Duet no wifi anymore
A few weeks ago i posted here that my sd card reader wasnt working properly anymore. I noticed this in the wifi not working all the time. I now replaced the sd card reader but now the wifi aint working anymore at all. I get the red light but not the blue light of trying to connect. Sometimes i get a low visible blue light but that is all. Does someone know the meaning of this and how I am able to fix this. I checked the solder connections and they are allright.
Berend
Did you replace the wifi module? The soldering there doesn't seem stock. When you replaced the SD card reader perhaps the wifi module soldering was melted as well causing a poor connection.
@bierent said in Duet no wifi anymore:
Which did you check and how did you check them?
Also, are you connecting the external antenna?
