wiring for touch probe on duet 3 6xd
having trouble with set up of touch probe on duet 3 6xd
cant seam to get the wiring right am i right that it is an analogue type with 2 wires
also can you tell me if there is a ready made macro for the probing thanks in advance -
Can you give some more information on what probe you have exactly? Are you talking about a BLTouch or something else?
Have you seen this yet? https://docs.duet3d.com/en/User_manual/Connecting_hardware/Z_probe_connecting
not a bl touch.
jest two wire, plate and crocodile clip -
It would be a simple switch type then. Probe type 8 probably.
How do you have it connected and defined in your config?
Please share your config.g and homing macros.
