    Macro Line 84 error after updating to 3.5.2
    • Sgt G 294undefined
      Sgt G 294
      I have the Duet 2 Wifi and I just updated the Firmware to 3.5.2 and now at start up, I get an error in the Console "Error in start-up file macro line 84: Pause the print before attempting to cancel it". I'll post my config file below. Thanks in advance!
      ; generated by RepRapFirmware Configuration Tool v2.1.7 on Wed Jan 15 2020 19:00:04 GMT-0500 (Eastern Standard Time)
      G90                                                  ; send absolute coordinates...
      M83                                                  ; ...but relative extruder moves
      M550 P"Ender5"                                         ; set printer name
      M552 S1 ; connect to strongest network with known SSID
      ;M552 S1 P"mywifi"                                 ; enable network
      ;M552 S2
      ; M554 PmyIP
      M586 P0 S1                                           ; enable HTTP
      M586 P1 S0                                           ; disable FTP
      M586 P2 S0                                           ; disable Telnet
      M569 P0 S0                                           ; physical drive 0 goes backwards
      M569 P1 S0                                           ; physical drive 1 goes backwards
      M569 P2 S0                                           ; physical drive 2 goes backwards
      M569 P3 S1                                           ; physical drive 3 goes forwards
      M584 X0 Y1 Z2 E3                                     ; set drive mapping
      M350 X256 Y256 I0                                    ; configure microstepping without interpolation
      M350 Z16 E16 I1                                      ; configure microstepping with interpolation
      M92 X1254.21 Y1251.72 Z392.53 E483.27                 ; set steps per mm
      M566 X480.00 Y480.00 Z24.00 E300.00                  ; set maximum instantaneous speed changes (mm/min)
      M203 X60000.00 Y60000.00 Z800.00 E3000.00            ; set maximum speeds (mm/min)
      M201 X800.00 Y800.00 Z100.00 E5000.00                ; set accelerations (mm/s^2)
      M906 X800 Y800 Z800 E800 I30                         ; set motor currents (mA) and motor idle factor in per cent
      M84 S30                                              ; Set idle timeout
      ;M208 X0:225 Y0:205 Z0:300                            ; set axis minima
      M208 X-3:234 Y0:205 Z0:300                            ; set axis minima
      M574 X2 S1 P"xstop"                                  ; configure active-high endstop for high end on X via pin xstop
      M574 Y2 S1 P"ystop"                                  ; configure active-high endstop for high end on Y via pin ystop
      M574 Z1 S2                                           ; configure Z-probe endstop for low end on Z
      ; Filament Sensor
      M591 D0 P3 C"e0stop" S1 R30:150 L24.84 E3.0 	     ; E0 endstop, D3D magnet sensor, enabled, sensitivity 24.8mm.rev, 70% to 130% tolerance, 3mm detection length
      M950 S0 C"exp.heater3"                               ; create servo pin 0 for BLTouch
      M558 P9 C"zprobe.in+zprobe.mod" H5 F120 T6000        ; set Z probe type to bltouch and the dive height + speeds
      G31 P500 X0 Y-38 Z2.08                               ; set Z probe trigger value, offset and trigger height
      ;M557 X20:225 Y0:167 S102.5:83.5                      ; define mesh grid
      M557 X10:225 Y0:167 P3                            ; define mesh grid
      M308 S0 P"bedtemp" Y"thermistor" T100000 B4138       ; configure sensor 0 as thermistor on pin bedtemp
      M950 H0 C"bedheat" T0                                ; create bed heater output on bedheat and map it to sensor 0
      M143 H0 S120                                         ; set temperature limit for heater 0 to 120C
      M307 H0 B1 S1.00                                     ; enable bang-bang mode for the bed heater and set PWM limit
      M140 H0                                              ; map heated bed to heater 0
      M308 S1 P"e0temp" Y"thermistor" T100000 B4725 C7.06e-8        ; configure sensor 1 as thermistor on pin e0temp
      M950 H1 C"e0heat" T1                                 ; create nozzle heater output on e0heat and map it to sensor 1
      M143 H1 S280                                         ; set temperature limit for heater 1 to 280C
      M307 H1 B0 S1.00                                     ; disable bang-bang mode for heater  and set PWM limit
      ;M307 H1 R5.086 K0.545:0.000 D1.38 E1.35 S1.00 B0 V24.2 ; Heater Tune see config override
      M950 F1 C"fan0" Q500                                 ; create fan 0 on pin fan0 and set its frequency
      M106 P1 S0 H-1                                       ; set fan 0 value. Thermostatic control is turned off
      M950 F0 C"fan1" Q500                                 ; create fan 1 on pin fan1 and set its frequency
      M106 P0 S1 H-1                                       ; set fan 1 value. Thermostatic control is turned off
      M950 F2 C"fan2" Q500                                 ; create fan 2 on pin fan2 and set its frequency
      M106 P2 S1 H1 T45                                    ; set fan 2 value. Thermostatic control is turned on
      M563 P0 D0 H1 F0                                     ; define tool 0
      G10 P0 X0 Y0 Z0                                      ; set tool 0 axis offsets
      G10 P0 R0 S0                                         ; set initial tool 0 active and standby temperatures to 0C
      M501                                                 ; load saved parameters from non-volatile memory
      M911 S19.8 R23 P"M913 X0 Y0 G91 M83 G1 Z3 E-5 F1000" ; set voltage thresholds and actions to run on power loss
      M0
      T0
        jay_s_uk @Sgt G 294
        @Sgt-G-294 you have an M0 is your config which is the command thats ran at the end of a print as stop. Remove it
        Sgt G 294undefined 1 Reply Last reply Reply Quote 1
          Sgt G 294 @jay_s_uk
          @jay_s_uk
          Thanks for the quick reply! I'll try removing that
            Sgt G 294
            SOLVED - thank you
            • jay_s_ukundefined jay_s_uk marked this topic as a question
            • jay_s_ukundefined jay_s_uk has marked this topic as solved
