    Upgrade from Duet 2 wifi to Duet 3 6hc config Issues
    Firmware installation
    1.4k
    • Alijambo73undefined
      Alijambo73 @droftarts
      @droftarts I have 5 endstops that are all switches. 1 on x 2 on y and 2 on z.
      When I use the end stop monitor plug in they all seem to be working correctly. The screenshot shows that x and y are homed which was correct. I can manually trigger the 2 end stops Z and see that thay appear to be working too.
      I have a probe to find 0 on the material. The 2 endstops used to home z are set to find the high end.
      I'm thinking there is something in the config of the touchplate probe that is incorrect. I commented out the probe but the behavior remained the same.
      Can you see where I have made a mistake with between the endstops and touch plate probe?
      cosmowaveundefined droftartsundefined 2 Replies Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @Alijambo73
        @Alijambo73 What type is your z probe? Is it like a switch?
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
          droftarts administrators @Alijambo73
          @Alijambo73 Your home Z uses G30 to home, which is using the probe, not the Z endstops. If you want to use the Z endstops, you need to change homez.g to use them. Currently in homez.g you have:
          ; homez.g
          ; called to home the Z axis
          ; generated by RepRapFirmware Configuration Tool v3.5.4 on Mon Sep 09 2024 22:47:08 GMT-0600 (Mountain Daylight Time)
          ; increase Z
          G91 ; relative positioning
          G1 H2 Z5 ; move Z relative to current position to avoid dragging nozzle over the bed
          G90 ; absolute positioning
          ; home Z
          var xCenter = move.compensation.probeGrid.mins[0] + (move.compensation.probeGrid.maxs[0] - move.compensation.probeGrid.mins[0]) / 2 - sensors.probes[0].offsets[0]
          var yCenter = move.compensation.probeGrid.mins[1] + (move.compensation.probeGrid.maxs[1] - move.compensation.probeGrid.mins[1]) / 2 - sensors.probes[0].offsets[1]
          G1 X{var.xCenter} Y{var.yCenter} F7200 ; go to bed centre
          G30 ; probe the bed
          Change it to:
          ; home Z
          var zTravel = move.axes[2].max - move.axes[2].min + 5 ; calculate how far Z can travel plus 5mm
          G1 H1 Z{-var.zTravel} F600                            ; coarse home in the -Z direction
          G1 H2 Z5 F6000                                        ; move back 5mm
          G1 H1 Z-10 F300                                       ; fine home in the -Z direction
          You will need to change the 'home Z' section of homeall.g too. You should also be able to home Z without having to home X and Y first.
          Alijambo73undefined 1 Reply Last reply Reply Quote 0
            @droftarts I'm using a touch plate like this.
              @Alijambo73 You want to use a probe like that for setting tool offsets, not for homing the Z axis. Please try what I suggest in my last post.
              Note that those type of probes are not much good for setting work offsets in X and Y. This type of probe is better: https://ooznest.co.uk/product/original-workbee-xyz-touch-probe/
                @droftarts on my duet 2 board this all worked fine and I used the probe to determine 0 for the work peice while the microswitches were used for homing z.
                I have changed the homez and homeall but still getting the 2 errors
                Error: in file macro line 14: G1: target position outside machine limits
                Error: in file macro line 14: G1: insufficient axes homed
                This is how they read now.
                Home z.g
                ; home Z
                homeall.g
                ; homeall.g
                ; called to home all axes
                ; increase Z
                G1 H2 Z5 F7200                                        ; move Z relative to current position to avoid dragging nozzle over the bed
                ; home XY
                var xTravel = move.axes[0].max - move.axes[0].min + 5 ; calculate how far X can travel plus 5mm
                var yTravel = move.axes[1].max - move.axes[1].min + 5 ; calculate how far Y can travel plus 5mm
                G1 H1 X{-var.xTravel} Y{-var.yTravel} F6000           ; coarse home in the -X and -Y directions
                G1 H2 X5 Y5 F7200                                     ; move back 5mm
                G1 H1 X{-var.xTravel} Y{-var.yTravel} F300            ; fine home in the -X and -Y directions
                ; home Z
                  @Alijambo73 Can you describe, from turning on the machine, exactly what you are doing, and post all the responses coming back from the console? ie of the two errors you report above, which is from running homez.g, and which is from running homeall.g?
                  Somehow, it seems some other macro is being called, and it's that macro that has got the error in it. Please could you zip your whole sys folder (so it has all the files) from your SD card and post it here? If you add '.txt' to the end after .zip, you should be able to upload it to the forum.
                    @droftarts after power up if I use home z I get " Error: in file macro line 14: G1: insufficient axes homed"
                    If I then home x and y, then use home z i get "Error: in file macro line 14: G1: target position outside machine limits"
                    After power up if I hit homeall (this is new) it will home correctly but then if I try to lower Z by -25 it tries to raise z even though the endstops are triggered.
                    This just keeps getting more weird.
                    download (1).zip.txt
                      dc42 administrators @Alijambo73
                      @Alijambo73 said in Upgrade from Duet 2 wifi to Duet 3 6hc config Issues:
                      This is normal if homeZ uses the Z probe to home, because you would be probing at a random position, possibly off the bed.
                      You are doing this:
                      My guess is that the calculation of yCenter and/or xCenter is going wrong. Have you set up the grid in config.g? Why not use bed centre calculated from the M208 limits instead?
                        Alijambo73 @dc42
                        @dc42 I don't want it to use the center of the bed. I want the z to home at x0 y0.
                        I inverted the zprobe and it now reads 0 in DWC and I changed this line
                        to
                        G1 H1 Z{var.zTravel} F600                            ; coarse home in the -Z direction
                        I also reversed the direction on the Z steppers and now the homeall seems works correctly.
                        If I try to just home Z i get "G28 Z
                        Error: Failed to home axes Z"
                        Here is the homeall.g that is working
                        ; homeall.g
                        ; increase Z
                        ; home XY
                        ; home Z
                        Here is the homez.g that is giving the error
                        ; home Z
                        var maxTravel = move.axes[2].max - move.axes[2].min + 5 ; calculate how far Z can travel plus 5mm
                        G1 H1 Z{var.maxTravel} F600                             ; coarse home in the +Z direction
                        G1 Z-5 F6000                                            ; move back 5mm
                        G1 H1 Z{var.maxTravel} F300                             ; fine home in the +Z direction
                          Phaedrux Moderator @Alijambo73
                          Do you see the difference?
                            Alijambo73 @Phaedrux
                            @Phaedrux That was it. Thank you for your help.
