    Number of input shaper "test-moves"?
    • sungod3kundefined
      sungod3k
      today i used input shaping for the first time on a very fragile machine (modix big meter), so far everything worked well thanks to the excellent documentation and i ended up with a good ZVDD compensation at 22hz.
      I still have to do some before and after testing however i was a bit suprised by how quick the testing moves were done.
      I followed the input shaper plugin and it suggested one x and one y move, which surprised me a bit.
      from what i can see from klipper input shaping its a much longer procedure with all kinds of testmoves in all directions, with different speeds and differently long moves.
      I wonder if I should add more moves or if I missed a step somewhere, or is there a library of testmoves out there somewhere?
      Can someone shed some light on how the input shaper procedure is supposed to be done?
      Cheers
      F.
      http://www.42dimensions.de/
      https://printnewworlds.blogspot.com/
        jay_s_uk @sungod3k
        @sungod3k nope, that's correct. RRF does one move in X and Y at the maximum speeds etc set in config.g.
        22Hz seems a little low however
        sungod3kundefined 1 Reply Last reply Reply Quote 0
        • sungod3kundefined
          sungod3k @jay_s_uk
          @jay_s_uk
          it s huge 1x1x1 meter machine, so it might not respomd on the normal frequencies
            jay_s_uk @sungod3k
            @sungod3k can you post your graphs? would be curious to see.
            IIRC, anything below 20Hz in klipper is discarded
