    Duet2 wifi stuck repeating Wifi Error.
    2.8k
    • zBeebleundefined
      zBeeble @rechrtb
      @rechrtb said in Duet2 wifi stuck repeating Wifi Error.:
      @zBeeble Nothing beyond turning on the debug messages for network and WiFi. If I'm correct, you turned off the network debug messages though since it was too noisy? Also, please make sure it's logging to file so we don't miss anything.
      Yeah... the networking was generating a line every so often ... printer on or not.
      But the machine is connected to the home server ... which is always on. I'm using minicom ... which is set to log all traffic
      rechrtbundefined 1 Reply Last reply Reply Quote 0
      • zBeebleundefined
        zBeeble
        I generally have at least 2 computers (so I expect that to be 4 connections from time-to-time)... go this just now:
        WiFi: /home/renz/Projects/Duet3D/WiFiSocketServerRTOS/src/Connection.cpp(578): refused conn on port 80 already 4 conns
        ... but can have as many as 3 or 4. Is this number tunable?
        This doesn't seem to be my problem, tho... as it should recover.
          droftarts administrators @zBeeble
          @zBeeble From the https://docs.duet3d.com/en/User_manual/Troubleshooting/WiFi_troubleshooting page, two things that might be relevant:
          • In Duet Web Control, in the Settings > Machine specific > Communication section, check that "Maximum number of AJAX retries" is at least 3.
          • Is the connection stable when the printer is idle, but unreliable when printing? If so then there may be too few CPU cycles to service the network interface, because of an excessive step pulse rate.
            • Check the M122 report after a disconnection during a print, or after completing the print, and look at the number of 'hiccups' ('MaxReps' in old firmware versions) figure in the 'DDARing' or 'Move' section of the diagnostics.
            • This value should be kept below about 50. If it is higher, reduce either microstepping (M350) or maximum speed (M203).
            • Please note, hiccups and MaxReps is reset when you run M122 so only the value the first time you run M122 after a disconnection or completion of a print is significant.
          Edit: Sorry, the above is old info, and MaxReps isn't reported in the current firmware M122 report. I've asked @dc42 how this information is reported now.
          Edit: Updated the above with info from dc42.
          • rechrtbundefined
            rechrtb @zBeeble
            @zBeeble said in Duet2 wifi stuck repeating Wifi Error.:
            Those "already 4 conns" should be normal, especially when there are multiple clients with the web interface open.
            • zBeebleundefined
              zBeeble
              So... been printing OK... for awhile. Just started acting up today again. Oddly, the serial output is "chunky" .... and incomplete. One recent query:
              m122
              RepRapFirmware for Duet 2 WiFi/Ethernet version 3.5.1 (2024-04-19 14:40:46) running on Duet WiFi 1.02 or later
              Board ID: 08DDM-9FAM2-LW4SD-6J9F8-3SN6J-T3ZRY
              Used output buffers: 1 of 26 (26 max)
              Static ram: 23256
              Dynamic ram: 72928 of which 12 recycled
              Never used RAM 13540, free system stack 110 words
              Tasks: NETWORK(1,ready,15.7%,175) HEAT(3,nWait 5,0.1%,307) Move(4,nWait 5,2.9%,298) MAIN(1,running,81.3%,711) IDLE(0,ready,0.0%,
              29), total 100.0%
              Owned mutexes: WiFi(NETWORK) USB(MAIN)
              Last reset 10:03:58 ago, cause: power up
              Last software reset at 2024-07-29 10:46, reason: User, Gcodes spinning, available RAM 17140, slot 2
              Error status: 0x04
              Aux0 errors 0,0,0
              MCU temperature: min 35.4, current 35.9, max 36.9
              Supply voltage: min 11.0, current 12.2, max 12.3, under voltage events: 0, over voltage events: 0, power good: yes
              Heap OK, handles allocated/used 99/6, heap memory allocated/used/recyclable 2048/932/816, gc cycles 1
              Events: 0 queued, 0 completed
              Driver 0: ok, SG min 0
              Driver 1: ok, SG min 0
              Driver 2: ok, SG min 0
              Driver 3: ok, SG min 0
              Driver 4: standstill, SG min n/a
              Driver 5:
              Driver 6:
              Driver 7:
              Driver 8:
              Driver 9:
              Driver 10:
              Driver 11:
              Date/time: 2024-07-30 01:04:58
              Slowest loop: 11.10ms; fastest: 0.20ms
              === Storage ===
              Free file entries: 9
              SD card longest read time 1.5ms, write time 0.0ms, max retries 0
              DMs created 83, segments created 23, maxWait 448ms, bed compensation in use: mesh, height map offset -0.031, max steps late 0, m
              in interval 0, bad calcs 0, ebfmin 0.00, ebfmax 1.00
              next step interrupt due in 20 ticks, disab
              • zBeebleundefined
                zBeeble
                Notably, on one output not shown, "slowest loop" was around 146ms.
                • zBeebleundefined
                  zBeeble
                  I've turned on the debugging for 14 and 1 (wifi and network). Lots of chatter, but the printer is definitely acting up. The serial is no longer chunky, but at one point, I disconnected the serial ... which would reset the driver on the server.... and probably the duet, too.
                  m111 and chatter look like:
                  Debugging enabled for modules: Network(1 - 0xffffffff) WiFi(14 - 0xffffffff)
                  Debugging disabled for modules: Platform(0) Webserver(2) Gcodes(3) Move(4) Heat(5) Kinematics(6) InputShaping(7) unused(8) Print
                  Monitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) SbcInterface(16) CAN(17) Expansion(18)
                  New conn on socket 0 for local port 80
                  Found responder
                  Received 367 bytes
                  New conn on socket 1 for local port 80
                  Found responder
                  Received 329 bytes
                  Found responder
                  Found responder
                  Received 329 bytes
                  Received 367 bytes
                    Have you tried updating to 3.5.2 yet? Or the 3.6 alpha release? I think the beta is upcoming as well.
                    zBeebleundefined 1 Reply Last reply Reply Quote 0
                    • zBeebleundefined
                      zBeeble
                      The printer was idle, so I shut off the constant network chatter. wifi debug was still on (as it's fairly quiet). During the idle day, it said this:
                      Debugging enabled for modules: WiFi(14 - 0xffffffff)
                      Debugging disabled for modules: Platform(0) Network(1) Webserver(2) Gcodes(3) Move(4) Heat(5) Kinematics(6) InputShaping(7) unus
                      ed(8) PrintMonitor(9) Storage(10) PortControl(11) DuetExpansion(12) FilamentSensors(13) Display(15) SbcInterface(16) CAN(17) Exp
                      ansion(18)
                      Now.... 2 computers look at the web server and the web server is on an RFC 1918 address behind NAT ... so not general internet exposed.
                      • zBeebleundefined
                        zBeeble @Phaedrux
                        @Phaedrux said in Duet2 wifi stuck repeating Wifi Error.:
                        I'm a little bit upgrade adverse ... you can convince me, but equally, I don't believe this is upgrade related.
                        • zBeebleundefined
                          zBeeble
                          OOB ... looking at your debug message ... you could probably significantly cut binary size by cutting /home/renz/Projects from the path of all debug messages --- ie: cut to the root of the project.
                          • zBeebleundefined
                            zBeeble
                            OK. Now it's full-on inaccessible.
                            Lots of these lines scrolling on the console.
                            ResponseTimeout, pending=1
                            • zBeebleundefined
                              zBeeble
                              And just to be clear, two local computers are pointing at it and no network traffic (as expected) is coming from the router for it.
                              • zBeebleundefined
                                zBeeble
                                This is the log from the first few glitches above (posted here) through starting a new print and then it glitching hard:
                                ansion(18)
                                Done printing file
                                Finished printing file 0:/gcodes/CFFFP_DeckStand_Anker.gcode, print time was 13h 4m
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                ResponseBusy
                                • zBeebleundefined
                                  zBeeble
                                  I delivered m111 p1 s1, and this is the changed repeating output:
                                  1ResponseTimeout, pending=1
                                  WiFi: /home/renz/Projects/Duet3D/WiFiSocketServerRTOS/src/Con^?/renz/Projects/Duet3D/WiFiSocketServerRTOS/src/Connection.cpp(578
                                  WiFi: /hom^?s/Duet3D/WiFiSocketServerRTOS/src/Connection.cpp(578): refused conn on port 80 already 4 conns
                                  Bad recv status size
                                  WiFi: /home/renz/Projec^?/home/renz/Projects/Duet3D/WiFiSocketServerRTOS/src/Connection.cpp(578): refused conn on port 80 already 4 conns
                                  WiFi: /home/renz/Projects/Duet3D/WiFiSocketServerRTOS/src/Con^?uet3D/WiFiSocketServerRTOS/src/Connection.cpp(578): refused conn on port 80 already 4 conns
                                  WiFi: /home/renz/Projects/^?t 80 already 4 conns
                                  WiFi: /home/renz/Projects/Duet3D/WiFiSocketServerRTOS/src/Connection.cpp(578): refused conn on po^?/Connection.cpp(578): refused conn on port 80 already 4 conns
