Reading status of input pin in roto toolboard
Gcode meta commands
    RockB
    I have a roto tool board on CAN network communicating with mainboard 6HC. How can I read the status of input pin io2.in in IO 2 of roto tool board?
    undefined undefined 2 Replies Last reply 26 Jun 2024, 05:21 Reply Quote 0
      jay_s_uk @RockB
      @RockB you can get that information from the object model https://docs.duet3d.com/en/User_manual/RepRapFirmware/Object_Model
        dc42 administrators @RockB
        @RockB to expand on the response from Jay: use M950 with the Jn parameter for your own choice of n (e.g. zero if you have not configured any other inputs) to configure that pin as an input port; then query sensors.gpIn[n] in the object model to find the current value.
        undefined 1 Reply Last reply 26 Jun 2024, 16:08 Reply Quote 0
          RockB @dc42
          @dc42 @jay_s_uk I have configured an input using M950 in my config.g
          M950 J0 C"20.io2.in"; create input 0 for air cylinder in tool 0
          I am not sure how to query sensors.gpIn[0] in the object model. Navigating to the object model plugin in DWC, I see sensors.gpIn is an array but can't see any values
          How do I query the sensors.gpIn[0]?
          undefined 1 Reply Last reply 26 Jun 2024, 20:24 Reply Quote 0
            @RockB I think your M950 command has failed. Which version of RRF are you using? What happens when you send that M950 command from the console?
            undefined 1 Reply Last reply 26 Jun 2024, 21:42 Reply Quote 0
              RockB @dc42
              @dc42 Looks like the roto tool board was running an older version (3.5.0 rc1) of the firmware. After updating the firmware to the latest 3.5.2 everything works as expected.
              • undefined dc42 marked this topic as a question 27 Jun 2024, 07:00
              • undefined dc42 has marked this topic as solved 27 Jun 2024, 07:01
              1 out of 6
