    Changing Stepper Speeds Dynamically with Duet wifi
    MultiAxis Printing
    • eranglrundefined
      eranglr
      Hey everyone!
      I’ve built a custom machine (not exactly a 3D printer) using a Duet 3 controller, and I could use some help with a challenge I’m facing.
      I have three stepper motors that need to run continuously at different speeds. So far, I’ve managed this pretty easily with a g-code like:
      G1 X9999999 Y9999999 Z99999999 F1000;
      However, here’s where I’m stuck: I need to be able to change the speed of one or two of the steppers while they’re running.
      One idea I had was to create a really long g-code file with something like:
      G1 X2 Y2 Z2 F100;
      Then I’d use an M92 command to change the steps/mm for each axis, effectively adjusting the speed "on the fly."
      I’m open to any suggestions or ideas you may have—thanks in advance!
      cosmowaveundefined shaunpplundefined Aurimasundefined 3 Replies Last reply Reply Quote 0
      • cosmowaveundefined
        cosmowave @eranglr
        @eranglr You can easy do that either with limiting the max feedrate M203 or with the "speed factor override" M220.
        Everything you need is written in the documentation.
        Mankati FSXT+, DeltaTowerV2, E3D MS/TC
        eranglrundefined 1 Reply Last reply Reply Quote 0
        • eranglrundefined
          eranglr @cosmowave
          @cosmowave said in Changing Stepper Speeds Dynamically with Duet wifi:
          M203
          No, you can't... I suggest that you re-read my post.
          cosmowaveundefined 1 Reply Last reply Reply Quote 0
            cosmowave @eranglr
            @eranglr Ah... ok. It's not possible because it's one long move...
            Sorry for that.
            Not sure if you can make something with "segmentation"?
            EDIT: could be possible to use segmentation with M669, which is dividing a long move in many shorter moves...
            • shaunpplundefined
              shaunppl @eranglr
              @eranglr Would be beneficial to see what you have built and what you use it for, perhaps then people could suggest alternate paths for you to follow or help investigate.
              Sounds like you are after variable speed control ? on the fly ?
              • Aurimasundefined
                Aurimas @eranglr
                @eranglr said in Changing Stepper Speeds Dynamically with Duet wifi:
                segmentation most likely is not going to work since you will ahve jerk and accelleration to take into account.
                I have done similar thing before and you have to account for those factors.
                Australian design and build large scale 3d printers
                https://aurarum.com.au
                  T3P3Tony administrators @shaunppl
                  @shaunppl this is the subject of a feature request:
                  https://github.com/Duet3D/RepRapFirmware/issues/780
                  T3P3 created this issue in Duet3D/RepRapFirmware
                  open Support configuring an axis as "continuous rotary" #780
