    Any tips on debugging techniques for out of memory?
    Gcode meta commands
    788
      dc42 administrators @DonStauffer
      @DonStauffer how about getting your macro to also echo the amount of free memory at various points? It's available in the object model.
      DonStaufferundefined 1 Reply Last reply Reply Quote 0
      • DonStaufferundefined
        DonStauffer @dc42
        @dc42 OK, about my "knowing the object model by heart" ... except that! 🙂
        boards[0].freeRam?
          @DonStauffer yes that's the one. It's the same as Never Used RAM in the M122 report.
            DonStauffer @dc42
            @dc42 Thanks. I'll look at it, though my immediate problem seems to be solved. But undoubtedly I'll run out of memory again at some point. But I'm pretty happy now.
              @DonStauffer I'd be interested to know whether you have less or more free memory after running a print with 3.6 alpha compared to 3.5.2.
              DonStaufferundefined 2 Replies Last reply Reply Quote 0
                DonStauffer @dc42
                @dc42 I'm a little afraid to install an alpha though. Is reverting easy?
                  @DonStauffer assuming you are running in standalone mode not SBC mode, reverting is very easy. To make it even easier you can install just the 3.6 Duet2CombinedFirmware.bin file and continue running DWC 3.5.2. You can ignore the warning about incompatible software versions in this case.
                  • gloomyandyundefined
                    gloomyandy @DonStauffer
                    @DonStauffer Just running M122 in the console should provide an idea of what the memory situation is before the print starts and after your startup code has run.
                      DonStauffer @gloomyandy
                      @gloomyandy Echoing boards[0].freeRam at various places throughout a small, 15 minute, 8-layer print job with tool changes, it looks like this (no units given; bytes?):
                      Machine turn-on: 8544
                      Partway through job startup: 8520
                      Before purge in job startup: 4000
                      After purge: 920
                      Beginning of Layer 1: 920
                      Layer 2: 848
                      Layer 3: 848
                      Layer 4: 848
                      Layer 5: 848
                      Layer 5 before tool change: 464
                      Layer 6: 72
                      Layer 6 before tool change: 72
                      Layer 7: 72
                      Layer 7 before tool change: 72
                      Layer 8: 72
                      Layer 8 before tool change: 72
                      After job finished: 72
                      It seems like I'm grazing the treetops. Most of my global data is created from config.g, so I'm not really sure why my startup script uses so much memory compared to the job proper.
                        DonStauffer @dc42
                        @dc42 OK, I'll do that. I have the details on free memory echoing throughout a job and I recorded them. So I'll have something to compare it with.
                          DonStauffer @dc42
                          @dc42 Same GCode file as the free RAM I posted for RRF 3.5.2, but after installing 3.6 alpha 2:
                          After upgrade: 22624
                          I couldn't believe that so I did an M999 and looked again: 22600 (where are my 24 bytes?)
                          Partway through job startup: 22600
                          Before purge in job startup: 16840
                          After purge: 14472
                          Beginning of Layer 1: 14472
                          Layer 2: 14472
                          Layer 3: 14304
                          Layer 4: 14280
                          Layer 5: 14280
                          Layer 5 before tool change: 13512
                          Layer 6: 13096
                          Layer 6 before tool change: 13096
                          Layer 7: 13096
                          Layer 7 before tool change: 13096
                          Layer 8: 13096
                          Layer 8 before tool change: 13096
                          After job finished: 13096
                          What wizardry is this?!
                          • oliofundefined
                            oliof @DonStauffer
                            @DonStauffer probably the work noted at https://github.com/Duet3D/RepRapFirmware/blob/bd8d9119d49ba425864f2280b005875b368746c0/src/Todo-next.txt#L25
