    Parsing error when loading height map
    heightmap
    379
    • sbNielsenundefined
      sbNielsen @droftarts
      @droftarts
      RepRapFirmware height map file v2 generated at 2024-16-07 19:04, min error -0.45, max error 1.10, mean 0.083, deviation 0.387
      axis0,axis1,min0,max0,min1,max1,radius,spacing0,spacing1,num0,num1
      X,Y,0.00,1700.00,0.00,900.00,,10.00,10.00,17,10
        0.600,  0.500,  0.400,  0.400,  0.400,  0.400,  0.400,  0.300,  0.300,  0.400,  0.400,  0.500,  0.500,  0.600,  0.700,  0.900,  1.100
        0.400,  0.400,  0.300,  0.300,  0.200,  0.200,  0.200,  0.200,  0.200,  0.200,  0.300,  0.350,  0.450,  0.500,  0.700,  0.800,  1.050
        0.300,  0.200,  0.200,  0.100,  0.100,  0.100,  0.050,  0.000,  0.000,  0.000,  0.100,  0.200,  0.300,  0.450,  0.600,  0.800,  1.000
        0.200,  0.100,  0.000, -0.100, -0.100, -0.100, -0.150, -0.200, -0.200, -0.200, -0.100, -0.100,  0.150,  0.280,  0.450,  0.680,  0.900
        0.100,  0.000, -0.100, -0.200, -0.200, -0.300, -0.300, -0.300, -0.220, -0.220, -0.180, -0.050,  0.020,  0.180,  0.400,  0.600,  0.900
        0.100,  0.000, -0.100, -0.200, -0.300, -0.400, -0.400, -0.400, -0.300, -0.300, -0.200, -0.150, -0.100,  0.000,  0.280,  0.500,  0.800
        0.100,  0.000, -0.150, -0.280, -0.400, -0.450, -0.400, -0.400, -0.200, -0.250, -0.200, -0.200, -0.050,  0.160,  0.400,  0.700,  0.700
        0.180, -0.050, -0.200, -0.300, -0.400, -0.400, -0.400, -0.400, -0.400, -0.350, -0.300, -0.250, -0.150,  0.050,  0.300,  0.600,  0.900
        0.100, -0.100, -0.200, -0.300, -0.400, -0.400, -0.400, -0.400, -0.380, -0.350, -0.280, -0.200, -0.200,  0.080,  0.250,  0.600,  0.900
        0.100, -0.100, -0.280, -0.380, -0.400, -0.440, -0.400, -0.400, -0.380, -0.350, -0.300, -0.280, -0.200,  0.000,  0.200,  0.550,  0.900
      I have a difficult time spotting any differences in syntax/structure between mine (above) and the example i posted before, but somehow my map will not load, and the other one will.
      With ^ this map i still get the
      Error: G29: Failed to load height map from file 0:/sys/heightmap.csv: failed to parse grid parameters
      droftartsundefined sbNielsenundefined 2 Replies Last reply Reply Quote 0
        droftarts administrators @sbNielsen
        @sbNielsen The main reason for it not loading is that you need to set radius to -1.
        You don't need anything on the first line after "RepRapFirmware height map file v2", if these have been copied from somewhere else and are not accurate.
        However, there's also a couple of mistakes. You need 18 X axis points, to go from 0 to 1700mm, other wise it goes from 0 to 1600. Also, the spacing is 100 for both axes, not 10. So first three lines should be:
        X,Y,0.00,1700.00,0.00,900.00,-1,100.00,100.00,18,10
        And you need to add an extra probe point value on each line of the probed points.
          sbNielsen
          Strange, even though I get the error message, that it failed to load, I can still preview the map in the 'height map' tab.
          And it corresponds correctly with the coordinates and the expected value.
          Does that mean that it is loaded anyway or?
          droftartsundefined 2 Replies Last reply Reply Quote 0
            @sbNielsen No, the Height Maps plugin just shows the points, it doesn't load it. Use either G29 S1 or in DWC go to Control > Dashboard > Machine Movement and click on the 'Compensation and Calibration' drop down menu. I guess the plugin parses the file in a different, and less exacting, way from the firmware.
            sbNielsenundefined 1 Reply Last reply Reply Quote 0
              @sbNielsen Did you update your firmware from the old release candidate (3.5.0-rc.1++) you are currently running?
                sbNielsen @sbNielsen
                @sbNielsen
                Ah yes, you are right!
                I corrected the mistakes you pointed out:
                X,Y,0.00,17000.00,0.00,9000.00,-1.00,100.00,100.00,18,10
                Now i get this error message:
                Error: G29: Failed to load height map from file 0:/sys/heightmap.csv: number expected at line 3 column 136
                If i flip the num0, num1 values around so num0=10 and num1=18 I get this error:
                Error: G29: Failed to load height map from file 0:/sys/heightmap.csv: failed to read line from file
                  @droftarts
                  No will do it now!
                    @droftarts said in Parsing error when loading height map:
                    Updated firmware to latest, still getting the error messages described above
                      @sbNielsen
                      You have changed the axis length from 1700mm to 17000mm, and 900mm to 9000mm?! Also, you only have 17 points for each line of the probe data; you need 18 to go to from 0 (the first point) to 1700 (the 18th and last point) in 100mm steps.
                        @sbNielsen
                        Damn it, I change things to quick and then I fuck it up, sorry!
                        It works now! The main issues was the missing 18th column in the grid..
                        I feel stupid and happy haha, thank you for your help and patience!
                        To anybody reading this in the future, here is the .csv file that ended up working:
                        X,Y,0.00,1700.00,0.00,900.00,-1.00,100.00,100.00,18,10
                          0.600,  0.500,  0.400,  0.400,  0.400,  0.400,  0.400,  0.300,  0.300,  0.400,  0.400,  0.500,  0.500,  0.600,  0.700,  0.900,  1.100,  1.100
                          0.400,  0.400,  0.300,  0.300,  0.200,  0.200,  0.200,  0.200,  0.200,  0.200,  0.300,  0.350,  0.450,  0.500,  0.700,  0.800,  1.050,  1.050
                          0.300,  0.200,  0.200,  0.100,  0.100,  0.100,  0.050,  0.000,  0.000,  0.000,  0.100,  0.200,  0.300,  0.450,  0.600,  0.800,  1.000,  1.000
                          0.200,  0.100,  0.000, -0.100, -0.100, -0.100, -0.150, -0.200, -0.200, -0.200, -0.100, -0.100,  0.150,  0.280,  0.450,  0.680,  0.900,  0.900
                          0.100,  0.000, -0.100, -0.200, -0.200, -0.300, -0.300, -0.300, -0.220, -0.220, -0.180, -0.050,  0.020,  0.180,  0.400,  0.600,  0.900,  0.900
                          0.100,  0.000, -0.100, -0.200, -0.300, -0.400, -0.400, -0.400, -0.300, -0.300, -0.200, -0.150, -0.100,  0.000,  0.280,  0.500,  0.800,  0.800
                          0.100,  0.000, -0.150, -0.280, -0.400, -0.450, -0.400, -0.400, -0.200, -0.250, -0.200, -0.200, -0.050,  0.160,  0.400,  0.700,  0.700,  0.700
                          0.180, -0.050, -0.200, -0.300, -0.400, -0.400, -0.400, -0.400, -0.400, -0.350, -0.300, -0.250, -0.150,  0.050,  0.300,  0.600,  0.900,  0.900
                          0.100, -0.100, -0.200, -0.300, -0.400, -0.400, -0.400, -0.400, -0.380, -0.350, -0.280, -0.200, -0.200,  0.080,  0.250,  0.600,  0.900,  0.900
                          0.100, -0.100, -0.280, -0.380, -0.400, -0.440, -0.400, -0.400, -0.380, -0.350, -0.300, -0.280, -0.200,  0.000,  0.200,  0.550,  0.900,  0.900
                        • dc42undefined dc42 marked this topic as a question
                        • dc42undefined dc42 has marked this topic as solved
