    Wifi/DWC Disconnecting with RRF3.5.2 on Duet2 Wifi Hardware
    Beta Firmware
    1.4k
    • trd87tundefined
      trd87t
      Ran a debug on wifi (P14)....
      >>> M111 P14 S1
      SENDING:M111 P14 S1
      Debugging enabled for modules: WiFi(14 - 0xffffffff)
      Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Gcodes(3) Move(4) Heat(5) Kinematics(6) InputShaping(7) unused(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) SbcInterface(16) CAN(17) Expansion(18)
      ResponseTimeout, pending=1
      WiFi: /home/duet3d/WiFiSocketServerRTOS/src/Connection.cpp(572): refused conn on port 80 already 4 conns
      Error: failed to retrieve WiFi status message: SPI timeout
      ESP reported status change
      WiFi: /home/duet3/home/duet3d/WiFiSocketServerRTOS/src/Connection.cpp(572): refused conn on port 80 already 4 conns
      WiFi: /home/duet3TOS/src/Connection.cpp(572): refused conn on port 80 already 4 conns
      WiFi: /home/duet3p(572): refused conn on port 80 already 4 conns
      >>> M111 P14 S0
      and then network (P1)....
      >>> M111 P1 S1
      SENDING:M111 P1 S1
      Debugging enabled for modules: Network(1 - 0xffffffff)
      Debugging disabled for modules: Platform(0) Webserver(2) Gcodes(3) Move(4) Heat(5) Kinematics(6) InputShaping(7) unused(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) WiFi(14) Display(15) SbcInterface(16) CAN(17) Expansion(18)
      Bad recv status size
      >>> M111 P1 S0
      Issuing another M122....
      - Now MAIN is running 99%
      - "noresp" continues to increase
      - Socket states are the same
      >>> m122
      SENDING:M122
      RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.2 (2024-06-11 17:13:43) running on Duet WiFi 1.02 or later
      Board ID: 08DAM-9K9K2-NGNSN-6J9DJ-3S86S-17T3J
      Used output buffers: 1 of 26 (14 max)
      Static ram: 23384
      Dynamic ram: 73040 of which 208 recycled
      Never used RAM 16512, free system stack 186 words
      Tasks: NETWORK(1,nWait 6,0.1%,222) HEAT(3,nWait 5,0.0%,328) Move(4,nWait 5,0.0%,359) MAIN(1,running,99.8%,370) IDLE(0,ready,0.1%,29), total 100.0%
      Owned mutexes: WiFi(NETWORK) USB(MAIN)
      Last reset 03:14:35 ago, cause: power up
      Last software reset details not available
      Error status: 0x00
      Error status: 0x00
      MCU temperature: min 27.7, current 28.3, max 30.1
      Supply voltage: min 1.3, current 1.4, max 1.4, under voltage events: 0, over voltage events: 0, power good: no
      Events: 0 queued, 0 completed
      Driver 0: ok, SG min n/a
      Driver 1: ok, SG min n/a
      Driver 2: ok, SG min n/a
      Driver 3: ok, SG min n/a
      Driver 4: ok, SG min n/a
      Driver 5:
      Driver 6:
      Driver 7:
      Driver 8:
      Driver 9:
      Driver 10:
      Driver 11:
      Date/time: 2024-07-08 23:39:20
      Slowest loop: 508.89ms; fastest: 0.14ms
      === Storage ===
      Free file entries: 10
      SD card longest read time 1.2ms, write time 0.0ms, max retries 0
      DMs created 83, segments created 0, maxWait 0ms, bed compensation in use: none, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
      no step interrupt scheduled
      Moves shaped first try 0, on retry 0, too short 0, wrong shape 0, maybepossible 0
      === DDARing 0 ===
      Heater 1 is on, I-accum = 0.0
      Movement locks held by null
      HTTP is idle in state(s) 0
      Telnet is idle in state(s) 0
      File is idle in state(s) 0
      USB is ready with "M122" in state(s) 0
      Aux is idle in state(s) 0
      Trigger is idle in state(s) 0
      Queue is idle in state(s) 0
      LCD is idle in state(s) 0
      Daemon is idle in state(s) 0
      Q0 segments left 0
      Code queue 0 is empty
      === Network ===
      Slowest loop: 600.01ms; fastest: 99.61ms
      Responder states: HTTP(0) HTTP(0) HTTP(0) FTP(0) Telnet(0)
      HTTP sessions: 0 of 8
      === WiFi ===
      Interface state: active
      Module is connected to access point
      Failed messages: pending 0, notrdy 34996, noresp 75827
      Failed to get WiFi status
      Socket states: 6 6 0 0 0 0 0 0
      Turned off the duet and went to sleep
      • trd87tundefined
        trd87t
        "Day 2"
        Had a thought after browsing the forums, nothing specific I was reading but thought, "what happens if I turn on the duet but not immediately connect to the DWC?"
        So the journey continues
        Start ping
        Turn on duet
        Connect USB
        Turn on debugging for P1 (Network) and P14 (Wifi)
        Issue M122 for start, all seems good
        >>> M111 P14 S1
        SENDING:M111 P14 S1
        >>> M111 P1 S1
        SENDING:M111 P1 S1
        Debugging enabled for modules: Network(1 - 0xffffffff) WiFi(14 - 0xffffffff)
        Debugging disabled for modules: Platform(0) Webserver(2) Gcodes(3) Move(4) Heat(5) Kinematics(6) InputShaping(7) unused(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) SbcInterface(16) CAN(17) Expansion(18)
        >>> M122
        SENDING:M122
        Used output buffers: 1 of 26 (2 max)
        Static ram: 23384
        Dynamic ram: 73040 of which 0 recycled
        Never used RAM 16720, free system stack 194 words
        Tasks: NETWORK(1,ready,13.3%,416) HEAT(3,nWait 5,0.0%,330) Move(4,nWait 5,0.0%,359) MAIN(1,running,85.8%,766) IDLE(0,ready,0.8%,29), total 100.0%
        Last reset 00:01:54 ago, cause: power up
        Error status: 0x00
        Error status: 0x00
        MCU temperature: min 19.2, current 24.6, max 25.0
        Supply voltage: min 0.4, current 1.3, max 1.4, under voltage events: 0, over voltage events: 0, power good: no
        Driver 5:
        Driver 6:
        Driver 7:
        Driver 8:
        Driver 9:
        Driver 10:
        Driver 11:
        Slowest loop: 8.22ms; fastest: 0.14ms
        === Storage ===
        SD card longest read time 1.3ms, write time 0.0ms, max retries 0
        === DDARing 0 ===
        Q0 segments left 0
        === Network ===
        Slowest loop: 2.81ms; fastest: 0.00ms
        === WiFi ===
        Failed messages: pending 0, notrdy 0, noresp 0
        Firmware version 2.1.0
        MAC address a0:20:a6:19:27:48
        Module reset reason: Turned on by main processor, Vcc 3.27, flash size 4194304, free heap 46324
        WiFi IP address xxx.xxx.xxx.254
        Signal strength -33dBm, channel 6, mode 802.11n, reconnections 0
        Clock register 00002002
        WiFi: Conns: 0:free, 1:free, 2:free, 3:free, 4:free, 5:free, 6:free, 7:free
        At this point, duet is pinging, usb responding
        Issue another M122 to see if anything changed..... nothing noticed
        >>> M122
        SENDING:M122
        Used output buffers: 1 of 26 (12 max)
        Static ram: 23384
        Never used RAM 16720, free system stack 186 words
        Tasks: NETWORK(1,ready,13.9%,416) HEAT(3,nWait 5,0.0%,328) Move(4,nWait 5,0.0%,359) MAIN(1,running,86.0%,766) IDLE(0,ready,0.0%,29), total 100.0%
        Owned mutexes: USB(MAIN)
        Last reset 00:13:50 ago, cause: power up
        Error status: 0x00
        Error status: 0x00
        MCU temperature: min 24.4, current 26.9, max 28.1
        Driver 5:
        Driver 6:
        Driver 7:
        Driver 8:
        Driver 9:
        Driver 10:
        Driver 11:
        Slowest loop: 8.35ms; fastest: 0.14ms
        === Storage ===
        === DDARing 0 ===
        Q0 segments left 0
        === Network ===
        Slowest loop: 20.70ms; fastest: 0.07ms
        === WiFi ===
        Signal strength -32dBm, channel 6, mode 802.11n, reconnections 0
        Duet is pinging but noticed (again) that it is erratic in its ping times to an AP that is in the same room. At cyclic times, noticed that there is a string a ping timeouts for 5 pings (essentially 5 seconds) then immediately recovers.
        There is consistently in this pattern.
        64 bytes from xxx.xxx.xxx.254: icmp_seq=12379 ttl=255 time=33.616 ms
        64 bytes from xxx.xxx.xxx.254: icmp_seq=12380 ttl=255 time=60.506 ms
        64 bytes from xxx.xxx.xxx.254: icmp_seq=12381 ttl=255 time=82.247 ms
        64 bytes from xxx.xxx.xxx.254: icmp_seq=12382 ttl=255 time=41.152 ms
        Request timeout for icmp_seq 12383
        Request timeout for icmp_seq 12384
        Request timeout for icmp_seq 12385
        Request timeout for icmp_seq 12386
        Request timeout for icmp_seq 12387
        64 bytes from xxx.xxx.xxx.254: icmp_seq=12388 ttl=255 time=180.845 ms
        64 bytes from xxx.xxx.xxx.254: icmp_seq=12389 ttl=255 time=68.944 ms
        After 4+ hours, I go to the DWC
        Network debugs start throwing this out
        New conn on socket 0 for local port 80
        Found responder
        Received 352 bytes
        Found responder
        New conn on socket 1 for local port 80
        Found responder
        Received 352 bytes
        I take it this is normal
        About 5 minutes into just browsing the DWC
        Found responder
        Received 352 bytes
        Found responder
        Found responder
        Received 352 bytes
        Send failed, terminating
        ResponseBusy
        ResponseBusy
        ResponseBusy
        ResponseBusy
        ResponseBusy
        ResponseBusy
        ResponseBusy
        Some observations: Remember the erratic pings and it timing out every now and then?
        So when the ping drop happened, DWC dropped (and never came back like the day before)
        Issued M122 again
        - Network is running 99% but in "ready" state
        - "noresp" increasing
        - Socket states back at "6 6 0 0 0 0 0 0"
        >>> M122
        SENDING:M122
        Used output buffers: 1 of 26 (16 max)
        Static ram: 23384
        Tasks: NETWORK(1,ready,98.9%,217) HEAT(3,nWait 5,0.0%,328) Move(4,nWait 5,0.0%,359) MAIN(1,running,1.1%,766) IDLE(0,ready,0.0%,29), total 100.0%
        Last reset 04:29:12 ago, cause: power up
        Error status: 0x00
        Error status: 0x00
        MCU temperature: min 27.6, current 27.8, max 28.2
        Supply voltage: min 1.3, current 1.3, max 1.4, under voltage events: 0, over voltage events: 0, power good: no
        Driver 5:
        Driver 6:
        Driver 7:
        Driver 8:
        Driver 9:
        Driver 10:
        Driver 11:
        Date/time: 2024-07-10 17:20:47
        Slowest loop: 735.13ms; fastest: 0.14ms
        === Storage ===
        SD card longest read time 101.0ms, write time 0.0ms, max retries 0
        === DDARing 0 ===
        Q0 segments left 0
        === Network ===
        Slowest loop: 3303.34ms; fastest: 100.30ms
        === WiFi ===
        Failed messages: pending 0, notrdy 620, noresp 1
        So I let it sit in this state for hours
        Pings never came back either.
        Other noteworthy things
        - Have not tried resetting the wireless with M552 commands yet. Just wanted to gather information to try to be helpful data gathering.
        - Wifi blue light has been steady the whole time, never was it ever blinking (tells me it stayed connected to the AP, M122 commands confirm this)
        Don't know what to do next, so thought I'd post since I'm at the latest (stable) version of all firmware.
        This is not a production printer, I'm just a hobbyist, so I can try things out. Will take me a couple days at a time to respond if I need to try something.
          droftarts administrators @trd87t
          @trd87t Thanks for the extensive report. Could you please:
          • send M586 and post the response, to see what network protocols are enabled? Disable any you are not using, eg FTP, Telnet
          • check the list of stored WiFi networks, by sending M587, looking particularly if there are any duplicate entries, with different capitalisation.
          • post your config.g.
          • have a look through the WiFi Troubleshooting page, to see if any of it is relevant.
          • is the SD card the same vintage as the printer? It may be worth trying a new SD card (we recommend using at least a Class 10 card now); see https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card
          If nothing helps, @rechrtb will need to take a look at it.
          DonStaufferundefined 1 Reply Last reply Reply Quote 0
          • trd87tundefined
            trd87t
            >>> M586
            SENDING:M586
            CORS disabled
            HTTP is enabled on port 80
            FTP is disabled
            TELNET is disabled
            >>> M587
            SENDING:M587
            Remembered networks:
            DUET IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
            esperville IP=0.0.0.0 GW=0.0.0.0 NM=0.0.0.0
              Below is the config.g
              I have read through this initially. AP is in same room as Duet with a -35dbm signal strength. The room in which it is in, is not near typical interference appliances, etc. The duet does stay online and pinging until the DWC is accessed.
              The SD card is of the same vintage. I can try a new card but will take a few to get it going, I will attempt this weekend.
            config.g file
            ; generated by RepRapFirmware Configuration Tool v3.1.4 on Tue Jul 21 2020 23:14:27 GMT-0500 (Central Daylight Time)
            G90                                                    ; send absolute coordinates...
            M83                                                    ; ...but relative extruder moves
            M550 P"Graber"                                         ; set printer name
            M552 S1                                                ; enable network
            M586 P0 S1                                             ; enable HTTP
            M586 P1 S0                                             ; disable FTP
            M586 P2 S0                                             ; disable Telnet
            M569 P0 S1                                             ; physical drive 0 goes forwards
            M569 P1 S0                                             ; physical drive 1 goes backwards
            M569 P2 S1                                             ; physical drive 2 goes forwards
            M569 P3 S1                                             ; physical drive 3 goes forwards
            M569 P4 S1											   ; physical drive 4 goes forwards
            M584 X0 Y1 Z2:4 E3                                     ; set drive mapping
            M671 X-70:263 Y95:95 S1								   ; set leadscrew pivot point with max correction
            ; Motor Configuration
            M350 X16 Y16 Z16 E16 I0                                ; configure microstepping without interpolation
            M92 X80.00 Y80.00 Z400 E847.76118                      ; set steps per mm
            M566 X900.00 Y900.00 Z60.00 E120.00                    ; set maximum instantaneous speed changes (mm/min)
            M203 X6000.00 Y6000.00 Z180.00 E1200.00                ; set maximum speeds (mm/min)
            M201 X500.00 Y500.00 Z20.00 E250.00                    ; set accelerations (mm/s^2)
            M906 X1000 Y1000 Z850 E800 I30                         ; set motor currents (mA) and motor idle factor in percent
            M84 S10                                                ; Set idle timeout
            M208 X0 Y0 Z0 S1                                       ; set axis minima
            M208 X198 Y190 Z190 S0                                 ; set axis maxima
            M574 X1 S1 P"!xstop"                                   ; configure active-low endstop for low end on X via pin xstop
            M574 Y1 S1 P"!ystop"                                   ; configure active-low endstop for low end on Y via pin ystop
            M574 Z1 S1 P"nil"                                      ; configure active-low endstop for low end on Z via pin null
            M950 S0 C"exp.heater3"                                 ; create servo pin 0 for BLTouch
            M558 P9 C"^zprobe.in" H5 F120 T6000                    ; set Z probe type to bltouch and the dive height + speeds
            G31 P25 X29.7 Y0 Z0                                    ; set Z probe trigger value, offset and trigger height, higher is lower
            M557 X35:188 Y5:185 P7:7                               ; define mesh grid
            M308 S0 P"bedtemp" Y"thermistor" T51000 B3950          ; configure sensor 0 as thermistor on pin bedtemp
            M950 H0 C"bedheat" T0                                  ; create bed heater output on bedheat and map it to sensor 0
            M307 H0 B0 S1.00                                       ; disable bang-bang mode for the bed heater and set PWM limit
            M140 H0                                                ; map heated bed to heater 0
            M143 H0 S130                                           ; set temperature limit for heater 0 to 130C
            M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8 ; configure sensor 1 as thermistor on pin e0temp
            M950 H1 C"e0heat" T1                                   ; create nozzle heater output on e0heat and map it to sensor 1
            M307 H1 B0 S1.00                                       ; disable bang-bang mode for heater  and set PWM limit
            M143 H1 S295										   ; Set temperature limit for heater 1 (hot end) to 295C
            ; Extra Sensors
            M308 S10 Y"mcu-temp" A"MCU"							   ; defines sensor 10 as MCU temperature sensor
            M308 S11 Y"drivers" A"Duet Stepper Drivers"			   ; defines sensor 11 as stepper driver temerature sensor
            M950 F0 C"fan0" Q100                                   ; create fan 0 on pin fan0 and set its frequency
            M106 P0 S0 H-1 C"Part Fan"                             ; set fan 0 value. Thermostatic control is turned off
            M950 F1 C"fan1" Q100                                   ; create fan 1 on pin fan1 and set its frequency
            M106 P1 S1 H1 T45 C"Hotend Fan"                        ; set fan 1 value. Thermostatic control is turned on
            M950 F2 C"fan2" Q100                                   ; create fan 2 on pin fan1 and set its frequency
            M106 P2 H10:11 T30:70 C"Board Fan"                  ; set fan 2 value. Thermostatic control is turned on
            M563 P1 D0 H1                                          ; define tool 1
            G10 P1 X0 Y0 Z0                                        ; set tool 1 axis offsets
            G10 P1 R0 S0                                           ; set initial tool 1 active and standby temperatures to 0C
            M912 P0 S-18										   ; MCU temperature calibration
            M501                                                   ; run config-override.g
            T1                                                     ; select first tool
            • trd87tundefined
              trd87t
              FWW
              >>> M39
              SENDING:M39
              SD card in slot 0: capacity 7.74GB, partition size 7.74GB, free space 7.65GB, speed 20.00MBytes/sec, cluster size 32kB
              • trd87tundefined
                trd87t
                Got a new SD card over the weekend (SanDisk Ultra A1 HC).
                Formatted according to the instructions on https://docs.duet3d.com/en/User_manual/RepRapFirmware/SD_card
                Still seeing the issues.
                Going to test out a couple things (that are probably not going to do anything but I'm trying anything at this point).
                1. Going to boot the duet and connect to DWC and let it sit on the Dashboard, see if it loses access just sitting there.
                2. Going to clean up the SD card. It has old firmware from RFF-1.18 days
                3. Since I have multiple SD cards now, going to install RFF3.3 with the older Wifi Firmware (prior to 2.01)
                4. If stable, keep upgrading stable releases until it breaks?
                • DonStaufferundefined
                  DonStauffer @droftarts
                  @droftarts I didn't read all of the original posts, but it sounds like what I've been seeing. WiFi suddenly disconnects unexpectedly. It usually reconnects about 15 seconds later, but I've been dumped out of whatever macro folder I was looking at, and if I was editing, I'm dumped out of the editor. Everything functions fine until the next time it happens. M122 is below. I have replaced the SD card recently and this problem predates it (it's been happening for months). I also occasionally get WiFi failures at power on, but not frequently. Cycling the power fixes that.
                  When this happens I sometimes wish I had a wired ethernet connection to fall back on (or just use most of the time, but still have WiFi available). I've been considering replacing the Duet2 WiFi with a pair of Duet3 Minis, and I was wondering if one can have WiFi and the other ethernet and thus give me the choice.
                  7/16/2024, 11:38:19 AM M122
                  RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.2 (2024-06-11 17:13:43) running on Duet WiFi 1.02 or later + DueX5
                  Board ID: 08DGM-9T6BU-FG3SN-6JKD0-3S06Q-9AY7D
                  Used output buffers: 3 of 26 (21 max)
                  Static ram: 23384
                  Dynamic ram: 80968 of which 0 recycled
                  Never used RAM 2208, free system stack 120 words
                  Tasks: NETWORK(2,nWait 6,18.7%,217) HEAT(3,nWait 5,0.1%,328) Move(4,nWait 5,0.0%,274) DUEX(5,nWait 5,0.0%,23) MAIN(1,running,79.7%,659) IDLE(0,ready,1.5%,29), total 100.0%
                  Owned mutexes:
                  Last reset 00:16:12 ago, cause: power up
                  Last software reset at 2024-07-16 11:06, reason: OutOfMemory, Gcodes spinning, available RAM 160, slot 1
                  Software reset code 0x41c3 HFSR 0x00000000 CFSR 0x00000000 ICSR 0x0041f000 BFAR 0xe000ed38 SP 0x20002578 Task MAIN Freestk 1150 ok
                  Stack: 20019868 0041079f 00000000 00400247 00000000 00000000 000000d0 00400299 200025d8 20002690 00473bec 20012464 00000001 0040018d 200025d8 00435295 200025d8 00000001 ffffffff 00435499 20002690 00000001 00000019 0043706b 00000004 ffffffff 2000a70c
                  Error status: 0x00
                  Aux0 errors 0,0,0
                  MCU temperature: min 43.1, current 46.3, max 47.7
                  Supply voltage: min 23.6, current 23.9, max 24.4, under voltage events: 0, over voltage events: 0, power good: yes
                  Heap OK, handles allocated/used 297/69, heap memory allocated/used/recyclable 4096/4036/2208, gc cycles 332
                  Driver 0: standstill, SG min 0
                  Driver 1: standstill, SG min 0
                  Driver 2: standstill, SG min n/a
                  Driver 3: standstill, SG min n/a
                  Driver 4: standstill, SG min n/a
                  Driver 5: standstill, SG min 0
                  Driver 6: standstill, SG min 0
                  Driver 7: standstill, SG min 0
                  Driver 8: standstill, SG min n/a
                  Driver 9: standstill, SG min n/a
                  Driver 10:
                  Driver 11:
                  Date/time: 2024-07-16 11:38:15
                  Slowest loop: 50.79ms; fastest: 0.10ms
                  === Storage ===
                  Free file entries: 9
                  SD card longest read time 11.3ms, write time 3.3ms, max retries 0
                  DMs created 83, segments created 3, maxWait 46129ms, bed compensation in use: mesh, height map offset 0.000, max steps late 0, min interval 0, bad calcs 0, ebfmin 0.00, ebfmax 0.00
                  === DDARing 0 ===
                  Scheduled moves 16, completed 16, hiccups 0, stepErrors 0, LaErrors 0, Underruns [0, 0, 0], CDDA state -1
                  Heater 0 is on, I-accum = 0.1
                  USB is idle in state(s) 0
                  Daemon is doing "G4 P{var.DaemonPeriod}" in state(s) 0 0, running macro
                  Q0 segments left 0
                  === Filament sensors ===
                  check 0 clear 4594439
                  Extruder 0 sensor: no data received
                  Extruder 1 sensor: no data received
                  === DueX ===
                  Read count 1, 0.06 reads/min
                  === Network ===
                  Slowest loop: 44.20ms; fastest: 0.00ms
                  Responder states: HTTP(0) HTTP(1) HTTP(0) FTP(0) Telnet(0)
                  HTTP sessions: 1 of 8
                  === WiFi ===
                  MAC address 84:f3:eb:83:47:be
                  Module reset reason: Power up, Vcc 3.36, flash size 4194304, free heap 39068
                  WiFi IP address 192.168.1.130
                  Signal strength -35dBm, channel 11, mode 802.11n, reconnections 0
                  Socket states: 5 3 0 0 0 0 0 0
                  • trd87tundefined
                    trd87t
                    RRF3.4.6 WF2.1.0 - still dropped
                    RRF3.4.6 WF1.27 - good
                    • Much better ping times and consistent
                    • When connected to DWC, pings do drop but at least DWC never disconnects
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=844 ttl=255 time=6.689 ms
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=845 ttl=255 time=9.533 ms
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=846 ttl=255 time=4.322 ms
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=847 ttl=255 time=5.767 ms
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=848 ttl=255 time=3.885 ms
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=849 ttl=255 time=3.560 ms
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=850 ttl=255 time=23.067 ms
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=851 ttl=255 time=19.400 ms
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=852 ttl=255 time=5.826 ms
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=853 ttl=255 time=16.080 ms
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=854 ttl=255 time=5.848 ms
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=855 ttl=255 time=10.788 ms
                    64 bytes from xxx.xxx.xxx.254: icmp_seq=856 ttl=255 time=4.342 ms
                    RRF3.4.6 WF2.1.0d - still dropped
                    So at this point, I guess I will stay on RRF3.4.6 and WF1.27 for now.
                    rechrtbundefined 1 Reply Last reply Reply Quote 0
                    • rechrtbundefined
                      rechrtb @trd87t
                      @trd87t @DonStauffer
                      Hi, I've been looking into some improvements to the WiFi firmware in terms of connection stability. Below is my initial build with those changes. If possible, please do try it out and let me know if you still encounter issues.
                      Note: After firmware update, please confirm M122 outputs wifi firmware version as 2.1.1beta1.
                      DuetWiFiServer.bin
                      DonStaufferundefined 2 Replies Last reply Reply Quote 1
                        DonStauffer @rechrtb
                        @rechrtb I'll try it! Just installed RRF 3.6 alpha 2, which seems to work fine.
                          @rechrtb I have it installed. I'll let you know if I have any disconnects.
                          • rechrtbundefined
                            rechrtb @DonStauffer
                            @DonStauffer Thank you!
                            • rechrtbundefined
                              rechrtb @rechrtb
                              @DonStauffer By the way, is the disconnect something you can sort of 'induce'? Because, if you can, please do try it on this new firmware.
                                @rechrtb I haven't seen any way to make it happen. It may be my imagination, but I think it happens more in the afternoons than mornings, if that makes any sense.
                                No trouble since last night's update to RFF & WiFi.
                                • rechrtbundefined
                                  @DonStauffer @trd87t Hi, I just wanted to ask if you encountered issues with the beta firmware build so far...
                                    @rechrtb The WiFi still disconnects unpredictably. Alpha firmware and beta WiFi didn't make it better or worse. I don't see any pattern except it seems more in the afternoon. I was assuming it was an interference problem, although other houses are at least 100 feet away here, and the Duet is about 10 feet from my router. But with increasing bandwidth use for WiFi I figured interference.
                                    The biggest problem is if I'm editing a macro or something it drops me out and unsaved changes are lost. If I had the ethernet board I'd just have gone with a wired connection.
                                    • rechrtbundefined
                                      @DonStauffer I see. Sorry to hear you're still encountering issues. When the issue occurs, is DWC open in multiple tabs (same or different device). Or perhaps a transfer is going on? Also, this doesn't happen on 1.27x wifi firmware?
                                        @rechrtb Nothing is necessarily happening, and no, not multiple tabs. Sometimes I even go out of the room briefly and come back and I see in the console log it disconnected then reconnected. Sometimes I see it happen. Usually it's out for anywhere from 20 seconds to a minute or so.
                                        I don't remember the firmware version for sure but I'm pretty sure I was on the latest released version, and now 2.1.1beta1.
                                        • rechrtbundefined
                                          @DonStauffer
                                          Oh, do you have what that log says? Also, do you happen to have a mesh/multi-AP setup, and the router you mentioned just happened to be the closest one?
                                            @rechrtb said in Wifi/DWC Disconnecting with RRF3.5.2 on Duet2 Wifi Hardware:
                                            mesh/multi-AP
                                            Only one router in my house. I think the log entry just said it lost connection. Next time it happens I'll copy the log entry and post it here.
