    Customizable (or reasonable) Extruder Control feed rates
    Duet Web Control wishlist
    • wescundefined
      wesc
      The standard extruder feed rates from the Machine Control panel of 60, 30, 15, 5 and 1 mm/s are mostly useless. Maybe on some other device 60mm/s makes sense, but on my printer anything above 5mm/s cause missed steps, and on some extruders (Titan Aero, i'm looking at you) even 5mm/s is too fast. I used this panel to calibrate extruder steps by extruding 100 mm. It takes forever at 1mm/s. I would love either more granularity on the low end (1, 2, 3, 5mm/s?), or the ability to set the speeds..
      CroXY - Crossed Gantry Printer, Ultibots D300VS+, Custom CoreXYU
      • Martin_Sundefined
        Martin_S
        They claim that the high speeds are for loading filament.
        As a Titan Aero user too, I only use 5 and 1 mm/s. The 5mm/s speed sometimes skips if the temperature is a bit cold.
        Either way, I like your request.
        +1 for a customizable or at least less agressive extude speeds.
        If it ain't broke, fix it till it is =)
        • totalitarianundefined
          totalitarian
          I 2nd this request too. As a work around I have to create custom macros
          • dintidundefined
            dintid
            If your Titan skips steps you need to feed it more current. If that doesn’t solve it, you should be looking at a new motor.
            I run it at the highest speed when loading and unloading filaments and at 5 when just extruding the first 100mm to or so.
            Used Titan just to be clear.
            I would like customizeable steps though. Same as the option to add the drop down temperatures for the heaters.
            RepRapFirmware supported G-codes: https://duet3d.com/wiki/G-code
