        ;   Read access
                                        var Inner2 = var.Outer[0][0][0][0][0] ; Copy part of branch
                                        echo var.Inner2[0][0]
                                          @DonStauffer This hadn't occurred to me until the last day or so ...
                                          Does my proposed >5 dimensional array concept produce a memory leak? I was assuming the language wouldn't permit a user to create a memory leak, but since I don't know anything about how memory is managed under the hood in RRF, I don't know.
                                          Specifically, does assigning an array value to an element of a global array discard the memory which until then had been used for that element's array? If so, then doing that iteratively would use up all available memory (and then probably crash). So, is this problematic? Is this a memory leak, or does the "lost" memory get returned to the the heap?
                                          global MyArray = {1, {2,3}}
                                          set global.MyArray[2] = {4,5} ; New 2-element array allocated in global element, to hold {4,5}
                                          ; now the memory which was holding {2, 3} is lost
                                          set global.MyArray[2] = {6,7}
                                          ; memory which was holding {4,5} is now lost
                                          Likewise if the array comes from another variable rather than an "array value" in braces?
                                            @DonStauffer the memory in question should get recycled to the help. If you have any evidence that there is a memory leak, please provide an example. The M122 report includes information on the state of the heap.
