Just upgraded SBC/Duet 6HC now have error connecting.
I have just ran an upgrade on my pi5/6HC printer and am now getting the "Connecting....." and the error "Failed to open IO device: Error 2. Cannot open GPIO device file '/dev/gpiochip4'" when opening the wen interface.
I had forgotten I was still configured to update from the 'unstable/testing' channel so have probably picked up an issue not yet resolved for the next release.
Seems it has upgraded from 3.5.2 to 3.5.3-rc.1, the printer was working fine before the upgrade. How would I fix this issue?
Thanks.[Edit]
I've tried downgrading the duet packages to the previous version with:sudo apt-get install duetcontrolserver=3.5.2 reprapfirmware=3.5.2-1 duetsoftwareframework=3.5.2 duetwebserver=3.5.2 duetpluginservice=3.5.2 duetruntime=3.5.2 duettools=3.5.2 duetpimanagementplugin=3.5.2 duetwebcontrol=3.5.2
This completes, but with the error:
Setting up reprapfirmware (3.5.2-1) ... [fatal] Failed to open IO device: Error 2. Can not open GPIO device file '/dev/gpiochip4'.
So I presume the Pi cannot communicate with the Duet board since upgrading the firmware of the board to 3.5.3-rc.1.
A look at /dev shows only the following gpiochip values:
gpiochip0 gpiochip10 gpiochip11 gpiochip12 gpiochip13
I found another article on setting up the DSF software and found that there is a reference to gpiochip4 in the file /opt/dsf/conf/config.json, editing the value of of following line resolved the issue:
"GpioChipDevice": "/dev/gpiochip4",
Changing this to /dev/gpiochip0 and restarting resolved the issue and I can now access the web interface.
